Airfoil update broke the plugin?
This forum is where we've moved the discussions of the original Airfoil plugin that shipped with Indigo 5/6 (and is now open source). You may continue to ask questions in this subforum, just make sure that it's not about the new Airfoil Pro plugin that shipped with Indigo 7 (ask those questions below).
philc
Post by philc »
Just processed an update to Airfoil to v4.8.12...and now Airfoil doesn't work.
Here's what I get in the log:
Enabling plugin "Airfoil 1.1.7"
Starting plugin "Airfoil 1.1.7" (pid 660)
Started plugin "Airfoil 1.1.7"
Airfoil Error Update failed. Check to see if Airfoil is functioning correctly.
Disabling plugin "Airfoil 1.1.7"
Stopping plugin "Airfoil 1.1.7" (pid 660)
Stopped plugin "Airfoil 1.1.7"
That's me starting and stopping the plugin manually, but the log just fills with the update failed message until I disable the plugin.
Sorry to hit you with this on Christmas Eve...all the best guys, and please don't bother to work on this until after Christmas.
jay (support)
Re: Airfoil update broke the plugin?
Post by jay (support) »
I'll take a look at this next week.
juntta
Post by juntta »
Reboot did the trick for me - Airfoil now working as before
philc
Post by philc »
I tried that...no joy
philc
Post by philc »
Here's a debug log of the problem, looks like one of my speakers (Master Bedroom) is all of a sudden a problem:
Airfoil Debug runConcurrentThread: update()
Airfoil Debug update method called
Airfoil Debug update: Airfoil is running
Airfoil Debug update: application sources: [app(u'/Applications/Airfoil.app').application_sources.ID(0), app(u'/Applications/Airfoil.app').application_sources.ID(1), app(u'/Applications/Airfoil.app').application_sources.ID(2)]
Airfoil Debug update: device sources: [app(u'/Applications/Airfoil.app').device_sources.ID(3), app(u'/Applications/Airfoil.app').device_sources.ID(4), app(u'/Applications/Airfoil.app').device_sources.ID(5), app(u'/Applications/Airfoil.app').device_sources.ID(6)]
Airfoil Debug update: system sources: [app(u'/Applications/Airfoil.app').system_sources.ID(7)]
Airfoil Debug update: speakers: [app(u'/Applications/Airfoil.app').speakers.ID(u'com.rogueamoeba.airfoil.LocalSpeaker'), app(u'/Applications/Airfoil.app').speakers.ID(u'EC66D1070C4E@Master Bedroom'), app(u'/Applications/Airfoil.app').speakers.ID(u'C82A1425092D@iMac 2011'), app(u'/Applications/Airfoil.app').speakers.ID(u'F0D1A907B126@DiningRoom'), app(u'/Applications/Airfoil.app').speakers.ID(u'EC66D10702F2@Living room'), app(u'/Applications/Airfoil.app').speakers.ID(u'745E1C2F184A@Pioneer Rcvr'), app(u'/Applications/Airfoil.app').speakers.ID(u'A8206655A06C@MacMini2012')]
Airfoil Debug update: Computer (com.rogueamoeba.airfoil.LocalSpeaker) - Connected: 0
Airfoil Debug update: adding to newKnownSpeakers for id: ID-com.rogueamoeba.airfoil.LocalSpeaker value: (u'Computer', u'disconnected')
Airfoil Debug Update failed with exception:
File "plugin.py", line 459, in update
speakerId = self.airfoil.get(speaker.id)
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/appscript/reference.py", line 498, in __call__
raise CommandError(self, (args, kargs), e, self.AS_appdata)
CommandError: Command failed:
OSERROR: -1728
MESSAGE: Can't get reference.
OFFENDING OBJECT: app(u'/Applications/Airfoil.app').speakers.ID(u'EC66D1070C4E@Master Bedroom')
COMMAND: app(u'/Applications/Airfoil.app').get(app(u'/Applications/Airfoil.app').speakers.ID(u'EC66D1070C4E@Master Bedroom').id)
BenX10
Post by BenX10 »
Same error here... :(
philc
Post by philc »
BTW, I reset the speaker list and now the plugin shows no speakers found in the log.
