Foscam Plugin - control/capture Foscam ip camera
kwijibo007
Re: Foscam Plugin for Indigo
Hi All,
I'm looking at purchasing the FI8910W. Can anyone confirm that this model works with the plugin? The link provided, https://github.com/discgolfer1138/indigo-foscam, only mentions that the 9000-aren't supported.
If so, can you recommend the camera... or not?
[MODERATOR NOTE]: Moved to Foscam plugin thread.
captcurrent
Re: Foscam Plugin - control/capture Foscam ip camera
I have several FOSCAM cameras including the F18910W . I use the cynical security spy plugin as I also use Security Spy (an excellent product)
I am still trouble shooting issues regards PTZ by I have great image and all other functionality. Price is right
kwijibo007
Thanks captcurrent. Very helpful. Security Spy looks good but not sure if I need it just yet as this will be my first camera. . Have you also tested the F18910W with the Foscam Plugin?I have several FOSCAM cameras including the F18910W . I use the cynical security spy plugin as I also use Security Spy (an excellent product)
captcurrent
no I haven't I am happy with the Cynical p[plug in and Security Spy
I have been using the FOSCAM plugin for a F18910W camera for about 6 months. Works with no issues.Thanks captcurrent. Very helpful. Security Spy looks good but not sure if I need it just yet as this will be my first camera. . Have you also tested the F18910W with the Foscam Plugin?
I have just purchased a Foscam FI9831W HD Wireless IP Camera and got hold of the Foscam IPCamera CGI User Guide so that I can investigate how to operate it via Indigo.MarcoGT wrote:Is there a plan to support HD cameras?
All,
I downloaded the v1.0.3 plugin and installed it into Indigo just fine , but where's the documentation for configuration and use?
Under Edit Device Settings/Hostname , I entered the IP address of the camera . Do I need a TCP port, or path to a CGI script?
And after this is all configured properly, can I actually access the live MPG feed with Indigo Touch?
If I can't access mpg video, what exactly can I access, and how? ...
thanks in advance
thanks in advance
Indigo 2025.1 w/ Insteon and Z-Wave lights and outlets
Security integration.
Energy monitoring
Energy monitoring
chrismenke
I'm also having problems getting a response out of this plug in. I've tried addressing the cameras by :
http//ip.ip.ip.ip
http://ip.ip.ip.ip/snapshot.cgi?
http://ip.ip.ip.ip/snapshot.cgi?user=admin&pwd=Password
None of these seem to work.
My camera is the Insteon rebrand of a supported Foscam. I can control them from a browser but not via Indigo.
http//ip.ip.ip.ip
The FOSCAM Controller plugin in is just for the CONTROL of the camera interfacing to Indigo. See the About Document what it controls.
It doesn't do the video piece. I purchased the Security Spy application and use the Cynical Security Spy plugin also for this function.
Hope this helps?
Jody
Edited URL
Hope this helps?
Jody
Edited URL
I'm with scs... I can't figure out what I'm supposed to enter in the Configuration dialog. I looked around but could not find any instructions on what to put in the Host or Port settings. I'm assuming that I'll use the Name and Password that I log into the camera app with, but haven't a clue about the other two.
Mike D.
Mike D.
It has been a long time since I initially set up the Foscam Controller plugin. This is the only configuration window I see:jmiked wrote:I'm with scs... I can't figure out what I'm supposed to enter in the Configuration dialog. I looked around but could not find any instructions on what to put in the Host or Port settings. I'm assuming that I'll use the Name and Password that I log into the camera app with, but haven't a clue about the other two.
Mike D.
Is this what you are asking about?
Or this?
Jody
Edit: Added second config window
kwijibo007
Just thought I'd post back my experience with this plugin as I finally purchased a FI8910W. Thanks to captcurrent and cuhouse for your comments.
I'm really happy with it and the $80 camera. I only want/need one camera in the house for when we go away so it's a simple setup. The camera is centrally located so when motion detectors in different locations are activated the plugin pans the camera to that location and emails a picture (and moves back to position).
I have also configured an Indigo trigger to activate/deactivate the internal camera "alarm" function when I arm/disarm my house alarm. It was easy to set up and works well.
Great plugin, discgolfer1138, thanks for sharing it.
This really highlights the awesomeness of Indigo being able to successfully integrate very different technologies together.... IMHO.
OK, finally found both of those windows. I guess the second one is to allow sending of emails, right?
I'll be fiddling with it a bit more this evening.
Mike
Mike
I'm still having a big problem trying to get my Foscam FI8918 camera to work with Indigo. I installed the plugin and configured it. I set a trigger action for a motion detector changing state to send a command to turn off the IR illumination on the camera. Here's the error message I get:
May 1, 2015 11:06:20 PM
Received INSTEON "Motion Sensor - LR" on (button 1)
Trigger Test mot sen foscam
Trigger Motion Sensor LR Incr
Foscam Controller Debug irOff called
Foscam Controller Debug url xmitted: http://10.0.1.84/decoder_control.cgi?us ... command=94
Foscam Controller Error Error in plugin execution ExecuteAction:
File "plugin.py", line 226, in irOff
File "plugin.py", line 67, in xmitToCamera
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 124, in urlopen
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 383, in open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 401, in _open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 361, in _call_chain
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1141, in http_open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1114, in do_open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 950, in getresponse
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 390, in begin
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 354, in _read_status
<class 'httplib.BadStatusLine'>:
Any ideas on what could be going wrong?
Thanks, any news?autolog wrote: have just purchased a Foscam FI9831W HD Wireless IP Camera and got hold of the Foscam IPCamera CGI User Guide so that I can investigate how to operate it via Indigo.
