Enabled the lights and renamed Aux 3 to LAMP to correspond with both the Aqualink RS and the Autelis.
- Jandy ColorLights Setup LAMP.tiff (211.14 KiB) Viewed 4665 times
Looks like the macro keeps searching; just bypasses "LAMP" in the menu and keeps going.
Put it in debug and here's the log. About halfway down I enabled the lamp and pressed one of the buttons again. Still bypasses the lamp.
- Code: Select all
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP OFF,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,3,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: LAMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [EXTRA AUX OFF]
Autelis Jandy Debug Updating Device: Pool, State: KP_11, Value: ↑↑ MORE ↓↓
Autelis Jandy Debug KP_HL: AUX5 OFF
Autelis Jandy Debug TX: #KEYPAD=5
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP OFF,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,4,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: LAMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [SPA MODE OFF]
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP OFF,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,5,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: LAMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [CLEAN MODE OFF]
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,CLEANER OFF,AIR BLOWER OFF,LAMP OFF,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,6,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: LAMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [ALL OFF ]
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,AIR BLOWER OFF,LAMP OFF,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,7,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: LAMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [FILTER PUMP OFF]
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 34.0
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,LAMP OFF,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,8,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: LAMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [SPA OFF]
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,AUX4 OFF,AUX5 OFF, ^^ MORE __,10,15,13,15,0,9,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [POOL HEAT ENA]
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,AUX5 OFF, ^^ MORE __,10,15,13,15,0,10,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [SPA HEAT ENA]
Autelis Jandy Debug RX: !00 KEYPAD=AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF, ^^ MORE __,10,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [CLEANER OFF]
Autelis Jandy Debug KP_HL: CLEANER OFF
Autelis Jandy Debug RX: !00 KEYPAD=AIR BLOWER OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF, ^^ MORE __,10,15,13,15,0,1,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: AUX7 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [AIR BLOWER OFF]
Error process (pid 31625) failed to quit after polite request -- forcing it to quit now
Stopped plugin "Autelis Jandy 1.2.7"
Starting plugin "Autelis Jandy 1.2.7" (pid 31738)
Started plugin "Autelis Jandy 1.2.7"
Autelis Jandy Debug Getting Plugin Configuration Settings
Autelis Jandy Debug Connection Type: Socket
Autelis Jandy Debug Socket IP: 10.0.1.40
Autelis Jandy Debug Socket Port: 6000
Autelis Jandy Debug Enable UDP: False
Autelis Jandy Debug UDP Port: 7890
Autelis Jandy Debug Keypad Updates: True
Autelis Jandy Debug AquaPure: True
Autelis Jandy Debug VSP 1: False
Autelis Jandy Debug VSP 2: False
Autelis Jandy Debug VSP 3: False
Autelis Jandy Debug VSP 4: False
Autelis Jandy Debug ColorLights: True
Autelis Jandy Debug Color Lights Aux Device: 03
Autelis Jandy Debug Aux Devices: 05
Autelis Jandy Debug Aux 01: Aux 1
Autelis Jandy Debug Aux 02: Blower
Autelis Jandy Debug Aux 03: LAMP
Autelis Jandy Debug Aux 04: Aux 4
Autelis Jandy Debug Aux 05: Control Page Toggle
Autelis Jandy Saved Plugin Configuration
Autelis Jandy Error Socket: 10.0.1.40:6000 not open to close
Autelis Jandy Debug Opening connection....
Autelis Jandy Socket: 10.0.1.40:6000 connected succesfully
Autelis Jandy Debug TX: #AUX1?
Autelis Jandy Debug TX: #AUX2?
Autelis Jandy Debug TX: #AUX3?
Autelis Jandy Debug TX: #AUX4?
Autelis Jandy Debug TX: #AIRTMP?
Autelis Jandy Debug TX: #POOLHT?
Autelis Jandy Debug TX: #POOLHT2?
Autelis Jandy Debug TX: #POOLSP?
Autelis Jandy Debug TX: #POOLSP2?
Autelis Jandy Debug TX: #POOLTMP?
Autelis Jandy Debug TX: #PUMP?
Received INSTEON "Thermostat MBR" humidity changed to 29.0
Autelis Jandy Debug TX: #PUMPLO?
Autelis Jandy Debug TX: #SPA?
Autelis Jandy Debug TX: #SPAHT?
Autelis Jandy Debug TX: #SPASP?
Autelis Jandy Debug TX: #SPATMP?
Autelis Jandy Debug TX: #SOLHT?
Autelis Jandy Debug TX: #SOLTMP?
Autelis Jandy Debug TX: #OPMODE?
Autelis Jandy Debug TX: #WFALL?
Autelis Jandy Debug TX: #CLEANR?
Autelis Jandy Debug TX: #VBAT?
Autelis Jandy Debug TX: #OPTIONS?
Autelis Jandy Debug TX: #MODEL?
Autelis Jandy Debug TX: #UNITS?
