Autelis Jandy
hamw
Re: Autelis Jandy
Post by hamw »
Wow, that will be great! I tried loading the new plugin and got this error:
  File "plugin.py", line 9, in <module>
<type 'exceptions.SyntaxError'>: ('invalid syntax', ('/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/AutelisJandy.indigoPlugin/Contents/Server Plugin/Autelis.py', 328, 56, '\t\t\twhile KP_HL.find(CLDevName + " " + CLDevState) == -1\n'))
I have some time this afternoon to troubleshoot.
nlagaros
Re: Autelis Jandy
Post by nlagaros »
Had a type in the code. Please download the package again. Wish I had lights in my pool!
hamw wrote:Wow, that will be great! I tried loading the new plugin and got this error:
hamw
Re: Autelis Jandy
Post by hamw »
here's the result...
  Stopping plugin "Autelis Jandy" (pid 26601)
  Autelis Jandy                   Socket: 10.0.1.40:6000 closed succesfully
  Stopped plugin "Autelis Jandy"
  Upgrading plugin "Autelis Jandy" to newer version 1.2.6 (previous version moved to trash)
  Loading plugin "Autelis Jandy 1.2.6"
  Starting plugin "Autelis Jandy 1.2.6" (pid 29056)
  Autelis Jandy Error             Error in plugin execution InitializeMain:
did I get the right copy? looks like the same error.
There's always a story.... Putting in these lights proved more difficult than I imagined...
nlagaros
Re: Autelis Jandy
Post by nlagaros »
I advanced the version to 1.2.7 and fixed yet another typo. Give it one more shot.
hamw
Re: Autelis Jandy
Post by hamw »
Could you reattach to vulture? It is downloading 1.2.6
nlagaros
Re: Autelis Jandy
Post by nlagaros »
Just did and downloaded myself to make sure it was 1.2.7. Hopefully it will work this time.
hamw
Re: Autelis Jandy
Post by hamw »
Got it downloaded, enabled and created some buttons. On button press:
Jun 9, 2013 7:09:24 PM
  Autelis Jandy Error             Error in plugin execution ExecuteAction:
  File "plugin.py", line 111, in actionColorLightsSet
  File "/Library/Application Support/Perceptive Automation/Indigo 6/plugins/AutelisJandy.indigoPlugin/Contents/Server Plugin/Autelis.py", line 325, in actionGeneric
<type 'exceptions.TypeError'>: int() argument must be a string or a number, not 'NoneType'
nlagaros
Re: Autelis Jandy
Post by nlagaros »
Ham - please put the plugin in debug mode and send me the output from the restart of the plugin. Want to make sure you have everything configured properly.
hamw
Re: Autelis Jandy
Post by hamw »
Here we are:
Jun 9, 2013 8:56:40 PM
  Autelis Jandy Debug             Getting Plugin Configuration Settings
  Autelis Jandy Debug             	 Connection Type: Socket
  Autelis Jandy Debug             	 Socket IP:        10.0.1.40
  Autelis Jandy Debug             	 Socket Port:      6000
  Autelis Jandy Debug             	 Enable UDP:       False
  Autelis Jandy Debug             	 UDP Port:         7890
  Autelis Jandy Debug             	 Keypad Updates:   True
  Autelis Jandy Debug             	 AquaPure:         True
  Autelis Jandy Debug             	 VSP 1:            False
  Autelis Jandy Debug             	 VSP 2:            False
  Autelis Jandy Debug             	 VSP 3:            False
  Autelis Jandy Debug             	 VSP 4:            False
  Autelis Jandy Debug             	 ColorLights:      False
  Autelis Jandy Debug             	 Aux Devices:      05
  Autelis Jandy Debug             		 Aux 01:           Aux 1
  Autelis Jandy Debug             		 Aux 02:           Blower
  Autelis Jandy Debug             		 Aux 03:           Color Lights
  Autelis Jandy Debug             		 Aux 04:           Aux 4
  Autelis Jandy Debug             		 Aux 05:           Control Page Toggle
  Autelis Jandy                   Saved Plugin Configuration
  Autelis Jandy Debug             Opening connection....
