The discussion seems to be closed, but here one more question:
I have several pairs of dimmers combined (responder and controller).
Deleted all variables for each of the second dimmers.
Still using the triggers for the 2. dimmer, but calling the applescript function with the main dimmer name. That should avoid double or wrong counting. Is that correct?
Also I have 2 thermostats ( out of 4 ) that run against one AC/Heater for one room each - one upstairs and one downstairs. Both can start the AC and are opening and closing valves for the individual rooms. Any suggestion how to handle that, should be he same as for the dimmers?
thx,
great app
eTrack
Re: eTrack applescript error if no iMeter variable defined
Added the following to the code in the "on trackEnergyReset()" (indicated with -- added)
If there is no eTrackiMeter_ .. defined in Indigo, apple script stops with error message that variable iMeterVars is not defined. Added test to verify that variable exists.
Thx
Thx
This primary handler resets all eTrackCost*, eTrackTotalCost, eTrackKWH*,
eTrackTotalKWH, and eTrackGrandTotal* Indigo variables to zero. This will also
send the raw INSTEON command to all tracked iMeter Solos devices to reset it's
internal accumulated energy total to zero.
Expects: nothing
Returns: true
-- Reset tracked iMeter Solo devices
set iMeterVars to every variable whose name begins with "eTrackiMeter_"
-- check if any variable is set
set iMexists to "true" -- added
try -- added
iMeterVars -- check if this works, then there is something in the variable, Indigo makes this variable undefined if there is no hit.
on error -- added
set iMexists to "false" -- added
end try -- added
if iMexists = "true" then -- yes variables are set, continue -- added
repeat with thisVar in iMeterVars
set thisiMeter to value of thisVar
set theAddress to address of device thisiMeter
send insteon raw cmd1 128 cmd2 0 to address theAddress
end repeat
end if --- added
set thisVar to null
Re: eTrack
I'm assuming that those paired dimmers are set up in a 2-way switch configuration where only one dimmer actually provides power to the light while the other dimmer just controls the load-bearing dimmer. Correct? Assuming that's the case, as long as Indigo keeps the "on" condition of the load-bearing dimmer in sync with the non-load bearing dimmer, there's no need to execute the AppleScript function when the non-load-bearing dimmer state changes because the eTrack triggers fire when the state changes, not when INSTEON commands are received.kw123 wrote:Still using the triggers for the 2. dimmer, but calling the applescript function with the main dimmer name. That should avoid double or wrong counting. Is that correct?
This may require a bit of eTrack trigger tweaking. The best way to handle this would probably be to do what you've suggested. Pick one thermostat as a primary one to track with eTrack, then modify the trigger for the second thermostat so that it executes the AppleScript function for the first. Additionally, so that eTrack doesn't double-count energy when both thermostats are on, you'll need to add a condition to the eTrack AC, Fan, Furnace, and Heat On triggers for each thermostat so that if one thermostat is already on, the other thermostat trigger doesn't execute. The same is true for the AC, Fan, Furnace, and Heat Off triggers.kw123 wrote:Also I have 2 thermostats ( out of 4 ) that run against one AC/Heater for one room each - one upstairs and one downstairs. Both can start the AC and are opening and closing valves for the individual rooms. Any suggestion how to handle that, should be he same as for the dimmers?
Thanks for the contribution. Good catch!kw123 wrote:Added the following to the code in the "on trackEnergyReset()" (indicated with -- added)
Thx
on trackEnergyReset() (* ================================================ This primary handler resets all eTrackCost*, eTrackTotalCost, eTrackKWH*, eTrackTotalKWH, and eTrackGrandTotal* Indigo variables to zero. This will also send the raw INSTEON command to all tracked iMeter Solos devices to reset it's internal accumulated energy total to zero. Expects: nothing Returns: true =================================================== *) tell application "IndigoServer" -- Reset tracked iMeter Solo devices set iMeterVars to every variable whose name begins with "eTrackiMeter_" -------- -- check if any variable is set set iMexists to "true" -- added try -- added iMeterVars -- check if this works, then there is something in the variable, Indigo makes this variable undefined if there is no hit. on error -- added set iMexists to "false" -- added end try -- added if iMexists = "true" then -- yes variables are set, continue -- added repeat with thisVar in iMeterVars set thisiMeter to value of thisVar set theAddress to address of device thisiMeter send insteon raw cmd1 128 cmd2 0 to address theAddress end repeat end if --- added set thisVar to null
Re: eTrack
Have added the attached code to the end of the eTrack script file.