Autelis Jandy Debug TX: #KPEN=1
Autelis Jandy Debug RX: !00 AUX1=0
Autelis Jandy Debug Updating Device: Pool, State: AUX1, Value: off
Autelis Jandy Debug RX: !00 AUX2=0
Autelis Jandy Debug Updating Device: Pool, State: AUX2, Value: off
Autelis Jandy Debug RX: !00 AUX3=0
Autelis Jandy Debug Updating Device: Pool, State: AUX3, Value: off
Autelis Jandy Debug RX: !00 AUX4=0
Autelis Jandy Debug Updating Device: Pool, State: AUX4, Value: off
Autelis Jandy Debug RX: !00 AIRTMP=77 F
Autelis Jandy Debug Updating Device: Pool, State: AIRTMP, Value: 77 F
Autelis Jandy Debug RX: !00 POOLHT=1
Autelis Jandy Debug Updating Device: Pool, State: POOLHT, Value: enabled
Trigger Pool Heater Pool off/enabled/on Set Pool_Heat_Pool_Status for Pool_Heat_Actual_Status
Autelis Jandy Debug RX: !00 POOLHT2=0
Autelis Jandy Debug Updating Device: Pool, State: POOLHT2, Value: off
Autelis Jandy Debug RX: !00 POOLSP=88 F
Autelis Jandy Debug Updating Device: Pool, State: POOLSP, Value: 88 F
Autelis Jandy Debug RX: !00 POOLSP2=60 F
Autelis Jandy Debug Updating Device: Pool, State: POOLSP2, Value: 60 F
Autelis Jandy Debug RX: !00 POOLTMP=87 F
Autelis Jandy Debug Updating Device: Pool, State: POOLTMP, Value: 87 F
Autelis Jandy Debug RX: !00 PUMP=0
Autelis Jandy Debug Updating Device: Pool, State: PUMP, Value: off
Autelis Jandy Debug RX: !00 PUMPLO=0
Autelis Jandy Debug Updating Device: Pool, State: PUMPLO, Value: off
Autelis Jandy Debug RX: !00 SPA=0
Autelis Jandy Debug Updating Device: Pool, State: SPA, Value: off
Autelis Jandy Debug RX: !00 SPAHT=1
Autelis Jandy Debug Updating Device: Pool, State: SPAHT, Value: enabled
Trigger Pool Heater Spa off/enabled/on sets Pool_Spa_Heat_Status for Pool_Heat_Actual_Status
Autelis Jandy Debug RX: !00 SPASP=93 F
Autelis Jandy Debug Updating Device: Pool, State: SPASP, Value: 93 F
Autelis Jandy Debug RX: !00 SPATMP=86 F
Autelis Jandy Debug Updating Device: Pool, State: SPATMP, Value: 86 F
Autelis Jandy Debug RX: !00 SOLHT=0
Autelis Jandy Debug Updating Device: Pool, State: SOLHT, Value: off
Autelis Jandy Debug RX: !00 SOLTMP=0 F
Autelis Jandy Debug Updating Device: Pool, State: SOLTMP, Value: 0 F
Autelis Jandy Debug RX: !00 OPMODE=AUTO
Autelis Jandy Debug Updating Device: Pool, State: OPMODE, Value: AUTO
Autelis Jandy Debug RX: !00 WFALL=0
Autelis Jandy Debug Updating Device: Pool, State: WFALL, Value: off
Autelis Jandy Debug RX: !00 CLEAN=0
Autelis Jandy Debug Updating Device: Pool, State: CLEAN, Value: off
Autelis Jandy Debug RX: !00 VBAT=900
Autelis Jandy Debug Updating Device: Pool, State: VBAT, Value: 900
Autelis Jandy Debug RX: !00 OPTIONS=1
Autelis Jandy Debug Updating Device: Pool, State: OPTIONS, Value: 1
Autelis Jandy Debug RX: !00 MODEL=6520
Autelis Jandy Debug Updating Device: Pool, State: MODEL, Value: 6520
Autelis Jandy Debug RX: !00 UNITS=F
Autelis Jandy Debug Updating Device: Pool, State: UNITS, Value: F
Autelis Jandy Debug RX: !00 KPEN=1
Autelis Jandy Debug RX: !00 KEYPAD=AIR BLOWER OFF,LAMP ON,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF, ^^ MORE __,10,15,13,15,0,2,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: EXTRA AUX OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [LAMP ON]
Autelis Jandy Debug RX: !00 AUX3=1
Autelis Jandy Debug Updating Device: Pool, State: AUX3, Value: on
Trigger Pool Light On/Off sets Pool_Light_Status
Autelis Jandy Debug TX: #KEYPAD=2
Autelis Jandy Debug RX: !00 KEYPAD=JANDY AquaLinkRS,, 06/09/13 SUN , 10:26 PM ,,FILTER PUMP OFF , AIR 77`F , ,,EQUIPMENT ON/OFF,ONETOUCH ON/OFF, MENU / HELP ,9,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: JANDY AquaLinkRS
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: 06/09/13 SUN
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: 10:26 PM
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: AIR 77°F
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: [EQUIPMENT ON/OFF]
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: ONETOUCH ON/OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_11, Value: MENU / HELP
Autelis Jandy Debug KP_HL: EQUIPMENT ON/OFF
Autelis Jandy Debug TX: #KEYPAD=4
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,0,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: [FILTER PUMP OFF]
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: LAMP ON
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: AUX6 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: AUX7 OFF
Autelis Jandy Debug KP_HL: FILTER PUMP OFF
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,1,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: [SPA OFF]
Autelis Jandy Debug KP_HL: SPA OFF
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,2,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: [POOL HEAT ENA]
Autelis Jandy Debug KP_HL: POOL HEAT ENA
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,3,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: [SPA HEAT ENA]
Autelis Jandy Debug KP_HL: SPA HEAT ENA
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,4,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: [CLEANER OFF]
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,5,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: [AIR BLOWER OFF]
Autelis Jandy Debug KP_HL: AIR BLOWER OFF
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,6,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: [LAMP ON]
Autelis Jandy Debug KP_HL: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,7,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: [AUX4 OFF]
Autelis Jandy Debug KP_HL: AUX4 OFF
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,8,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: [AUX5 OFF]