  Autelis Jandy                   Socket: 10.0.1.40:6000 connected succesfully
  Autelis Jandy Debug             TX: #AUX1?
  Autelis Jandy Debug             TX: #AUX2?
  Autelis Jandy Debug             TX: #AUX3?
  Autelis Jandy Debug             TX: #AUX4?
  Autelis Jandy Debug             TX: #AIRTMP?
  Autelis Jandy Debug             TX: #POOLHT?
  Autelis Jandy Debug             TX: #POOLHT2?
  Autelis Jandy Debug             TX: #POOLSP?
  Autelis Jandy Debug             TX: #POOLSP2?
  Autelis Jandy Debug             TX: #POOLTMP?
  Autelis Jandy Debug             TX: #PUMP?
  Autelis Jandy Debug             TX: #PUMPLO?
  Autelis Jandy Debug             TX: #SPA?
  Autelis Jandy Debug             TX: #SPAHT?
  Autelis Jandy Debug             TX: #SPASP?
  Autelis Jandy Debug             TX: #SPATMP?
  Autelis Jandy Debug             TX: #SOLHT?
  Autelis Jandy Debug             TX: #SOLTMP?
  Autelis Jandy Debug             TX: #OPMODE?
  Autelis Jandy Debug             TX: #WFALL?
  Autelis Jandy Debug             TX: #CLEANR?
  Autelis Jandy Debug             TX: #VBAT?
  Autelis Jandy Debug             TX: #OPTIONS?
  Autelis Jandy Debug             TX: #MODEL?
  Autelis Jandy Debug             TX: #UNITS?
  Autelis Jandy Debug             TX: #KPEN=1
  Autelis Jandy Debug             RX: !00 AUX1=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: AUX1, Value: off
  Autelis Jandy Debug             RX: !00 AUX2=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: AUX2, Value: off
  Autelis Jandy Debug             RX: !00 AUX3=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: AUX3, Value: off
  Autelis Jandy Debug             RX: !00 AUX4=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: AUX4, Value: off
  Autelis Jandy Debug             RX: !00 AIRTMP=79 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: AIRTMP, Value: 79 F
  Autelis Jandy Debug             RX: !00 KEYPAD=JANDY AquaLinkRS,,  06/09/13 SUN  ,    9:04 PM     ,,   POOL 88`F    ,    AIR 78`F    ,                ,,EQUIPMENT ON/OFF,ONETOUCH  ON/OFF,   MENU / HELP  ,9,15,0,15,0,0,1,9
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: JANDY AquaLinkRS
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value:
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: 06/09/13 SUN
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: 9:04 PM
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value:
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: POOL 88°F
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AIR 78°F
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value:
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value:
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: [EQUIPMENT ON/OFF]
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: ONETOUCH  ON/OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_11, Value: MENU / HELP
  Autelis Jandy Debug             KP_HL: EQUIPMENT ON/OFF
  Autelis Jandy Debug             RX: !00 POOLHT=1
  Autelis Jandy Debug             	 Updating Device: Pool, State: POOLHT, Value: enabled
  Autelis Jandy Debug             RX: !00 POOLHT2=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: POOLHT2, Value: off
  Autelis Jandy Debug             RX: !00 POOLSP=88 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: POOLSP, Value: 88 F
  Autelis Jandy Debug             RX: !00 POOLSP2=60 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: POOLSP2, Value: 60 F
  Autelis Jandy Debug             RX: !00 POOLTMP=88 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: POOLTMP, Value: 88 F
  Autelis Jandy Debug             RX: !00 PUMP=1
  Autelis Jandy Debug             	 Updating Device: Pool, State: PUMP, Value: on
  Autelis Jandy Debug             RX: !00 PUMPLO=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: PUMPLO, Value: off
  Autelis Jandy Debug             RX: !00 SPA=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: SPA, Value: off
  Autelis Jandy Debug             RX: !00 SPAHT=1
  Autelis Jandy Debug             	 Updating Device: Pool, State: SPAHT, Value: enabled
  Autelis Jandy Debug             RX: !00 SPASP=93 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: SPASP, Value: 93 F
