Latest Version 1.01.09 - Hotfix (non-critical)
Chameleon
Post by Chameleon »
Hi all
Just a quick hotfix. You can download the latest version (1.01.09) from this link:
https://www.dropbox.com/s/vtnxa5ssxvrog ... f.zip?dl=1
This update is non-critical and will only affect an issue that very few users will come across. The problem will only occur if the first Debug option is switched on.
What's new in version 1.01.09?
There are no new features in version 1.01.09 but there is an essential hotfix to resolve an issue discovered by TOPS.
  • B92 - iFindStuff won't calculate the correct read distance or travel time to the Home GeoFence. I only have one Home GeoFence as confirmed by Debug option 5. Checking with Debug Option 1 (critical errors only) the plugin displays an error message (Failed to calculate bearings....contact Developer). Resolved - This was a good spot. There was an error in the code for displaying error messages using the first Debug Option (ironically a debug message causing a fault :roll: ) which has now been corrected. This problem was also displayed in the iFindStuffError.log and enabled me to identify the specific issue very quickly.
    You can also check the iFindStuffErrors.log as shown in a previous post (1.01.05)
    http://forums.indigodomo.com/viewtopic. ... 81&t=14982
Regards
Mike
TOPS
Re: Latest Version 1.01.09 - Hotfix (non-critical)
Post by TOPS »
:D Hi Mike,
"Well done that man!!!!" all seems to be working perfectly now after the Hotfix.......excellent, I'll keep you informed (as you know I will :wink: )
Thanks for all your help,
Dave
Return to “iFindStuff”
