INDIGOplotD -- a plot tool for indigo
A Plugin to create Plots from INDIGO data and other sources
Re: INDIGOplotD -- a plot tool for indigo
https://www.dropbox.com/s/r7opappb417g6 ... -2-8-1.zip v 2-8-1
will switch to NO SQL if database not found, should get you out of the no-sql found loop.
fixes:
SQL-Import: if there is sparse data for a device (i.e. no information for a bin) , SQL import took the average of the last bin and filled the next bin with the average of the previous instead of the last available info.
eg: if you head 90% "ON" time but the last value was OFF :1,1,1,1,1,1,1,1,1,0 = 90% , the next bins (if no information is available) where set to 90% instead of 0. That is fixed now.
Improvements:
better SQL import structure that will enable faster imports i.e. if old data was already imported only new data will be requested from SQL. On some smaller MACs with 2-4G memory and with > 2 GB SQL database the import might take several minutes. In the next release that will be reduced significantly. This step is the first intermediate step towards that.
future release (~ 2 weeks) will have:
-Design / create your own data, put it into a variable. or file e.g. (0;1;3|1;2;5|3;5;6|...|9;4;3) (as x;y1;y2|x;y1;y2|..) and INDIGOplotD can use this information to make a plot with 1.2,3,.. lines and nice fonts, texts scales.. Every time the variable / file gets changed/updated the plot will be refreshed.
haavarda
Post by haavarda »
kw123 wrote:1. do you have sql logger enabled?
2. could you switch to "Do not use SQL-Logger" in Configuration at the bottom of the page, see attached screen shot.
3. and if you are on OSX 10.9 could you try using matplot?
indigoplot to indigoplotD does not transfer any data, should be no interference, 2 completely independent plugins.
Once its running, could you go into the test plot and see if there are any lines defined.
thanks
I tried to enable sql logger but it did not help.
After I applied 2 and 3 it stated to work. So I think I am up and running again now. I have no preferences to use GNUplot instead of matplot. Thank you for your help!
Håvard
https://www.dropbox.com/s/q4l59p8tresny ... -3-0-1.zip v 3-0-1
fixes:
smaller issues in rare circumstances fixed
- some more error controls when bad data is entered,
added:
- help text added in the menus if you hover over the fields
- addition to plot time series with data from devices and variables This version supports to plot data from a variable or file:
assume a variable "test2" contains:
#x;distance;direction|1;2;3|2;5;6|5;3;4|8;2;5|10;3;4
can be used to produce a plot (with added smooth options etc ) like:
variable plot-S1.png (6.34 KiB) Viewed 6435 times
You could fill the variable in an applescript or python script or create a file that contains the data to be plotted.
You can set the x-axis description, scale, format etc. and naturally all the option for formatting, smoothing, math etc are available too.
The detailed help is in the attached PDF file in the download.
I have tested this version for some days, naturally not in all the possible combinations.
Devildog0331
Post by Devildog0331 »
Karl,
This is another cool plugin that I'm hoping to take advantage of. However, I'm running into a few problems setting it up. I can't seem to get the plugin to play nice with the SQL Logger (either mode). I was able to get it to behave when I switched the config away from SQL Logger.
If it helps, I'm running 10.9.3 Server. I'm also using Postgres and the db user has full access to the database (via phpPgAdmin for the setup).
While I've tried to figure this out on my own... I deleted the plugin along with all the files in my Documents folder; I even created a new Postgres database called indigo_data just to be sure it wasn't that. The log output below is from a fresh install of the plugin from the UC lib and not dropbox.
I trimmed the misc stuff out of the log and noted what I tried to do as such ****my actions****.
Please advise if I can provide any other info or trouble shooting steps.
Thanks!!
--Richard
****Installed the plugin****
  Jun 17, 2014, 10:02:54 PM
  Installing and enabling plugin "INDIGOplotD" v2.6.1
  Loading plugin "INDIGOplotD 2.6.1"
  Starting plugin "INDIGOplotD 2.6.1" (pid 1894)
  Started plugin "INDIGOplotD 2.6.1"
  INDIGOplotD                     initializing  ... 2-6-1
  INDIGOplotD                     indigo version found: 6
  INDIGOplotD Error               Error in plugin execution startup:
  File "plugin.py", line 317, in startup
  File "plugin.py", line 3368, in getSQLdataDynamic
  File "plugin.py", line 3593, in testSQL
  File "plugin.py", line 3812, in readSQLLoggerPreferences
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'text'
  INDIGOplotD Error               ------------------------------------
  INDIGOplotD Error                not  configured yet, please select menue:  Indigo /plugins/indigoplot/Configure...
****Configuration change from Online to Batch - then saved & reloaded the plugin****
Jun 17, 2014, 10:12:17 PM
  INDIGOplotD                     Updating device/prop from SQL db: no device or variable defined.. skipping update   ...
Jun 17, 2014, 10:12:44 PM
  Reloading plugin "INDIGOplotD 2.6.1"
  Stopping plugin "INDIGOplotD 2.6.1" (pid 1894)
  INDIGOplotD                     stopConcurrentThread  ...