  Autelis Jandy Debug             RX: !00 SPATMP=86 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: SPATMP, Value: 86 F
  Autelis Jandy Debug             RX: !00 SOLHT=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: SOLHT, Value: off
  Autelis Jandy Debug             RX: !00 SOLTMP=0 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: SOLTMP, Value: 0 F
  Autelis Jandy Debug             RX: !00 OPMODE=AUTO
  Autelis Jandy Debug             	 Updating Device: Pool, State: OPMODE, Value: AUTO
  Autelis Jandy Debug             RX: !00 WFALL=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: WFALL, Value: off
  Autelis Jandy Debug             RX: !00 CLEAN=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: CLEAN, Value: off
  Autelis Jandy Debug             RX: !00 VBAT=900
  Autelis Jandy Debug             	 Updating Device: Pool, State: VBAT, Value: 900
  Autelis Jandy Debug             RX: !00 OPTIONS=1
  Autelis Jandy Debug             	 Updating Device: Pool, State: OPTIONS, Value: 1
  Autelis Jandy Debug             RX: !00 MODEL=6520
  Autelis Jandy Debug             	 Updating Device: Pool, State: MODEL, Value: 6520
  Autelis Jandy Debug             RX: !00 UNITS=F
  Autelis Jandy Debug             	 Updating Device: Pool, State: UNITS, Value: F
  Autelis Jandy Debug             RX: !00 KPEN=1
  Autelis Jandy Debug             RX: !00 KEYPAD=JANDY AquaLinkRS,,  06/09/13 SUN  ,    9:04 PM     ,,   POOL 88`F    ,    AIR 79`F    ,                ,,EQUIPMENT ON/OFF,ONETOUCH  ON/OFF,   MENU / HELP  ,9,15,0,15,0,0,1,9
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AIR 79°F
  Autelis Jandy Debug             RX: !00 KEYPAD=EQUIPMENT STATUS,,  AquaPure 50%  , SALT 2900 PPM  ,  FILTER PUMP   , POOL HEAT ENA  ,  SPA HEAT ENA  ,,,,,,15,15,0,15,0,0,1,9
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: EQUIPMENT STATUS
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: AquaPure 50%
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: SALT 2900 PPM
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: FILTER PUMP
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: POOL HEAT ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: SPA HEAT ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: AP_STATUS, Value: on
  Autelis Jandy Debug             	 Updating Device: Pool, State: AP_SET, Value: 50%
  Autelis Jandy Debug             	 Updating Device: Pool, State: AP_SALT, Value: 2900 PPM
  Received INSTEON                "Thermostat MBR" humidity changed to 42.0
  Autelis Jandy Debug             TX: #AUX5=1
  Autelis Jandy Debug             RX: !00 AUX5=1
  Autelis Jandy Debug             	 Updating Device: Pool, State: AUX5, Value: on
  Autelis Jandy Debug             TX: #KEYPAD=4
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP   ON,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP         OFF,AUX4         OFF,AUX5          ON,AUX6         OFF,AUX7         OFF,   ^^ MORE __,0,15,0,15,0,0,1,9
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: [FILTER PUMP   ON]
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: AUX5          ON
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_11, Value: ↑↑ MORE ↓↓
  Autelis Jandy Debug             KP_HL: FILTER PUMP   ON
  Autelis Jandy Debug             TX: #KEYPAD=2
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP   ON,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5          ON,AUX6         OFF,AUX7         OFF,   ^^ MORE __,0,15,0,15,0,0,1,9
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 AUX3=1
  Autelis Jandy Debug             	 Updating Device: Pool, State: AUX3, Value: on
  Trigger                         Pool Light On/Off sets Pool_Light_Status
nlagaros
Re: Autelis Jandy
Post by nlagaros »
This was helpful. Please go to the plugin configuration box and check the Color Lights option. You will then have to select the AUX device number that corresponds to the one you have connected to that LED. Bear in mind that the name you gave to the AUX device in Indigo must be identical to the label in the AquaLink.
hamw
Re: Autelis Jandy
Post by hamw »
Enabled the lights and renamed Aux 3 to LAMP to correspond with both the Aqualink RS and the Autelis.
