Inconsistent behaviour
siclark
Re: Inconsistent behaviour
Post by siclark »
Ah yes. It’s 1.6.11. I think the latest?
autolog
Post by autolog »
I think I must have PM'd you that version as the latest on Github Pre-Release is 1.5.0 AFAICS?
I am running an alpha version1.7.2 (in production) at the moment which incorporates code from my Z-Wave_Interpreter plugin as oppose to doing its own thing to interpret the Z-Wave commands coming in from the TRVs and Remotes. I could let you try it BUT you would need to be able to fall-back to your current version if it goes pear-shaped. I haven't had many issues with it but that is not to say you wouldn't flush something out if you tried it.
siclark
Post by siclark »
Ok. Downgraded to current GitHub release and still see same behaviour. It restarted at 20:20. I then adjusted the temp with UI and 2 of the devices went to mode 2 but then straight back to 3 and 4.
siclark
Post by siclark »
Happy to try the alpha version and revert if needed.
autolog
Post by autolog »
Hi Simon,
siclark wrote:Happy to try the alpha version and revert if needed.
I have PM'd the link to you. :)
Return to “TRV Controller”
