Better Email Q&A
ChopOMatic
Re: Better Email Q&A
Post by ChopOMatic »
Thx, Joe!
kennybroh
Post by kennybroh »
I have a gmail account I use strictly to send and receive emails used as triggers, such as geofencing notifications that I'm coming home, motion detected by a camera, etc. Triggers check the subject line, and make something happen. Was not happy that wasn't working.
Was having gmail scan authentication errors; installed Better Email and problem solved!
Thanks so much
Be aware that GMail has an issue that it drops the IMAP connection for no apparent reason. Other users are restarting the device on a regular schedule to avoid that.
kennybroh
Post by kennybroh »
But if I'm only checking incoming mail from the pop server that shouldn't be an issue, correct?
kennybroh wrote:But if I'm only checking incoming mail from the pop server that shouldn't be an issue, correct?
No, it's only IMAP server devices using the IDLE option that have the issue. But if you do use IMAP/IDLE, the response time for reacting to an incoming email is seconds, not minutes. What's your poll interval for the POP server?
kennybroh
Post by kennybroh »
1 minute
kennybroh
Post by kennybroh »
For the kinds of things I'm using it for, I have not experienced any significant delay.
MeetKevin
Post by MeetKevin »
Hi everyone,
How can I set a variable as the subject line of the email? I know this plug-in compares to the subject line to determine if a statement is true or false. So I'm wondering if I can use that subject line in a notification like this in Pushover.
E.G. Email comes in. "New Listing: 123 Main Street."
"New Listing" is my trigger phrase.
Then I modify "New Listing: 123 Main Street" as a variable value, which I can then output as a push notification.
Maybe something like:
indigo.variable.updateValue(321275956, "indigo.activePlugin.substitute(pluginAction.props["emailSubject"])"
Thanks so much!
Kevin
Are you trying to do this in a Python script or in an Indigo Action? There's a Server Action named "Insert Device State into Variable". That's what you use to put the subject line into a variable. The device state you want is "messageSubject".
But instead of doing that, just use the BetterEmail device state "messageSubject" for the Pushover notification using the device state substitution, rather than variable substitution.
MeetKevin
Post by MeetKevin »
I was going to put this in an indigo action via the Pushover plugin. I'll try these notes -- Thanks so much!
MeetKevin wrote:I was going to put this in an indigo action via the Pushover plugin. I'll try these notes -- Thanks so much!
If you want to send a Pushover message triggered by an email message, you have to base the trigger on the email device state, then use a Pushover action from there. Maybe that's what you're trying to do already.
MeetKevin
Post by MeetKevin »
Yes that's it. Just need the email subject line to update a variable so I can use that data.
I think your previous will nail that.
MeetKevin wrote:Yes that's it. Just need the email subject line to update a variable so I can use that data.
I'll say it again. If you need the email subject line in an action, you don't need to put it in a variable first.
MeetKevin
Post by MeetKevin »
Ah, see that goes to show that I have no idea what I'm doing. The email device state contains the subject-line information?
MeetKevin wrote:Ah, see that goes to show that I have no idea what I'm doing. The email device state contains the subject-line information?
Exactly. Otherwise, how would you get it into the variable in the first place?
Return to “Better Email”
