Latest Version 1.0.49 - minor update
Chameleon
Post by Chameleon »
Hi all
I've released version 1.0.49 which contains a minor update regarding distance calculations and improved debugging information for calculations. There is no need to update your plugin if you are not having any issues with Home Geo, Bearing or Compass calculations. However, you should be using version 1.0.46 as the last version contained an important fix for distance calculations on ranges. 1.0.49 contains all fixes from previous versions.
You can download and install the latest version from this link:https://www.dropbox.com/s/vtnxa5ssxvrog ... f.zip?dl=1
What's new in version 1.0.49?
  • B76 - Bearing & Compass calculations failure. If a Latitude or Longitude is entered incorrectly for a GeoFence, especially a Home GeoFence, or the Longitude/Latitude update from the Apple API is corrupted (rare but occasional error) the plugin will fail to calculate Home Bearing or Distances correctly with the error iFindStuff Failed to calculate bearing numbers or update correctly - advise Developer. This has now been trapped. If you feel that updates to Home information is not being correctly completed please turn on Debug Option 1 and send me a copy of the log.
    B77 - No debugging provided for calculation options. Added additional debugging messages for bearing and compass calculations to determine any issues with GeoFence or Device location set ups.
    Minor typo updates - Changed a few spellings on configuration screens
That's all
Regards
Mike
Return to “iFindStuff”
