Ok I've been thinking about this one for a little while. I have a number of the Fibaro RGBW Controllers http://www.vesternet.com/z-wave-fibaro-rgbw-controller around the house providing mood lighting in rooms and my Christmas lights. Although it's a minor problem - I've always struggled with the RGBW Dimmer being set up as five devices Red, Blue, Green, White and Composite. Now I see these as a single device and I'd like to treat them as such. I'd also like to be able to link lights together so that if I change the state or colour of one it changes all the linked LED strips at the same time.
First world problem or not this is the beginning of my solution. This plugin provides some additional functionality for the Fibaro RGBW Controller. I think the code could be easily adapted to work with any RGB system.
Features
When installed this dimmer provides the following functionality:
- Combines together the RGB and Composite channels from a Fibaro RGBW Controller into a single device call Fibaro Combined RGBW Device
Select a colour, from the device settings, using a colour picker rather than numbers
Trigger LED changes based on an event - e.g. It's freezing outside so make the LED Blue
In an action you can select a Fibaro RGBW Controller Manager command to:- Link together LED devices so that they always represent the same state (e.g. colouor, on, off, flash, effect, etc...)
Select a colour for the group from a selection of 100+ preset colours
Switch a group off
Switch a group on (restoring to the previous colour settings)
Unlink LED devices so they no longer effect each other
Manage chains of LED Devices (e.g. LED 1 is linked to LED 2 which is linked to LED 3. Any change in 1, 2 or 3 is reflected in the others in the group)
Manage loops of chains (e.g. LED 1 is linked to LED 2 which in turn is linked to LED 1) safely
Coming in the next release:- Create present effects (flash, fade and change) to use instead of a single colour
Add your own favourite colours to the presets
Link colours to your favourite music tracks (subtle disco anyone?)
Provide a more fancy UI system to allow you to make changes directly (I'm working on how I might do this outside of indigo using the REST API)
Please remember that this is Alpha code and will certainly have a number of annoying bugs still present despite testing
Mike
