NOAA Weather Plus - new location [solved]
jalves
Post by jalves »
I recently moved from MA to FL. Got my Indigo setup, running in the new house and making needed changes to reflect the new location, etc. I'm not seeing how to change the weather locale for this plug-in. Is it necessary to first delete the "device" and then re-create it to be able to change the locale? Right now its still using my old location.
Jeff
DaveL17
Re: NOAA Weather Plus - new location
Post by DaveL17 »
1. Go to the NOAA weather device, highlight it, and click 'Edit' (or double-click the device).
2. Click on 'Edit Device Settings'.
3. From there, you can enter a new 'Weather Station ID'.
Hope this helps.
Dave
My Plugins and Scripts
jalves
Post by jalves »
Thanks, that did it. I should have realized it was something simple.
Jeff
DaveL17
Re: NOAA Weather Plus - new location [solved]
Post by DaveL17 »
Glad I could help.
nsheldon
Post by nsheldon »
Moderator Note:
The instructions given by DaveL17 are for the Perceptive Automation "NOAA Weather" plugin that ships with Indigo, NOT for the NOAA Weather Plus plugin created by myself.
DaveL17
Post by DaveL17 »
nsheldon wrote:Moderator Note:
Whoops. Well, at least the answer I gave about the wrong plugin was the right one. :D
Dave
