Controlpages no display images
g.saldi
Post by g.saldi »
I install DomoPad and it's work fine
I want prepare a dedicated control page for android.
I try select on settings ->control page options->view method-> Native
in this configuration i see the correct screen size,
i set the background color to white, but i see always black, other colors work fine.
But the main problem is this: i never see any Static image and and device state controls as images.
I see the captions but no images.
I change the view-methods to WEB
the background color is ok,
the page size is much smaller than the screen size but if i double click on the screen i see the correct size and also all the images
thanks in advance
RogueProeliator
Re: Controlpages no display images
Post by RogueProeliator »
This is the first report I've heard of this, so it is likely something in your setup or device or something. Let's start with the basics -- what device are you using, what Android version and what version of DomoPad? I'm sure we can get you going.
Adam
g.saldi
Post by g.saldi »
RogueProeliator wrote:This is the first report I've heard of this, so it is likely something in your setup or device or something. Let's start with the basics -- what device are you using, what Android version and what version of DomoPad? I'm sure we can get you going.
Adam
Hi Adam
You are right
This is my configuration:
Mac Mini OSX 10.6.8
Indigo 6.1
DomoPad plugin 0.9.15
DomoPad mobile client 0.9.3 r43
Android 4.2.1 (MIUI 4.8.29)
I don't think that is a Device type problem, i try with a simple static image with some kind of images.
The next week i can try with a more recent Android version.
RogueProeliator
Yeah, I didn't mean the physical device, but rather the flavor of Android or configuration of the device. If you would, go to the settings of the application and set the User-Selected Identifier to perhaps your forum username (located under the Error / Crash Reporting section of settings), then attempt to load the control page. I'll see if any error reports come through for your device.
I know that DomoPad works on 4.2.1, though to be honest I doubt anyone has tried with the MIUI ROM. Still, the first step would be to see if we are crashing or trapping any errors during the image download.
Adam
g.saldi
Post by g.saldi »
ok, i do it, i use my forum name.
I think that the problem can be the MIUI ROM.
it's not the original one.
I flash it a month ago, and i have some problems with others apps.
The next week i re-flash the original ROM and try with it.
g.saldi
Post by g.saldi »
Resolved,!!
With the original ROM all work fine.
g.saldi
Post by g.saldi »
Bad news !!
it worked only the first time now the situation is the same, no images on CP.
RogueProeliator
Have you restricted permissions on the application (I know that some ROMs can do that)? If it works the first time and not subsequent times, it almost sounds like it cannot read from the image cache that it saved -- try clearing the image cache (available via the menu on the Control Page List). Then launching a control page. If it works after clearing the cache, it may be having trouble reading from storage.
g.saldi
Post by g.saldi »
yes it's a cache problem
After clear cache work fine.
thanks
