I tried to find this answered already to no avail.
I would like to know the daily high temperature at my house as it will be used to determine how often I water the lawn and garden. I cannot find an easy way to get this value short of creating a scheduled event that polls the temperature every ~30 minutes or so to set the high temperature. I don't see this state available from the Weathersnoop plugin, nor do I see it in Weathersnoop's "Weather Properties," but WS does track this information within the application as a marker on the graphical thermometer. Would it need to be among WS's Weather Properties to be available to the plugin's states?
Getting Daily High Temperature from Weathersnoop
Forum rules
Re: Getting Daily High Temperature from Weathersnoop
I wrote a high/low AppleScript function for the wunderground script that does what I think you are looking for. You can probably adapt this to run in a trigger that fires each time the temp changes.
First, you need to create these Indigo variables...
Finally, I call the function like this...
Oh, and don't forget to have a scheduled action to reset the high/low variables just after midnight each night. An embedded AppleScript something like the following should do the trick...
When this is all working, Last_High_Temp, Last_High_Time, Last_Low_Temp & Last_Low_Time will record the previous day's high/low temp data. The "local_" variables are tracking the current day's data.
- Last_High_Time
Last_High_Temp
Last_Low_Time
Last_Low_Temp
Local_High_Time
Local_High_Temp
Local_Low_Time
Local_Low_Temp
on SetHighLow(currentTemp, thedate)
iset thedate to thedate as text
set theTime to word 6 of thedate & ":" & word 7 of thedate & " " & word 8 of thedate
-- First, check if we have a new high
set oldHigh to the value of variable "Local_High_Temp" as real
if oldHigh is equal to "" then set oldHigh to 0 as real
if currentTemp is greater than oldHigh then
set the value of variable "Local_High_Temp" to temp_f
set the value of variable "Local_High_Time" to theTime
end if
-- And now, check if we have a new high
set oldLow to the value of variable "Local_Low_Temp" as real
if oldLow is equal to "" or oldLow is equal to 0 then set oldLow to 100 as real
if currentTemp is less than oldLow then
set the value of variable "Local_Low_Temp" to temp_f
set the value of variable "Local_Low_Time" to theTime
end if
end tell
end SetHighLowCode: Select all
set observation_time to do shell script "date"
set currentTemp to temp_f as number
SetHighLow(currentTemp, observation_time)Code: Select all
set the value of variable "Last_High_Temp" to the value of variable "Local_High_Temp"
set the value of variable "Last_High_Time" to the value of variable "Local_High_Time"
set the value of variable "Last_Low_Temp" to the value of variable "Local_Low_Temp"
set the value of variable "Last_Low_Time" to the value of variable "Local_Low_Time"
set the value of variable "Local_High_Temp" to 0
set the value of variable "Local_Low_Temp" to 100
set the value of variable "Local_High_Time" to "12:01 AM"
set the value of variable "Local_Low_Time" to "12:01 AM"Re: Getting Daily High Temperature from Weathersnoop
Thank you, berkinet, for the great reply. I forgot I had those HiLo variables in my variables list and had to do a little digging to see what was setting them as they hadn't been updated in quite a while. It turns out I lacked the scheduled event to reset those variables at the start of each new day, so they were holding old HiLo values.
To make use of them, I wrote this script to be run each night at 11:50:
I set up the variables in Indigo so that I can easily change the temperature threshold and the nominal watering interval, even from Indigo Touch. The scheduled event that runs the drip irrigation is called daily, but only runs if two variables are true, runDripToday (set by this script) and enableSprinklers, which is a global variable I use in all my sprinkler schedules so I can toggle them with a single variable. I run the drip every three days (dripDayInterval = 3) in the early morning, but will run it if the previous day exceeded the dripTemperature, regardless how many days have passed since the last watering.
from datetime import date
# Indigo Variables
runDripToday = indigo.variables[542358241] # Set to true if the drip should run today
dripDayInterval = indigo.variables[1228875068] # Nominal watering period in days
todaysHighTemp = indigo.variables[53056838] # The high temperature of the day in degreesF
dripTemperature = indigo.variables[1965665196] # Above this temperature, the drip should run
# Reset runDripToday variable
indigo.variable.updateValue(runDripToday, "false")
# Grab today's date and convert it to a day count
today = date.today()
dayNumber = date.toordinal(today)
# Ensure dripDayInterval is an integer
interval = int(dripDayInterval.value, base=10)
# Set runDripToday to true if the daily high temperature exceeded the threshold set
# by dripTemperature, or if the number of days set by dripDayInterval has passed.
if ((dayNumber % interval == 0) or (todaysHighTemp.value >= dripTemperature.value)):
indigo.variable.updateValue(runDripToday, "true")
indigo.server.log("runDripToday Enabled")
indigo.server.log("runDripToday Disabled")