Jandy ColorLights Setup LAMP.tiff
Jandy ColorLights Setup LAMP.tiff (211.14 KiB) Viewed 5258 times
Looks like the macro keeps searching; just bypasses "LAMP" in the menu and keeps going.
Put it in debug and here's the log. About halfway down I enabled the lamp and pressed one of the buttons again. Still bypasses the lamp.
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP         OFF,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,3,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [EXTRA AUX    OFF]
  Autelis Jandy Debug             KP_HL: AUX5         OFF
  Autelis Jandy Debug             TX: #KEYPAD=5
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP         OFF,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,4,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [SPA MODE     OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP         OFF,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,5,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [CLEAN MODE   OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,CLEANER      OFF,AIR BLOWER   OFF,LAMP         OFF,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,6,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [ALL OFF         ]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,AIR BLOWER   OFF,LAMP         OFF,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,7,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [FILTER PUMP  OFF]
  Received INSTEON                "Thermostat Main Bedrooms" humidity changed to 34.0
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,LAMP         OFF,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,8,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: LAMP         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [SPA          OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,AUX4         OFF,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,9,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [POOL HEAT    ENA]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,AUX5         OFF,   ^^ MORE __,10,15,13,15,0,10,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [SPA HEAT     ENA]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,   ^^ MORE __,10,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: AUX6         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [CLEANER      OFF]
  Autelis Jandy Debug             KP_HL: CLEANER      OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=AIR BLOWER   OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,   ^^ MORE __,10,15,13,15,0,1,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: AUX7         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [AIR BLOWER   OFF]
  Error                           process (pid 31625) failed to quit after polite request -- forcing it to quit now
  Stopped plugin "Autelis Jandy 1.2.7"
  Starting plugin "Autelis Jandy 1.2.7" (pid 31738)
  Started plugin "Autelis Jandy 1.2.7"
  Autelis Jandy Debug             	 ColorLights:      True
  Autelis Jandy Debug             		 Color Lights Aux Device: 03
  Autelis Jandy Debug             		 Aux 03:           LAMP
  Autelis Jandy Error             Socket: 10.0.1.40:6000 not open to close
  Received INSTEON                "Thermostat MBR" humidity changed to 29.0
  Autelis Jandy Debug             RX: !00 AIRTMP=77 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: AIRTMP, Value: 77 F
  Trigger                         Pool Heater Pool off/enabled/on Set Pool_Heat_Pool_Status for Pool_Heat_Actual_Status
  Autelis Jandy Debug             RX: !00 POOLTMP=87 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: POOLTMP, Value: 87 F
  Autelis Jandy Debug             RX: !00 PUMP=0
  Autelis Jandy Debug             	 Updating Device: Pool, State: PUMP, Value: off
  Trigger                         Pool Heater Spa off/enabled/on sets Pool_Spa_Heat_Status for Pool_Heat_Actual_Status
  Autelis Jandy Debug             RX: !00 KEYPAD=AIR BLOWER   OFF,LAMP          ON,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,   ^^ MORE __,10,15,13,15,0,2,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: EXTRA AUX    OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [LAMP          ON]
  Autelis Jandy Debug             RX: !00 KEYPAD=JANDY AquaLinkRS,,  06/09/13 SUN  ,    10:26 PM    ,,FILTER PUMP OFF ,    AIR 77`F    ,                ,,EQUIPMENT ON/OFF,ONETOUCH  ON/OFF,   MENU / HELP  ,9,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: 10:26 PM
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AIR 77°F
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,0,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: [FILTER PUMP  OFF]
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: AUX5         OFF
  Autelis Jandy Debug             KP_HL: FILTER PUMP  OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,1,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: [SPA          OFF]
  Autelis Jandy Debug             KP_HL: SPA          OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,2,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: [POOL HEAT    ENA]
  Autelis Jandy Debug             KP_HL: POOL HEAT    ENA
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,3,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: [SPA HEAT     ENA]
  Autelis Jandy Debug             KP_HL: SPA HEAT     ENA
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,4,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: [CLEANER      OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,5,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: [AIR BLOWER   OFF]
