- Native control pages are now very usable -- refreshing images and device updates are snappier and should work all the time, fixed a bunch of potential crash points, text rendering is much improved, image caching is working snappier and much more. There are a few minor display issues but those seem to be the fringe cases. Please post with any issues you find and I'll walk you through sending me the underlying display information to diagnose/fix.
- Web control pages will benefit from native device popups (e.g. sliders on dimmers, on/off, etc.)
- The Indigo Server selection has been drastically improved in the settings; HousePad can now automatically detect Indigo Servers on the network and configure all settings for you (similar to Indigo Touch)
- If you use the above method to select your Indigo Server, HousePad is now able to automatically switch from Home to Away servers (utilizing local IP address for when at home on the local network and an external IP or Prism Reflector when away)
- Geofences will now re-enable themselves on device boot (note this requires a new permission of Launch on Device Start; HousePad does not actually start to the foreground but does run code to re-enable Geofences that were previously enabled before the reboot)
- TiVo and Roku controls are better supported in the native device popup control, including keyboard support
I hope that some of the beta testers will upgrade to this version and leave any feedback before I launch to everyone via the standard download.
Adam
