Geofencing radius limit
I've just purchased DomoPad for my new Android phone.
Previously on my iPhone, I had triggers on two fences: one within 2 miles of my house, and one for 15 miles away. I had intended to use DomoPad to reproduce this functionality, but it seems the radius is limited to 10km. Since I work more than 10km from home, this won't work for the 2nd trigger.
Is there a reason it's limited to just 10km? Or maybe there is another way to do what I want? Essentially, I use the 15 mile trigger to indicate that I'm going to be away for a while, which shuts down more things in the house than the first trigger.
- RogueProeliator
Re: Geofencing radius limit
I can increase the limit, no problem... I had set a limit as some users had accidentally set very large radius fences accidentally (when the feature was first released to beta). However, I had meant to go back and revisit that in the future. I'll get it increased in the next release.
Adam
Adam
Appreciate it!
One more quick question. I assume this requires a connection to Indigo for the geofencing triggers to work, yes? I signed up for the prism reflector service to facilitate this, but I figured I'd verify with you that this how it actually happens (I can't think of any other way).
Thanks again.
Thanks again.
- RogueProeliator
You are correct, the geofencing triggers actions on the remote server, so a connection is required. In fact, you will get an error notification if DomoPad can't contact the server. If you have a reflector setup then DomoPad will use it for geofencing actions. You may want to check setting to make sure your reflector is picked up... If not then can reselect the server in the selection screen (once the reflector is setup on the server first of course).
Does DomoPad need to be open on my phone for geofencing to work? My trigger didn't activate today when I went to work.
Yeah, I am unable to get geofencing triggers to work. I'm not sure why. It's set to run an Action Group on leaving and another on entering, both which just set a boolean variable.
If it helps, I have a Sony Xperia Z3 Compact running Android 5.0.2.
Is there anything else you'd need from me to help diagnose the issue?
- RogueProeliator
If you are not getting an error in the notification panel, and the Last Triggered is not being updated in the list, DomoPad is likely not getting the notification of the geofence boundary being passed. This notification comes from the system, so perhaps it has become disabled without DomoPad knowing it; try disabling and re-enabling each geofence (to do so edit each, uncheck the Enabled box, save, edit and re-check/save).Yeah, I am unable to get geofencing triggers to work. I'm not sure why. It's set to run an Action Group on leaving and another on entering, both which just set a boolean variable.
That would be the first step...
Adam
OK I've done that. Quick question though: does DomoPad actually have to be open for this to work? I've got it running, but was curious.
- RogueProeliator
No, whenever your phone boots up DomoPad registers the geofences such that it (DomoPad) will be informed whenever the geofence boundary is passed. The system will launch the necessary parts of the application if it is not running. One thing I don't know, and can investigate, is what happens if something disabled the geofences -- such as maybe (guessing here) turning off location services -- after the bootup. DomoPad may consider the geofences enabled, but in reality without location services running they won't ever be called.OK I've done that. Quick question though: does DomoPad actually have to be open for this to work? I've got it running, but was curious.
That would be another thing to double check - that location services are enabled on the device. Some low-battery / battery-saver modes may disable that when the battery gets low.
I confess I'm still new to Android, but under Settings->Location, it is enabled (high accuracy mode), and shows DomoPad as an app that has used location services.
In the permissions for DomoPad it also does show that it's permitted to use location services.
Do I need to reboot the phone maybe to get it to register the geofences?
- RogueProeliator
Have you tried them since disabling/re-enabling? From the sounds of it, you have the location services running and setup okay. If they still aren't triggering, let me know and I will get some debug information in there to help us diagnose the issue.Do I need to reboot the phone maybe to get it to register the geofences?
Have not tried yet (still at work). I will check it when I get home (which should trigger the action).
Thanks again for your help!
That did it! It triggered on my way home from work
Thanks again!
Thanks again!
It seems to trigger now when I leave the fence, but it's also triggering the entrance action group 10-15 minutes later, even though I did not re-enter. It only does this once and is not triggering a second time when I do actually return.
Any idea what might be causing this?
Oh, it appears the latest update just fixed this. Thanks