Jpaction
Post by Jpaction »
Same issue here. The update broke the plugin.
jay (support)
Well, good and bad news: the good news is that it isn't a problem with the plugin. The bad news is that it appears to be a bug in Airfoil. If you try to get a speaker by it's ID in any AppleScript editor:
tell application "Airfoil"
    speaker whose id is "INSERTIDHERE"
end tell
You get an OS error returned (-1728). It seems to work with the local speaker whose ID is "com.rogueamoeba.airfoil.LocalSpeaker", it's just any other speaker that is failing.
I've reported this to Rogue Amoeba and hopefully will hear something back from them in the next day or two.
Dewster35
Post by Dewster35 »
New update for airfoil dropped recently... hopefully this was the fix.
vasisht
Post by vasisht »
No dice for me. This all started when Airfoil updated recently. I'm running the latest version of Airfoil and Instant On.
  Airfoil Debug                   update: device sources: [app(u'/Applications/Airfoil.app').device_sources.ID(3), app(u'/Applications/Airfoil.app').device_sources.ID(4)]
  Airfoil Debug                   update: system sources: [app(u'/Applications/Airfoil.app').system_sources.ID(5)]
  Airfoil Debug                   update: speakers: [app(u'/Applications/Airfoil.app').speakers.ID(u'com.rogueamoeba.airfoil.LocalSpeaker'), app(u'/Applications/Airfoil.app').speakers.ID(u'28CFE97E0F2D@Living Room'), app(u'/Applications/Airfoil.app').speakers.ID(u'D8306233AB5E@Master Bedroom'), app(u'/Applications/Airfoil.app').speakers.ID(u'403CFC020D42@Office')]
		OSERROR: -1728
		OFFENDING OBJECT: app(u'/Applications/Airfoil.app').speakers.ID(u'28CFE97E0F2D@Living Room')
		COMMAND: app(u'/Applications/Airfoil.app').get(app(u'/Applications/Airfoil.app').speakers.ID(u'28CFE97E0F2D@Living Room').id)
richo
Post by richo »
jay (support) wrote:Well, good and bad news: the good news is that it isn't a problem with the plugin. The bad news is that it appears to be a bug in Airfoil. If you try to get a speaker by it's ID in any AppleScript editor:
end tell
Hi Jay, it seems that the following statement works:
	get every speaker whose bonjourName is "INSERTIDHERE" --i.ex. "90840DEB89CE@Speaker" --
end tell
Ryszard
jay (support)
Unfortunately I don't believe it's possible to construct that particular series of apple events using appscript, which is what the plugin uses to communicate from Python to AppleScript. I'm hoping Rogue Amoeba will fix the problem since I'm not sure there's going to be another way to fix the plugin.
vasisht
Post by vasisht »
OK due to my absolute requirement that airfoil work for me at all times, I coded this. Feel free to use/modify this in any way.
I threw this in a file called airfoil.py
It requires the (no longer supported) python library "app script": http://appscript.sourceforge.net
#!/usr/bin/python
from appscript import app
def connectToSpeaker(speaker):
        app(u'Airfoil').speakers[speaker].connect_to()
def disconnectFromSpeaker(speaker):
        app(u'Airfoil').speakers[speaker].disconnect_from()
def connectToAllSpeakers():
        app(u'Airfoil').speakers.connect_to()
def disconnectFromAllSpeakers():
        app(u'Airfoil').speakers.disconnect_from()
usage:
import airfoil
airfoil.connectToSpeaker("Living Room")
airfoil.disconnectFromSpeaker("Master Bedroom") # or whatever your speakers are named
Hopefully the plugin's issues get resolved soon, but this is a decent stop gap.
I'll add more functions to change sources etc as time permits in the next few days. I just leave my input on "System Audio" so I don't need to change sources.
jay (support)
Great news! Rogue Amoeba has found the problem and corrected it in their latest developer release - 4.8.13d1 which can be downloaded here. If they've released 4.8.13 then you should already be covered.
There were actually two issues with this release - one was a bug which they fixed and another is a change in how speaker IDs are constructed. The latter required a change to the plugin, which will be included in the next general release of Indigo (6.0.21). You can download the updated Airfoil plugin v1.1.8 here in the meantime.
Return to “Old Airfoil Discussions”
