Won't this block my graphing it if the Thermostat and Setpoint are not in the poll?autolog wrote:Good morning
This is a useful bit of testing, can check that your Spirit device settings are setup as follows: I suspect what is happening is that when the Spirit returns the Setpoint (which isn't needed by the plugin), the plugin can't tell whether that is the result of a poll or whether a physical button has been pressed. I suspect that is why it is showing it as being in TRV Hardware Mode.
Also, On the first Spirit fw 0.15 if I set the Poll Device to Only When Activity is detected I stop getting TRV Temperature.
The one with 0.16 don't have this problem.
