Tado Thermostat Device Plugin
- Colorado4Wheeler
Re: Support For Fibro RGBWW controller
Then the API broke again. This is what happened when. you have a hacked API, back to square one again and that is why this takes so long, I don't have the time to keep chasing a moving target every time the API breaks.
- durosity
Sure you do! 24/7 monitoring of it.. the second it changes your SLA guarantees a fix in 5 mins or we all get a free pizza from you!Colorado4Wheeler wrote:I don't have the time to keep chasing a moving target every time the API breaks.
In all seriousness though does that mean you’re not going to be able to do it? Just if that’s the case I’ll need to flog the stuff I’ve got and replace it with something that will work before we start getting into winter
- Colorado4Wheeler
I have to see how bad it is broken. I've had to rewrite the alpha four times now I believe.
- durosity
Ouch! Well I’d appreciate if you could keep me posted.. replacing it will take time and the wife won’t be happy with me!
- Colorado4Wheeler
I still want to get it updated but it's frustrating to spend all this time on something to have it change and I don't even have the hardware to test with and that makes it much more difficult.
And, honestly, the regular digs about how long it is taking doesn't motivate me to do this, quite the opposite actually. I wrote the Tado plugin as a nice thing to do and now it's kind of an albatross around my neck. There's probably at least 20-30 hours of work to get it redone, which in my world equates to about $6K to $8K what I would charge clients for my time so it is not a minor project with the new OAuth system Tado put into place that is implemented in a funky way. The first plugin took me a couple hours.
That being said, it's still on the list but not a top priority right now, HKB took a LOT (and I do mean a L O T) of my "Indigo time" to code. In fact it took at lot of non Indigo time too. That eats into the Tado coding time.
- durosity
Re: Tado Thermostat Device Plugin
yeah... its a pain they don't have an official API. They say they'll make one.. sometime.. possibly in the year 3000 when we all live under water.
If it'd help I could send you my upstairs controller and a couple of TRVs and then when finished with them I'd pay for them to be shipped back?
- Colorado4Wheeler
Extremely generous offer but I think the power requirements would be too different for me to utilize them, not to mention I don't have radiant heaters in my house. I just have to hack through the API using the credentials I have and see what happens. The other issue is if I am testing something and set the heat to 350 degrees in the summer while someone is at work then, well, it's going to be a very interesting entry into their home...durosity wrote:If it'd help I could send you my upstairs controller and a couple of TRVs and then when finished with them I'd pay for them to be shipped back?
- jay (support)
- Site Admin
- Contact:
FYI, we include both oauthlib v2.0.2 and requests_oauthlib v0.8.0 with Indigo 7.1+. Those might help in adding the OAuth client stuff.Colorado4Wheeler wrote:OAuth system Tado put into place that is implemented in a funky way.
In OAuth 2.0, when you originally request a token from an OAuth server, you receive both an authorization token and a refresh token. The auth token usually has a relatively short lifespan. You send the auth token in an HTTP_AUTHORIZATION header, and when the auth token expires, then the client uses the refresh token to get a new auth/refresh token pair (and you receive both an auth token and a refresh token). When that auth token expires, you use the refresh token that came with it to get a new token pair. Rinse, repeat.
Of course, they may be implementing OAuth 1.0 (which I have no understanding of) or maybe they've just mussed it up somehow.
- Colorado4Wheeler
It's hybrid. It's standard token/refresh with a twist.jay (support) wrote:Of course, they may be implementing OAuth 1.0
- Colorado4Wheeler
I had it working and they broke it again. It was working pretty well too. It's undocumented so everything I'm going off of was sniffed from an Android client pretty much so if there isn't any new sniffer reports then I'm not sure if they changed the URL or actually made it OAuth 2.0 compliant (without the twist) or what. I can take hours of testing just to try to get to that data.
- durosity
Aye good point I forget about the power. The radiator issue wouldn’t be a problem because I’d have just sent a couple of the connections they actually attach onto and you’d visually be able to tell if they’re on or not.Colorado4Wheeler wrote:Extremely generous offer but I think the power requirements would be too different for me to utilize them, not to mention I don't have radiant heaters in my house. I just have to hack through the API using the credentials I have and see what happens. The other issue is if I am testing something and set the heat to 350 degrees in the summer while someone is at work then, well, it's going to be a very interesting entry into their home...durosity wrote:If it'd help I could send you my upstairs controller and a couple of TRVs and then when finished with them I'd pay for them to be shipped back?
But seriously if it helps I can easily disconnect my upstairs controller and then it doesn’t matter what temperature you set it to no heat is going to be generated by the boiler. So no fear of over heating the house. (And we very seldom use the upstairs heating anyway.. last year it was turned on twice in one single room with the exception of when the system was being serviced)
- Colorado4Wheeler
I might take you up on that. I know that your system is more complex than the account I've been using and I know you got a bunch more Tado equipment recently so it might be better to use your account. I have a couple pressing issues I'm working through on HKB and Device Extensions and then Tado is supposed to be next on my list.durosity wrote:But seriously if it helps I can easily disconnect my upstairs controller
- jay (support)
- Site Admin
- Contact:
He'd also need a European Z-Wave stick since the RF frequency is different than in the US...durosity wrote:But seriously if it helps I can easily disconnect my upstairs controller and then it doesn’t matter what temperature you set it to no heat is going to be generated by the boiler. So no fear of over heating the house. (And we very seldom use the upstairs heating anyway.. last year it was turned on twice in one single room with the exception of when the system was being serviced)
Or not. Duh, not Z-Wave...
- Colorado4Wheeler
Yea, I had meant to mention that as well as I remembered that too.jay (support) wrote:He'd also need a European Z-Wave stick since the RF frequency is different than in the US...
The answer is quite simple. Fly me out to you and I'll bring my laptop and iPad and I'll get this dialed right in for you. I'll even buy you a pint (but I'm not a beer guy so I'll just hit the scotch instead).
- durosity
Hahaha ahh I do love that meme. Interesting factoid: My best friend now lives on the same street that Sean Bean lived on when he was a kid in Sheffield.jay (support) wrote:He'd also need a European Z-Wave stick since the RF frequency is different than in the US...durosity wrote:But seriously if it helps I can easily disconnect my upstairs controller and then it doesn’t matter what temperature you set it to no heat is going to be generated by the boiler. So no fear of over heating the house. (And we very seldom use the upstairs heating anyway.. last year it was turned on twice in one single room with the exception of when the system was being serviced)
Also the Tado system is WiFi connected rather than z-wave. I happen to have a spare internet bridge that works fine with everything but HomeKit so they replaced it and didn’t want the old one back.. so I’d have been able to send that too.
