Can't Find Hue Hub after Update to Indigo 2024.2.1
randysk
Re: Can't Find Hue Hub after Update to Indigo 2024.2.1
Post by randysk »
Karl,
OK. Terminal is set with full disk access.
Randy
I shall publish an update that covers network failures a little more explicit:
Ie when the network is down it will show that ping to the hub is not successful, not just http timeout ….
randysk
Post by randysk »
Karl,
Thanks for your help. It winds up my wifi connection got shut off and that's where my Hue hub is. With the wifi on, everything is working fine.
Thanks again.
Randy
Was fun talking you
the error message in the log will now look like:
   Hue Lights Error                Failed to connect to the Hue bridge at 192.168.1.202 after 4 seconds. - Check that the bridge is connected and turned on. >>>> the hub does not answer ping <<<<
added : >>>> the hub does not answer ping <<<<. to the log
Return to “Hue Lights”