  Autelis Jandy Debug             KP_HL: AIR BLOWER   OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,6,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: [LAMP          ON]
  Autelis Jandy Debug             KP_HL: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,7,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: [AUX4         OFF]
  Autelis Jandy Debug             KP_HL: AUX4         OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,8,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: [AUX5         OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,9,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: [AUX6         OFF]
  Autelis Jandy Debug             KP_HL: AUX6         OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,0,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [AUX7         OFF]
  Autelis Jandy Debug             KP_HL: AUX7         OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,1,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,2,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,3,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,4,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,5,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,6,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: LAMP          ON
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,7,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,8,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,9,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,AUX7         OFF,   ^^ MORE __,10,15,13,15,0,10,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,0,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,1,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: SPA MODE     OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: LAMP          ON
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [AUX4         OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,2,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: CLEAN MODE   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: LAMP          ON
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [AUX5         OFF]
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,3,0,10
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_00, Value: ALL OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_01, Value: FILTER PUMP  OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: SPA          OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: POOL HEAT    ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_04, Value: SPA HEAT     ENA
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_05, Value: CLEANER      OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AIR BLOWER   OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_07, Value: LAMP          ON
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_08, Value: AUX4         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_09, Value: AUX5         OFF
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_10, Value: [AUX6         OFF]
  Reloading plugin "Autelis Jandy 1.2.7"
  Stopping plugin "Autelis Jandy 1.2.7" (pid 31738)
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,4,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,5,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,6,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,7,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,8,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,9,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,LAMP          ON,   ^^ MORE __,10,15,13,15,0,10,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,0,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,1,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,2,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,3,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,4,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,5,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,6,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,7,0,10
  Schedule                        Hide iTunes iRed TeamViewer Mail
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,8,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,9,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,POOL HEAT    ENA,   ^^ MORE __,10,15,13,15,0,10,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,   ^^ MORE __,10,15,13,15,0,0,0,10
  Autelis Jandy Debug             KP_HL: CLEAN MODE   OFF
  Autelis Jandy Debug             RX: !00 KEYPAD=ALL OFF         ,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,   ^^ MORE __,10,15,13,15,0,1,0,10
  Received INSTEON                "Thermostat Main Bedrooms" humidity changed to 35.0
  Error                           process (pid 31738) failed to quit after polite request -- forcing it to quit now
  Starting plugin "Autelis Jandy 1.2.7" (pid 31744)
  Script                           - Skipping zKids Emily Outlet
  Sent INSTEON                    "DR Chand Master" status request (received: 0)
  Sent INSTEON                    "Garage Apt Steps Upstairs Power" status request (received: 0)
  Autelis Jandy Debug             RX: !00 KEYPAD=ALL OFF         ,FILTER PUMP  OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,   ^^ MORE __,10,15,13,15,0,2,0,10
  Autelis Jandy Debug             Vaidating Plugin Configuration
  Autelis Jandy Debug             	 Validation Succesful
  Autelis Jandy Error             Socket: 10.0.1.40:6000 failed to connect. Please check the plugin configuration.