  INDIGOplotD                      main loop stopped
  Stopped plugin "INDIGOplotD 2.6.1"
  Starting plugin "INDIGOplotD 2.6.1" (pid 2419)
  INDIGOplotD                      read file /Users/richard/Documents/INDIGOPlotD/minute.dat lines: 2304
  INDIGOplotD                      read file /Users/richard/Documents/INDIGOPlotD/hour.dat lines: 912
  INDIGOplotD                      read file /Users/richard/Documents/INDIGOPlotD/day.dat lines: 390
  INDIGOplotD                     initializing  ...2
****Configuration change from Batch to Online - then saved & reloaded the plugin****
Jun 17, 2014, 10:13:38 PM
  INDIGOplotD                     initialized
  Z-Wave                          received "Luminance, Porch" sensor update to 7 lux
  Z-Wave                          received "Humidity, Porch" sensor update to 80%
  Z-Wave                          received "Temperature, Porch" sensor update to 78.1 °F
  Stopping plugin "INDIGOplotD 2.6.1" (pid 2419)
  Starting plugin "INDIGOplotD 2.6.1" (pid 2492)
****Configuration changed back to Batch - then saved & reloaded the plugin****
Jun 17, 2014, 10:14:38 PM
  Stopping plugin "INDIGOplotD 2.6.1" (pid 2492)
  Starting plugin "INDIGOplotD 2.6.1" (pid 2539)
****Configured my first data source point****
Jun 17, 2014, 10:25:16 PM
  INDIGOplotD                     sql commands launched  2014-06-17 22:25:16.601770  waiting for SQL tasks to end to read data into INDIGOplotD pid=3068
  INDIGOplotD                     sql commands launched  2014-06-17 22:25:22.852742  waiting for SQL tasks to end to read data into INDIGOplotD pid=3092
  INDIGOplotD                     sql commands launched  2014-06-17 22:25:29.126774  waiting for SQL tasks to end to read data into INDIGOplotD pid=3118
  INDIGOplotD                     sql commands launched  2014-06-17 22:25:35.400252  waiting for SQL tasks to end to read data into INDIGOplotD pid=3142
  INDIGOplotD                     sql commands launched  2014-06-17 22:25:41.672731  waiting for SQL tasks to end to read data into INDIGOplotD pid=3163
(Note the above continues endlessly)
****Created my plot then switched to Online SQL****
INDIGOplotD Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 2705, in runConcurrentThread
  INDIGOplotD Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
****Switched config back to Batch****
Jun 17, 2014, 10:37:22 PM
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:22.683359  waiting for SQL tasks to end to read data into INDIGOplotD pid=5827
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:28.945049  waiting for SQL tasks to end to read data into INDIGOplotD pid=5854
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:35.213480  waiting for SQL tasks to end to read data into INDIGOplotD pid=5878
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:41.490728  waiting for SQL tasks to end to read data into INDIGOplotD pid=5899
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:47.771652  waiting for SQL tasks to end to read data into INDIGOplotD pid=5922
  Stopping plugin "INDIGOplotD 2.6.1" (pid 2539)
  Starting plugin "INDIGOplotD 2.6.1" (pid 5938)
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:51.974984  waiting for SQL tasks to end to read data into INDIGOplotD pid=5948
  INDIGOplotD                     sql commands launched  2014-06-17 22:37:58.367536  waiting for SQL tasks to end to read data into INDIGOplotD pid=5978
  INDIGOplotD                     sql commands launched  2014-06-17 22:38:07.743820  waiting for SQL tasks to end to read data into INDIGOplotD pid=6002
****Switched the config to not use the SQL Logger (appears happy[initialized])****
un 17, 2014, 10:47:44 PM
  Stopping plugin "INDIGOplotD 2.6.1" (pid 5938)
  Starting plugin "INDIGOplotD 2.6.1" (pid 8147)
1. could you try 3.0.1 - see 2 postings before this one.
2. I have never tried to make it work with postgres - and the batch version will NOT work with it.
The dynamic may be, but I don't know. The error message is in the section where the connection to the database gets tested- The error indicates that it is not connecting properly
Also I don't know if you can have both (sql-logger and postgres) running at the same time.
The SQL code was "donated" by Adam (RogueProeliator), Adam, may be you could comment?
