Foscam Plugin - control/capture Foscam ip camera
Re: Foscam Plugin - control/capture Foscam ip camera
I am still working on it - it is in alpha state at the moment.
It works well enough now to do motion detection with Indigo polling the camera every 5 seconds.
I can pull down an instant snap from the camera and am currently working on the code to be able to scroll through images that have been collected when the motion detection is triggered. I am not using it capture video at the moment as I think that could use up too much space on that camera and it would be difficult to display in Indigo.
It still has rough edges - so not really in in a position to publish a plugin.
When it is a bit tidier I could let you have a copy on a "take it as you see it basis" i.e. I don't want to commit to maintaining it until I have more time available.
Hello, I'm new at this forums but I've been playing around with domestics for a while now.
I am not a programer thus I cannot develop plugins, however I wonder whether it could be possible to include into the Foscan Plugin new states related with the motion detection that will allow to trigger actions. I'm talking about using the Foscam camera as a motion detection sensor.
Many thanks.
Many thanks.
Guillermo.
I can't wait. I upgraded my door cameras to Foscam HD without thinking of what indigo was going to say about it. I miss my door bell snap shots.autolog wrote:I am still working on it - it is in alpha state at the moment.
Bill
My Plugin: My People
Trying to work around the whole HD thing with applescript (how I use to email snapshots to myself). The URL is the snapshot, but it keeps saving a zero KB .jpg .... I swear this use to work. This is what I have.... can someone point out where I'm goofing up?
When I copy and paste that URL into safari, it works.... so I'm stumped.
set {tUrl, dFolder} to {"http://10.0.6.181:8081/cgi-bin/CGIProxy.fcgi/1.jpg&?cmd=snapPicture2&usr=mainuserid&pwd=mypassword ", "~/Desktop/IPCam/"}
set {oAStid, AppleScript's text item delimiters} to {AppleScript's text item delimiters, "/"}
set fName to (last text item of tUrl) as string
set AppleScript's text item delimiters to oAStid
do shell script ("mkdir -p " & dFolder & "; curl -A/--user-agent " & tUrl & " >> " & (dFolder & fName))
set theAttachment1 to POSIX file "/Users/service/Desktop/IPCam/1.jpg"
tell application "Mail"
set newMessage to make new outgoing message with properties {subject:"Motion Received", content:"Attached Image" & return & return}
tell newMessage
set visible to false
set sender to "[email protected]"
make new to recipient at end of to recipients with properties {address:"[email protected]"}
make new attachment with properties {file name:theAttachment1} at after the last paragraph
(* change save to send to send*)
send --<<<<---------------- change save to send to send
end tell
end tell
delay 2
tell application "Finder"
delete folder "IPCam"
end tellBill
Since the code is open source and on github, would you have any problem posting it as a fork off the current released version and seeing if some others of us might be able to assist in some areas? I've got a couple 8000-series cameras, and one 9000 series, and one of the 8000's is starting to act flakey after about 3 years; I'd love to be able to upgrade it, but emailing snaps is an essential feature for me.autolog wrote:I am still working on it - it is in alpha state at the moment.
Thanks for your consideration!
It doesn't bear much relationship to the original code, so I wouldn't be happy to fork it plus it isn't really in a state that I would be happy to publish
However, I will take another look at it and see what I can do with it as I would like to get it finished.
Thanks for the prompt
Just been reading through this topic and it looks great, the only problem i've got is actually getting my cameras live feed to display in control pages, I have 6 Foscam Cameras with a mixture of HD and standard ones, so far I have only managed to get one of the standard def cameras to show up in a control page, I guess this has something to do with a MPEG feed? I looked through Foscam's support threads and the show a way of changing one of the H.264 streams to MPEG but for the life of me I can't get it to work.
All I want to do is show a live feed from my cameras on a control page. At the moment I am not really interested in any other control but I guess that will come after I can get a feed to display,
Any help would be very much appreciated,
Best Regards,
Dave
Best Regards,
Dave
This has been working for me for a while.
Refreshing Image URL
Set Refresh rate to "Continuous" for smooth video <-- uses more bandwidth (I typically use 1 second)
For URL, use the following:
H264 Cameras:
replace "10.0.6.182:8082" with URL of your camera
replace "master" with your username for camera
replace "donkey" with your password for camera
MJPEG Cameras:
replace "10/0/6/122:82" with URL of your camera
H264 Cameras:
http://10.0.6.182:8082/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=master&pwd=donkeyreplace "master" with your username for camera
MJPEG Cameras:
http://10.0.6.122:82/snapshot.cgi?user=master&pwd=donkeyreplace "master" with your username for camera
Bill
well, what can I say? apart from a very BIG Thank you, I have been playing around with this for months and have been getting nowhere, I reach out, get a reply and all is sorted in minutes.....thanks very much indeed,
Cheers,
Dave
Is there any news of a new foscam plugin for the 9000 series.
the41stside
I will second that
- Different Computers
- Contact:
I third it. Confusing name, but my Foscam C1 is apparently a 9000 series as well.
That is sad news that the C1 is not supported either.
I have just added 4 C1 cameras (£29 at Amazon.co.uk right now) to me existing 9000 series bullet cam.
Looks like Ill have to go the Security Spy way rather than the Foscam Plugin Way for now.
Really good idea though
- Contact:
Take a look at EvoCam for those C1s.
It's more processor intensive than SecuritySpy, but WAY cheaper and works great so far with Indigo for me, even including having EvoCam update variables in Indigo based on camera motion/status.
Any updates on the plugin? I got a Foscam R2 HD, which I can pull a snapshot from, but no motion video and can't use PTZ commands with the plugin.
