[Mac System] Enhancement requests (XMBC Bug) (Solved)
bip.philippe
Post by bip.philippe »
Create a post for any new request !
ELWOOD
Re: [Mac System] Enhancement requests
Post by ELWOOD »
Trying the plug in for starting and stopping XBMC media server. It seems to work OK and does start and quit the program but I do get
the following error each time:
Starting XBMC
Mar 22, 2015, 5:58:25 PM
Mac System Error launching XBMC failed because 2015-03-22 17:58:24.559 osascript[94323:507] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
osascript: OpenScripting.framework - scripting addition "/Library/ScriptingAdditions/Adobe Unit Types.osax" declares no loadable handlers.
2015-03-22 17:58:24.561 osascript[94323:507] Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:
/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: mach-o, but wrong architecture
osascript: OpenScripting.framework - scripting addition "/Library/ScriptingAdditions/XSLT Tools.osax" declares no loadable handlers.
Stopping XBMC
Mar 22, 2015, 5:59:07 PM
Mac System Error forced quit XBMC failed because 2015-03-22 17:59:07.050 osascript[94348:507] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
2015-03-22 17:59:07.053 osascript[94348:507] Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:
Looking forward to setting up my media hard drives.
Thanks for sharing your plug in
Elwood
bip.philippe
Just you let you know that working on my EyeTV plugin allowed me to develop better error management.
I am going to issue a new release of Mac System that will include these, and hopefully solve your issue.
Sincerely,
Vaillant
Post by Vaillant »
I like the idea for more info/control over our Mac's through a plugin.
Ever thought of sound control, i.e. control app. Midi to select/configure output?
Greeting,
Adrian
bip.philippe
ELWOOD wrote:Trying the plug in for starting and stopping XBMC media server. It seems to work OK and does start and quit the program but I do get
The v1.1.0 should not output this message.
Please let me know,
ELWOOD
Post by ELWOOD »
Upgraded to 1.1.0
Getting the following error that keeps repeating until I disable the plugin.
Apr 20, 2015, 6:37:49 PM
Enabling plugin "Mac System 1.1.0"
Starting plugin "Mac System 1.1.0" (pid 33702)
Started plugin "Mac System 1.1.0"
Mac System Error shell script failed because /bin/sh: -c: line 0: unexpected EOF while looking for matching `''
/bin/sh: -c: line 1: syntax error: unexpected end of file
Mac System Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 188, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Mac System.indigoPlugin/Contents/Server Plugin/interface.py", line 143, in getVolumeData
<type 'exceptions.TypeError'>: 'NoneType' object is unsubscriptable
Mac System Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Received INSTEON "synchrolinc" on
Trigger SumpPump Running Timer (on) SPEAK
Received INSTEON "synchrolinc" off
Trigger SumpPump Stopped Timer (off) SPEAK
Disabling plugin "Mac System 1.1.0"
Stopping plugin "Mac System 1.1.0" (pid 33702)
Stopped plugin "Mac System 1.1.0"
Let me know if you need any more info.
Elwood
bip.philippe
Could you activate the followings : Enable debugging and Enable log raw data in the plugin configuration and send me the resulting log ?
Thank in advance,
bip.philippe
Hi again,
I forgot one thing in my previous post :
This new version of the plug-in needs you to edit the configuration of every application or volume device and click save on it to create some new data.
Have you done that ?
Sincerely
bip.philippe
Can you try v1.1.1 ?
Let me know,
ELWOOD
Post by ELWOOD »
Upgraded to 1.1.1, removed old device type application XBMC and added new device XBMC
starting XBMC with the plugin I do not get any errors and the app starts OK
However the log now shows status of XBMC about once a minute.