If you use it without SQL you will not have any historical data before you start picking devices / states in indigoplotd. It collects its own history. but otherwise its the same.
as for postgres, I would need some time to setup and test. -and I would lose all my sql-logger history .. :-(
code section..
	def readSQLLoggerPreferences(self, prefFilePath):
		configParams = dict()
		preferencesDom = xml.etree.ElementTree.parse(prefFilePath)
		prefRootNode = preferencesDom.getroot()
		databaseTypeStr = prefRootNode.find("databaseType").text
		if databaseTypeStr == "postgresql":
			configParams["dbType"] = indigosql.kDbType_postgres
			configParams["dbName"] = prefRootNode.find("postgresqlDatabase").text
			configParams["serverHost"] = prefRootNode.find("postgresqlHistoryDataost").text
			configParams["sqlUsername"] = prefRootNode.find("postgresqlUser").text
			configParams["sqlPassword"] = prefRootNode.find("postgresqlPassword").text
			configParams["dbType"] = indigosql.kDbType_sqlite
			configParams["dbName"] = prefRootNode.find("sqliteFilePath").text
		return configParams
RogueProeliator
Post by RogueProeliator »
Karl:
I believe your code there is correct for reading the configuration -- it seems to match mine in terms of configuring the database access parameter's dictionary. How are you creating the database connection after that -- do you check similar to:
dbConfig = self.readSQLLoggerPreferences(sqlLoggerPrefPath)
		if dbConfig["dbType"] == indigosql.kDbType_sqlite:
			return indigosql.IndigoSqlite(dbConfig["dbName"], None, self.logMessage, None)
		elif dbConfig["dbType"] == indigosql.kDbType_postgres:
			return indigosql.IndigoPostgresql(dbConfig["serverHost"], dbConfig["sqlUsername"], dbConfig["sqlPassword"], dbConfig["dbName"], None, self.logMessage, None)
			return None
After that, I imagine it should be working fine -- I use and read SQL Logger history from Postgre all the time without any issues. Without knowing your plugin I can't say for sure, but it looks like it is actually making it to sending commands before erroring -- are you able to tell from that log what exactly piece of code/SQL access is bailing?
You'll find that this is a significantly more mature/powerful/full-featured database than SQLlite, so it is somewhat possible you are doing something that SQLlite allows that a fully typed and such database won't. However, for simple selects and what not normally you should be ok.
Adam
Adam,
the error message is in THIS section.
at this line:
Its the first thing that happens -- well before any really query !
Could it be if there are both database files present it stumbles?
Devildog0331
Karl & Adam,
I can gladly remote in and help with any type of changes and I'm not concerned with losing any historical data at this point.
Would it help if I modified something in the code to not do a look up but specified the host, database, UN, PW, etc.?
--Richard
RogueProeliator
That should be:
configParams["serverHost"] = prefRootNode.find("postgresqlHost").text
I missed that on your first posting...
Adam
Somehow in some replace all this must have been mixed up . Will fix later today. My charter internet is down now for > 2 hours.
Devildog0331
Karl - Since you don't have the Postgres database tied to the SQL Logger (and will lose your data), let me see what I can do. Just please know that my knowledge of coding is nowhere near yours! Will advise when possible.
As soon as my internet is back up I can post the fix. Charter is down 6 hours now .. Also TV. The whole area.
Devildog0331
Viola... That did the trick. Changed ("postgresqlHistoryDataost") to ("postgresqlHost") and it appears to be working correctly in ONLINE mode. As you eluded to earlier... Batch mode is a no go (same as before: INDIGOplotD sql commands launched 2014-06-18 14:15:51.306699 waiting for SQL tasks to end to read data into INDIGOplotD pid=49509).
One question left over... Once I started the service, it appeared that no data was being found in the database (no records returned from database, skipping). Is this normal? Trimmed Log below.
Richard
****Mod the plugin.py file as above and started the plugin****
Jun 18, 2014, 2:12:01 PM
  Enabling plugin "INDIGOplotD 2.6.1"
  Starting plugin "INDIGOplotD 2.6.1" (pid 49304)
****Changed the config to online and reloaded the plugin****
Jun 18, 2014, 2:12:56 PM
  Stopping plugin "INDIGOplotD 2.6.1" (pid 49304)
  Starting plugin "INDIGOplotD 2.6.1" (pid 49348)
  INDIGOplotD                     connected to indigo_data as indigo on 127.0.0.1
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.000040 Door, Front / zoneState.faulted/count   ...
  INDIGOplotD                                                          no records returned from database, skipping     ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.058197 Door, Back / zoneState.faulted/count   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.115773 Door, Patio / zoneState.faulted/count   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.172446 Nest Thermostat / temperatureInput1/max   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.234854 Nest Thermostat / temperatureInput1/min   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.234902 Nest Thermostat / temperatureInput1/average   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.234941 Nest Thermostat / humidityInput1/max   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.286450 Nest Thermostat / humidityInput1/min   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.286493 Nest Thermostat / humidityInput1/average   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.286529 Nest Thermostat / setpointCool/average   ...
  INDIGOplotD                     Updating device/prop from SQL db:  0:00:00.343436 Nest Thermostat / hvacCoolerIsOn/average   ...
(The above continues on for all the devices I already had defined in the plugin after getting to work w/o the SQL Logger)
Then that's probably the SQL statement that works for SQL lite but not for postgre...
Internet still down. Need to get a wireless backup.
https://www.dropbox.com/s/wjozhk9kxcdol ... d3-0-2.zip v 3-0-2
fixed the post- greSQL syntax error
will need some help in fixing the sql statement not returning data.
Does anyone know if there is a command prompt version to test sql statements?
Return to “INDIGOplotD”