It reads out the parameters and writes them to a coma delimited file for use in excel
A scheduled action calls this function and then the reset function 1 minute before midnight.
Result is a file that has all usage data for each day concatenated - one line per device/type (several for a thermostat - fan, heater, ac ..)
It is a completely de-normalized format, can be used in excel pivot tables.
File size is ~2K for 40 devices per day.
The file eTrackout.txt gets put into the $HOME/Documents/ directory
I have not done the iMeter section yet.
Seems to work fine.
Use as you you see fit.
+++ updated the file exist section, did not work properly.
Seems to work fine.
on writefileeTrack()
This primary handler write out all data to file in coma delimted format
Expects: nothing
Returns: true
set rightNow to (current date)
set rightNow to ((month of rightNow) as integer) & "/" & ((day of rightNow) as integer) & "/" & ((year of rightNow) as integer) & " " & time string of rightNow
set rightNow to rightNow as text
set outputfile to "\"$HOME/Documents/etrackout.txt\" "
--create headerline if called first time
set myPath to (path to home folder) as text
set myPath to myPath & "Documents:etrackout.txt"
--create headderline if called first time
tell application "Finder"
if exists myPath then
set create to "no"
else
set create to "yes"
end if
end tell
if create = "yes" then
set outcmd to "echo \"" & "Dev, Date-Time, "
set outcmd to outcmd & "GrandTotalCOST, GrandTotalKWH, GrandTotalTherms, CostPerKWH, CostPerTherm"
set outcmd to outcmd & " ," & "Cost, TotalCost ,TotalTime ,TotalCycles, KWH, TotalKWH, Therms, TotalTherms, ThermsPerHour"
set outcmd to outcmd & " \" >> " & outputfile
do shell script outcmd
end if
(* to be done, dont have the hardware , need to check code which variables get set
try -- added
iMeterVars -- check if this works, then there is something in the variable, Indigo make this variable undefined if there is no hit.
on error -- added
end try -- added
set outcmd to "echo " & "\" " & " VAR " & thisiMeter & "\" >> " & outputfile
end repeat
end if --- added
set outcmd0 to rightNow
set dat to (get value of variable "eTrackGrandTotalCost") as text
set outcmd0 to outcmd0 & ", " & dat
set dat to (get value of variable "eTrackGrandTotalKWH") as text
set outcmd0 to outcmd0 & " ," & dat
set dat to (get value of variable "eTrackGrandTotalTherms") as text
set dat to (get value of variable "eTrackCostPerKWH") as text
set dat to (get value of variable "eTrackCostPerTherm") as text
end tell
-- eTrackCost variables
set costVars to every variable whose name begins with "eTrackCost_"
set ni to number of items in costVars
end tell
set nn to 1
repeat while nn < ni
set w to item nn of costVars
set nam to name of w
set tid to AppleScript's text item delimiters
set AppleScript's text item delimiters to "_"
set devName to (text item 2 of nam) as text
set AppleScript's text item delimiters to tid
set outcmd to "echo " & "\"" & devName & ", " & outcmd0
set dat to "-0"
if variable nam exists then set dat to (get value of variable nam) as text
set outcmd to outcmd & " ," & dat
set dat to "-0"
set nam to "eTrackTotalCost_" & devName
set dat to "-0"
set nam to "eTrackTotalTime_" & devName
set dat to "-0"
set nam to "eTrackTotalCycles_" & devName
set dat to "-0"
set nam to "eTrackKWH_" & devName
set dat to "-0"
set nam to "eTrackTotalKWH_" & devName
set dat to "-0"
set nam to "eTrackTherms_" & devName
set dat to "-0"
set nam to "eTrackTotalTherms_" & devName
set dat to "-0"
set nam to "eTrackThermsPerHour_" & devName
end tell
set outcmd to outcmd & "\" >> " & outputfile
set nn to nn + 1
end repeat
Re: eTrack
there is one mistake in the fix
The "end if" has to go after the set thisVar to null, the "set" should not be executed if the variable does not exis. Does not seem to create a problem though if executed.
set thisVar to null
end if
Re: eTrack
Another great addition Karl. Thanks!