Log:
Apr 22, 2015, 7:06:55 PM
Mac System received "XBMC" status PCpu update to 4.3
Mac System received "XBMC" status ETime update to 283
Apr 22, 2015, 7:07:55 PM
Mac System received "XBMC" status PMem update to 4.4
Mac System received "XBMC" status PCpu update to 4.5
Mac System received "XBMC" status ETime update to 343
Apr 22, 2015, 7:08:15 PM
AD2USB Alarm Interface Zone: -DRIVEWAY MOTION supervision received. (RFX:0078216,04)
Apr 22, 2015, 7:08:55 PM
Mac System received "XBMC" status ETime update to 403
Apr 22, 2015, 7:09:36 PM
Schedule PLOT META OFFICE MOTION (delayed action)
Meta Device META OFFICE MOTIONS Device "META OFFICE MOTIONS" off
Apr 22, 2015, 7:09:55 PM
Mac System received "XBMC" status ETime update to 463
Schedule Wood stove Tstat fan off (winter)
Sent INSTEON "Fan Attic " off
Apr 22, 2015, 7:10:55 PM
Mac System received "XBMC" status PCpu update to 4.4
Mac System received "XBMC" status ETime update to 523
Schedule KITCHEN motion (delayed action)
Sent INSTEON "KITCHEN LED UNDER COUNTER LIGHTS" off
Apr 22, 2015, 7:11:55 PM
Mac System received "XBMC" status PCpu update to 3.3
Mac System received "XBMC" status ETime update to 583
_________________________________
When the plugin quits XBMC I do get 1 error in the log:
Apr 22, 2015, 7:16:55 PM
Mac System received "XBMC" status PCpu update to 4.6
Mac System received "XBMC" status ETime update to 883
Apr 22, 2015, 7:17:11 PM
Mac System sent device "XBMC" action TurnOff
Mac System Error applescript (* Tell to quit *) failed because 2015-04-22 19:17:12.187 osascript[17276:507] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
2015-04-22 19:17:12.198 osascript[17276:507] Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:
Mac System received "XBMC" status ProcessID update to 0
Mac System received "XBMC" status onOffState update to False
Mac System received "XBMC" status PStatus update to off
Mac System received "XBMC" status PCpu update to 0
Mac System received "XBMC" status ETime update to 0
Mac System received "XBMC" status LStart update to
Mac System received "XBMC" status PMem update to 0
All seems to work OK except the error when the app is quit.
Elwood
achterberg
Post by achterberg »
I'm getting the same log entries every minute. I downloaded the plugin to try it out, and created an iTunes app to play with and noticed the log entries. I thought that was the default behavior so I disabled Indigo communication for the device, but they still show up. Not a huge deal, but I would prefer not to have them. But the plugin seems to be working fine and I'm sure I'll find a use for it somehow.
bip.philippe
ELWOOD wrote:Upgraded to 1.1.1, removed old device type application XBMC and added new device XBMC
Elwood
I just published the v1.2.0 version that :
  • introduces a less verbose log
  • should correct the last bugs (but I have no way to test it here).
Thanks for your feedback,
Sincerely,
bip.philippe
achterberg wrote:I'm getting the same log entries every minute. I downloaded the plugin to try it out, and created an iTunes app to play with and noticed the log entries. I thought that was the default behavior so I disabled Indigo communication for the device, but they still show up. Not a huge deal, but I would prefer not to have them. But the plugin seems to be working fine and I'm sure I'll find a use for it somehow.
  • now manages the "enable Indigo communication" flag.
Sincerely,
achterberg
Thank you, I appreciate the changes.
ELWOOD
Post by ELWOOD »
Installed 1.2.0
Starting and stopping application works as expected.
Starting no errors in log. When quitting application I get the following error.:
Apr 25, 2015, 10:43:31 PM
WUnderground There is 1 severe weather alert for the Allendale location:
WebServer request to execute "iPAD" control #207 from 192.168.1.6
Mac System Error applescript (* Tell to quit *) failed because 2015-04-25 22:43:39.980 osascript[74520:507] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
2015-04-25 22:43:40.012 osascript[74520:507] Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:
Apr 25, 2015, 10:44:03 PM
___________
Elwood
Locked
Return to “Bip's Plugins”
