Mac System Plugin Application, Helpers & Daemon known config
bip.philippe
Post by bip.philippe »
Dyn Updater
Application can be managed using the Application device with a special settings:
  • Use special process name: Tick
  • Process name : dyn_updater
Dyn Updater needs a Daemon device to follow the background process.
  • Daemon process name: dyn_updater
  • Daemon full path and name: /Applications/Dyn Updater.app/Contents/MacOS/dyn_updater
  • Daemon start command arguments: --daemon start
  • Daemon sop command arguments: --daemon stop
EyeTV
Application can be managed using the Application device with no special configuration.
EyeTV Helper needs an Helper device.
  • Helper name: EyeTV Helper
  • Helper directory path: /Library/Application Support/EyeTV
Handyprint
Handyprint Helper needs an Helper device.
  • Helper name: handyPrintUserDaemon
  • Helper directory path: /Applications/handyPrint.app/Contents/Library/LoginItems
Printopia
Printopia needs a Daemon device to follow the background process. It cannot start or stop it.
  • Daemon process name: Printopia Server
  • Daemon full path and name: /Users/admin/Library/PreferencePanes/Printopia.prefPane/Contents/MacOS/Printopia Server.app/Contents/MacOS/Printopia Server
  • Daemon start command arguments: keep it empty
  • Daemon sop command arguments: keep it empty
Return to “Bip's Plugins”
