That's very weird. The plugin compiles all the applescript objects on startup. In your case it looks like it's successfully compiling the first 9 objects and choking on the 10th.
My only suggestion at this point is to delete the plugin entirely and reinstall a fresh copy. If that doesn't work, we may need Matt or Jay to help dig into why the applescript compiler inside IndigoPluginHost is failing.
iTunes Local Control and Catalina
Re: iTunes Local Control and Catalina
Ok, I've tried this (plugin disabled/deleted and installed a new copy) and still doesn't work.kmarkley wrote:That's very weird. The plugin compiles all the applescript objects on startup. In your case it looks like it's successfully compiling the first 9 objects and choking on the 10th.
Jun 2021 at 19:40:23
Installing and enabling plugin iTunes Local Control v0.0.8
Loading plugin "iTunes Local Control 0.0.8"
Starting plugin "iTunes Local Control 0.0.8" (pid 60191)
iTunes Local Control Error Error in plugin execution InitializeMain:
File "plugin.py", line 12, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/iTunes Local Control.indigoPlugin/Contents/Server Plugin/iTunesAppleScript.py", line 96, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/iTunes Local Control.indigoPlugin/Contents/Server Plugin/iTunesAppleScript.py", line 23, in _make
File "/Library/Application Support/Perceptive Automation/Indigo 7.5/IndigoPluginHost.app/Contents/Resources/PlugIns/applescript/__init__.py", line 49, in __init__
ScriptError: Expected end of line, etc. but found identifier. (-2741) range=78-83
Stopping plugin "iTunes Local Control 0.0.8" (pid 60191)
Stopped plugin "iTunes Local Control 0.0.8"
- jay (support)
- Site Admin
- Contact:
We're using a library, so I don't know for sure what's going on. I wonder if there's something odd in the names of stuff that might be causing an error? I don't recall how the plugin works but if it's just failing on one instance then I'd suspect that something is odd about that instance.
It's working for other users, so it must be something peculiar to this one system, I should think.
Based on the line numbers, the source sent to applescript.AppleScript() should be:
I can add some debug logging for yassi to confirm that it's successfully compiling the previous applescript objects and failing on the one above. But beyond that, I haven't a clue.
It'll be a day or two to get it posted.
on run(args)
tell application "iTunes" -- or "Music" depending on OS version
next track
end tell
end run
FWIW, I am seeing the same error message:
Jun 6, 2021 at 3:43:42 PM
Indigo Cocoa client authenticated (192.168.0.4)
Reloading plugin "iTunes Local Control 0.0.8"
Starting plugin "iTunes Local Control 0.0.8" (pid 6018)
Stopping plugin "iTunes Local Control 0.0.8" (pid 6018)
I believe the problem is this version check:
I am on Catalina 10.15.7 using the Music.app. The plugin loads fine if I hard code AS_TARGET_NAME to "Music". I suspect the check works fine in Big Sur as well.
mac_base_ver = int(os.popen("sw_vers -productVersion").read().strip().split(".")[0])
if mac_base_ver > 10:
AS_TARGET_NAME = "Music"
AS_TARGET_NAME = "iTunes"
So the version check should be this instead?:
I have a High Sierra machine and a Big Sur machine and had check the internet for which OS version switched to Music.app. Not surprised if I got it wrong by one.
Could you test this change and confirm? Thanks.
if mac_base_ver >= 10:
AS_TARGET_NAME = "iTunes"Could you test this change and confirm? Thanks.
Where do I have to change this? Which file?
