Latest version of iFindStuff - 1.0.45
Chameleon
Post by Chameleon »
Hi all
I've released version 1.0.45 which contains an important fix if you have unusual characters in the device name on your iDevice. This version will automatically strip out these characters in iFindStuff without the need to change the actual name of your device on your iDevice.
You can download and install the latest version from this link:https://www.dropbox.com/s/vtnxa5ssxvrog ... f.zip?dl=1
What's new in version 1.0.45?
  • F/B70 - Issue with device names containing ",". Caused a float literal error on device update. This is caused by the use of commas that are special python characters in dictionary & array management. This character is now automatically removed from the device name for use in iFindStuff. NO CHANGES ARE MADE TO THE NAME USED ON THE ACTUAL iDEVICE ITSELF.
    F/B71 - Issue with device names containing ":", "'", or ";". Can cause a float literal error on device update on some machines. There have been two examples of this error so it's fairly rare. These characters are also ignored in iFindStuff device names.
    F/B72 - Issue with random maps being displayed in safari when using Debug 3 error tracking. Resolved. Display of maps only occurs on Debug Option 4 to reduce activities when debugging issues
    B73 - Issue with random messages being displayed in indigo log. Some debugging messages were not trapped. Resolved
Thanks again for all your support and ideas for features
Regards
Mike
Return to “iFindStuff”
