That means, that if during the night I will put it in "airplane mode", it will be set as "away"...that means, no more "airplane mode" during the night
I will begin to play with it this evening
fingscan Error Error in plugin execution UiValidate:
File "plugin.py", line 719, in validatePrefsConfigUi
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''Code: Select all
fingscan Error Error in plugin execution startup:
File "plugin.py", line 283, in startup
File "plugin.py", line 1065, in cleanUpEvents
<type 'exceptions.NameError'>: global name 'emptyEvent' is not defined
Mar 13, 2015 10:50:43 PM
fingscan FINGSCAN initializedCode: Select all
Mar 13, 2015 10:51:10 PM
fingscan Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 767, in IPdeviceMACnumber19Filter
File "plugin.py", line 784, in IPdeviceMACnumberFilter
<type 'exceptions.AttributeError'>: 'Plugin' object has no attribute 'IPretList'
Mar 13, 2015 10:55:24 PM
fingscan Error ----------------------------------------------------------------------------------
fingscan Error seems that FING is not active - no change in data, restarting fing, seconds since last change: 280.786175013
fingscan FING initialized .. created new data waiting ~ 1 minute for stable operation
fingscan Error fing restarted successfully
