Tado Thermostat Device Plugin
durosity
Re: Tado Thermostat Device Plugin
Post by durosity »
Londonmark wrote:Finally Tado now talks to HomeKit but the ability to control is limited. All you can do is invoke manual control and set a temp. Kind of defeats the object as you really want to be able to change the automatic home and away temps but I can see that’s complex.
To me this makes sense.. in effect you’re using homekit to enable the manual override. In use I suspect I’ll keep all of mine in manual mode and just use indigo to set the setpoints in exactly the same way I do with my old Stella-Z setup!
Colorado4Wheeler
Post by Colorado4Wheeler »
I'm probably going to start with zone 0 (likely zone 1 to you) first and work on giving full control, then rolling the rest out is just incrementing what I have already written. So if I can give zone 0 everything and it works great then we can expect that for subsequent zones.
durosity
Post by durosity »
Excellento! Looking forward to it!
Londonmark
Post by Londonmark »
durosity wrote:Excellento! Looking forward to it!
Likewise
durosity
Post by durosity »
Oh and sorry just to add about the AC.. they do have a module for AC but I don’t presently have an air conditioning unit so rather useless to me, though I do intend to get one perhaps next year.
Londonmark
Not sure why you wouldn’t set temps in auto mode and only have the heating on when someone is actually in the house...
durosity
Post by durosity »
That’s what I do with my current system.. it’s mostly based off of triggers from the alarm system and states of play. I’m gonna play with the settings once I get it all fixed in place but I suspect my usage is more complex than what the tado system can handle itself (eg not turning on heating in certain rooms at all as they’re seldom used.. so only come on if I either manually tell it to do so or if the door opens, etc)
Londonmark
durosity wrote:That’s what I do with my current system.. it’s mostly based off of triggers from the alarm system and states of play. I’m gonna play with the settings once I get it all fixed in place but I suspect my usage is more complex than what the tado system can handle itself (eg not turning on heating in certain rooms at all as they’re seldom used.. so only come on if I either manually tell it to do so or if the door opens, etc)
Appreciate we all try doing complex stuff! You may be able to get away with automatic for commonly used rooms and manual for others. I currently use ifttt to switch from auto to manual in the event that someone without the tado app on their phone is home. Motion sensors spot that and then start a two hour timer.
durosity
Post by durosity »
Yeah I think having had it installed for a few days now it’s going to be a combination of manual over rides and schedules from the tado app.
So far it’s quite a nice system. Had a few odd issues like the hot water extension kit also turning on the downstairs heating circuit which they’re currently investigating.. and occasionally a TRV will not respond to a homekit request.. and indeed the lead time on it responding is a bit weird, sometimes immediately and sometimes upto 1 min.. I have a feeling I might not use their built in HB support and just feed it through homekit bridge once C4W has this tado plugin up and running... but we’ll see..
Londonmark
durosity wrote:Yeah I think having had it installed for a few days now it’s going to be a combination of manual over rides and schedules from the tado app.
Me too. We just need that plugin... ;-)
durosity
Post by durosity »
We do! If only C4W wasn’t so damn lazy
DaveL17
Post by DaveL17 »
I am just popping in to say that I'm tired of seeing Durosity's hand in my feed so I give you a picture of a rabbit with a pancake on its head.
My Plugins and Scripts
durosity
Post by durosity »
Awww.. that’s lovely.. I’m so entertained by it I’m gonna give it a big thumbs up!
agame
Post by agame »
I'm back on deck, so able to provide another TADO login if you need it.
I have 2 thermostats, a radiator valve, and the airconditoner controller.
durosity
Post by durosity »
agame wrote:I'm back on deck, so able to provide another TADO login if you need it.
Out of interest how well does the AC controller work? And what model AC do you have? I was thinking of getting one for the two days a year when it actually gets warm enough for such a thing but finding one with a compatible remote has been difficult!
Also do you have issues with your internet bridge dropping it’s cloud connection constantly? I am and their tech support have been struggling to work out why (and the lack of any user accessible logs is driving me nuts!)