Jun 9, 2013 10:21:40 PM
  Stopping plugin "Autelis Jandy 1.2.7" (pid 31744)
  Starting plugin "Autelis Jandy 1.2.7" (pid 31760)
  Received INSTEON                "Thermostat MBR" off (button 1)
hamw
Re: Autelis Jandy
Post by hamw »
Here's the log. Turned the lamp on about halfway down.
hamw
Re: Autelis Jandy
Post by hamw »
Here's the log. Lamp is turned on. Tried it with lamp off too; no difference. The macro bypasses the lamp.
nlagaros
Re: Autelis Jandy
Post by nlagaros »
I think I found the logic error. We are getting closer. I posted v1.2.8 on the Wiki.
hamw wrote:Here's the log. Lamp is turned on. Tried it with lamp off too; no difference. The macro bypasses the lamp.
hamw
Re: Autelis Jandy
Post by hamw »
Still searching..... It passes over [LAMP ON] and keeps going. I split the file into the next post as it is too long for one.
Jun 10, 2013 10:34:38 PM
  Autelis Jandy Debug             RX: !00 AIRTMP=75 F
  Autelis Jandy Debug             	 Updating Device: Pool, State: AIRTMP, Value: 75 F
  Autelis Jandy Debug             RX: !00 KEYPAD=JANDY AquaLinkRS,,  06/10/13 MON  ,    10:42 PM    ,,FILTER PUMP OFF ,    AIR 75`F    ,                ,,EQUIPMENT ON/OFF,ONETOUCH  ON/OFF,   MENU / HELP  ,9,15,13,15,0,0,1,9
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_02, Value: 06/10/13 MON
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_03, Value: 10:42 PM
  Autelis Jandy Debug             	 Updating Device: Pool, State: KP_06, Value: AIR 75°F
  Autelis Jandy Debug             RX: !00 KEYPAD=EQUIPMENT STATUS,, POOL HEAT ENA  ,  SPA HEAT ENA  ,,,,,,,,,15,15,13,15,0,0,1,9
******Turned on pool light********
  Autelis Jandy Debug             RX: !00 KEYPAD=EQUIPMENT STATUS,, POOL HEAT ENA  ,  SPA HEAT ENA  ,      LAMP      ,,,,,,,,15,15,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,0,15,13,15,0,0,1,9
  Autelis Jandy Debug             RX: ?01 INVALID COMMAND
  Trigger                         Pool Pump ON TIME
  Action Collection               Pool Pump ON 06-10 22:35
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP   ON,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,0,0,13,15,0,0,1,9
  Trigger                         Pool Pump OFF TIME
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,0,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,1,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,2,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,3,0,13,15,0,0,1,9
  Schedule                        Pool Pump OFF TIME (delayed action)
  Action Collection               Pool Pump OFF 06-10 22:35
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,4,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,5,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,6,0,13,15,0,0,1,9
***********Below it is on [LAMP ON] but does not act**************
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,7,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,8,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,9,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,0,1,9
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,1,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,2,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,3,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,4,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,5,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,6,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,7,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,AUX5         OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,8,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AUX6         OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,9,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,AUX7         OFF,   ^^ MORE __,10,0,13,15,0,10,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,0,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,1,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,2,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,3,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,4,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA          OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,5,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,POOL HEAT    ENA,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,6,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,7,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,8,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,AIR BLOWER   OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,9,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,LAMP          ON,   ^^ MORE __,10,0,13,15,0,10,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=AUX4         OFF,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,0,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,AUX5         OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,1,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AUX6         OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,2,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,AUX7         OFF,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,3,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,EXTRA AUX    OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,4,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,SPA MODE     OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,5,0,10
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,CLEAN MODE   OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,6,0,10
  Action Group                    Plugin Reload Scripts Autelis
  Autelis Jandy Debug             RX: !00 KEYPAD=SPA HEAT     ENA,CLEANER      OFF,AIR BLOWER   OFF,LAMP          ON,AUX4         OFF,AUX5         OFF,AUX6         OFF,ALL OFF         ,FILTER PUMP  OFF,SPA          OFF,POOL HEAT    ENA,   ^^ MORE __,10,0,13,15,0,7,0,10
  Embedded script executor host started
  Reloading plugin "Autelis Jandy 1.2.8"
  Stopping plugin "Autelis Jandy 1.2.8" (pid 41663)
Return to “Autelis Jandy”