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,9,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: [AUX6 OFF]
Autelis Jandy Debug KP_HL: AUX6 OFF
Autelis Jandy Debug RX: !00 KEYPAD=FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,0,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [AUX7 OFF]
Autelis Jandy Debug KP_HL: AUX7 OFF
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,1,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,2,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,3,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,4,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,5,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,6,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: LAMP ON
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,7,0,10
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,AUX5 OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,8,0,10
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AUX6 OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,9,0,10
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,AUX7 OFF, ^^ MORE __,10,15,13,15,0,10,0,10
Autelis Jandy Debug RX: !00 KEYPAD=EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,0,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,1,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: SPA MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: LAMP ON
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [AUX4 OFF]
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,2,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: CLEAN MODE OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: LAMP ON
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [AUX5 OFF]
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,3,0,10
Autelis Jandy Debug Updating Device: Pool, State: KP_00, Value: ALL OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_01, Value: FILTER PUMP OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_02, Value: SPA OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_03, Value: POOL HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_04, Value: SPA HEAT ENA
Autelis Jandy Debug Updating Device: Pool, State: KP_05, Value: CLEANER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_06, Value: AIR BLOWER OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_07, Value: LAMP ON
Autelis Jandy Debug Updating Device: Pool, State: KP_08, Value: AUX4 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_09, Value: AUX5 OFF
Autelis Jandy Debug Updating Device: Pool, State: KP_10, Value: [AUX6 OFF]
Reloading plugin "Autelis Jandy 1.2.7"
Stopping plugin "Autelis Jandy 1.2.7" (pid 31738)
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,4,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,5,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,POOL HEAT ENA,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,6,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,7,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,CLEANER OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,8,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,AIR BLOWER OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,9,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,LAMP ON, ^^ MORE __,10,15,13,15,0,10,0,10
Autelis Jandy Debug RX: !00 KEYPAD=AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,0,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,1,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,2,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,3,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,4,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,SPA MODE OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,5,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,CLEAN MODE OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,6,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,ALL OFF ,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,7,0,10
Schedule Hide iTunes iRed TeamViewer Mail
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,FILTER PUMP OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,8,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,9,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,POOL HEAT ENA, ^^ MORE __,10,15,13,15,0,10,0,10
Autelis Jandy Debug RX: !00 KEYPAD=SPA HEAT ENA,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF, ^^ MORE __,10,15,13,15,0,0,0,10
Autelis Jandy Debug KP_HL: CLEAN MODE OFF
Autelis Jandy Debug RX: !00 KEYPAD=ALL OFF ,CLEANER OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF, ^^ MORE __,10,15,13,15,0,1,0,10
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 35.0
Error process (pid 31738) failed to quit after polite request -- forcing it to quit now
Starting plugin "Autelis Jandy 1.2.7" (pid 31744)
Script - Skipping zKids Emily Outlet
Sent INSTEON "DR Chand Master" status request (received: 0)
Sent INSTEON "Garage Apt Steps Upstairs Power" status request (received: 0)
Autelis Jandy Debug RX: !00 KEYPAD=ALL OFF ,FILTER PUMP OFF,AIR BLOWER OFF,LAMP ON,AUX4 OFF,AUX5 OFF,AUX6 OFF,AUX7 OFF,EXTRA AUX OFF,SPA MODE OFF,CLEAN MODE OFF, ^^ MORE __,10,15,13,15,0,2,0,10
Autelis Jandy Debug Vaidating Plugin Configuration
Autelis Jandy Debug Validation Succesful
Autelis Jandy Socket: 10.0.1.40:6000 closed succesfully
Autelis Jandy Error Socket: 10.0.1.40:6000 failed to connect. Please check the plugin configuration.
Jun 9, 2013 10:21:40 PM
Stopping plugin "Autelis Jandy 1.2.7" (pid 31744)
Starting plugin "Autelis Jandy 1.2.7" (pid 31760)
Received INSTEON "Thermostat MBR" off (button 1)
