I've created an update checker module that can be easily included in any indigo plugin. I started with berkinet's versionCheck method, which worked great, but then my imagination got the best of me.
I wanted to have a version checking module that would meet the following requirements:
1. Have the option to email a user once for each new version release.
- Maybe it's just me, but I rarely check my logs unless something is wrong. Email's the only reliable notification option for me. I've also had a few of my plugins break after an Indigo update (usually something I did wrong). It's not always obvious to the user that there's a problem. It would be nice to have a facility where I can notify the users of an important update. The plugin saves the version number last emailed to the user so they're only notified once per version.
- This way the user can be notified of what's changed without them having to go looking in the forums. A download link can optionally be added into the body of the email.
- I was aiming for two or three lines of code. One line to create the instance and setup the module. One more to allow it to see if it's time to check for an update. Then one more if you want to force an update manually, like from a menu action. The plugin handles all the config checking and state saving on its own.
Using indigoPluginUpdateChecker
1. You can download the module here.
2. Put the module in your plugin's Server Plugin folder, and import the module at the top of your plugin.py:
import indigoPluginUpdateChecker
self.updater = indigoPluginUpdateChecker.updateChecker(self, versionFileUrl [,daysBetweenChecks])
- - versionFileUrl is the url for the location of your update info file. The url must be formatted like "http://www.domain.com/folder/versionInfoFile.html"
- daysBetweenChecks is optional and defaults to 1. This controls how often the module will check for updates automatically. They can always be checked for manually by running self.updater.checkVersionNow()
If you've already got a runConcurrentThread that loops, just add the line below:
self.updater.checkVersionPoll()
# While Indigo hasn't told us to shutdown
while self.shutdown is False:
self.sleep(1)
self.shutdown = True
PluginConfig.xml
If you'd like to use the email feature, you need to have at least a text box for an email address in your plugin's config. You can also optionally have a checkbox that's used to enable/disable email notifications. Regardless of either of these settings the module will always check the server at the set interval and make a note in the log.
<!-- Do NOT change the ids -->
<Field id="updaterEmail" type="textfield">
<Label>Email:</Label>
</Field>
<Field id="updaterEmailNote" type="label" fontColor="darkgray" fontSize="small" alignWithControl="true">
<Label>Email sending must be configured in Indigo's preferences.</Label>
</Field>
<!-- Optionally a checkbox can also be used. -->
<Field id="updaterEmailsEnabled" type="checkbox" defaultValue="true">
<Label>Email Update Notifications:</Label>
</Field>
- 'updaterLastCheck' = Last time an update check was performed (epoch time)
'updaterLastVersionEmailed' = The last version emailed to the user
Checking Manually
If you want to have a Check for Updates option in the plugin's menu.
MenuItems.xml:
<?xml version="1.0"?>
<MenuItems>
<MenuItem id="menu1">
</MenuItem>
</MenuItems>
def checkForUpdates(self):
indigo.server.log(u"Manually checking for updates")
Sample Server Version Info File
Below is a template for the version file that must reside on a server. The only mandatory line is the first one. That will cause a note to be displayed in the Indigo log. If you don't want a notification emailed to the user then don't include the EmailSubject: or EmailBody:.
Version: 1.3.1
EmailSubject: DSC Alarm Indigo Plugin Update
EmailBody: The DSC Alarm Plugin you are using with Indigo has been updated to version 1.3.1.
The changes are:
- Change 1
- Change 2
The update can be downloaded at the link below.
http://www.domain.com/plugins/plugin.zip
This email was sent to you by Indigo at the request of the plugin. You will only be emailed once per release. To disable these emails see the plugin's config.
