INDIGOplotD -- a plot tool for indigo
A Plugin to create Plots from INDIGO data and other sources
The thread is the discussion forum for http://www.perceptiveautomation.com/fil ... php?id=341
The "official" version will always be posted there and intermediate versions for the adventurous user will be posted on DropBox.
Shutter
Re: INDIGOplotD -- a plot tool for indigo
Post by Shutter »
Hi Karl,
I've been playing around with this since yesterday and I have to say thank you - it's pretty slick.
While at first it seemed a bit daunting it was quite easy to get most of the settings sorted out once I started generating plots and moving back and forth between the browser and Indigo - changing a setting and seeing the effect. Granted, I feel I've only touched the surface and haven't yet configured anything as detailed as the examples in the PDF, but so far so good. So far I'm plotting temp for two rooms and the external temp from forecast.io via Cynical Weather. I'd like to think this will come in handy to justify to my other half getting more sensors to show how all this HA is going to save on our energy bills. :D
A couple of things I've noticed so far.
1. Sometimes I'll change a setting, something minor, and the day png doesn't get generated and errors appear in the log. Is there anything I can check to see why?
2. Is there a way to sort the order the data lines key in the top of the plots are displayed. I thought it was creation order but I'm not so sure now.
3. Would it be possible to post a couple more screenshots of your configurations and the results? I tried recreating a right plot, as in your output example, but it looked nothing like it.
Otherwise I'm off to make some more plots. :)
sorry to answer late.. just saw your posting now:
1.
when you have an error message could you post it?
one common mistake is: if you have a fresh plot no line confirmed i.e. configure the line, click save, but forgot to click on confirm, gnuplot will throw an error. I can add a warning message.
2.
in gnuplot it goes left to right first line defined to last line defined
in marplot left lines have 3 keys in one line and the fourth key goes into the next line. same for "right" lines. they go to the right.
3.
: will post some examples.
[url]https://www.dropbox.com/s/3bduyek99owx7u0/INDIGOplotD-2-6-4.zip/url] 2.6.4
fixes:
- math option: lineA/lineB if -- if LineB had 0.0 values MATplot did not work (gnuplot was fine), now a value of 0.0 is used as result
adds:
- when you have a space in the plot name (i.e. filename of the png file), the log file dump of the png filenames now replace spaces with "%20". This makes it easier to copy and paste into control pages - the control page does not like space in filenames.
- font scale factor between resolution 1 and resolution 2: before the font size was the same for the large and the smaller plot. Now you can scale the font size.
formula: font size of resolution 2 = font size of resolution 1 * scale factor.... Sounds much more complicated than it is.
e.g. you have 8 points fonts for the smaller plot; with a scale factor of 1.5 the font size for the larger plot is 12 points
- added warning / check if you defined a plot WITHOUT confirming = creating a line in the plot. It will create an empty plot with no line in it and print a waring line in the log file.
I will update the how- to-PDF and some more examples in the next days.
If I don't hear of any bugs I will post this version next week as a regular version on this web site.
reminder: the dropBox posting are for new releases, once stable the stable version will be posted in the plugin section.
https://www.dropbox.com/s/3bduyek99owx7 ... -2-6-4.zip v 2.6.4
with expanded "how to" PDF
- some more examples
- how to do special characters
- added font scale factor example
fixes:
- left right Y axis in MATplot sometimes did not work properly
- a rare python exception when adding a new device (now checking if device already exists) ..
Shutter
Post by Shutter »
Hi Karl,
Shortly after I posted to the thread I made a change and everything stopped working. So I reset the plugin and started again. That initially appeared to fix the issue and was working for most of the day. I then messed around with the smoothing options, always remembering to click confirm, when the day plot suddenly stopped showing any lines. (I've found that even the lowest smoothing option can make the lines appear inaccurate).
I switched off smoothing yesterday and then this morning the day plot started to display lines. So far so good. I also ran the update yesterday.
Now this morning I decided to create another plot with on/off motion sensor states. Now I'm seeing lots of errors. I've tried setting it up 3 times and I've always made sure to click confirm before moving to the next step. Here are the error logs:
6 May 2014 10:36:50 am
  INDIGOplotD                     command: write the looong path/filenames of plotfiles to logfile for copy and paste
  INDIGOplotD                     IndigoPlot png file names: copy and paste to field <URL:>  below Display: <RefreshingImage URL>
  INDIGOplotD                        file:/Users/simon/Documents/INDIGOPlotD/Home%20Temp.-minute-S1.png
  INDIGOplotD                        file:/Users/simon/Documents/INDIGOPlotD/Home%20Temp.-minute-S2.png
  INDIGOplotD                        file:/Users/simon/Documents/INDIGOPlotD/Home%20Temp.-hour-S1.png
  INDIGOplotD                        file:/Users/simon/Documents/INDIGOPlotD/Home%20Temp.-hour-S2.png
  INDIGOplotD                        file:/Users/simon/Documents/INDIGOPlotD/Home%20Temp.-day-S1.png
  INDIGOplotD                        file:/Users/simon/Documents/INDIGOPlotD/Home%20Temp.-day-S2.png
  INDIGOplotD                     command: write the looong path/filenames of plotfiles to logfile for copy and paste .. done
  INDIGOplotD                     /Users/simon/Documents/INDIGOPlotD/Motion Sensors ON/OFF States-minute-S1.gnu has no lines defined --click CONFIRM before you save the lines and plots
  INDIGOplotD Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 2730, in runConcurrentThread
  File "plugin.py", line 2856, in syncPlotsWithIndigo
  File "plugin.py", line 1188, in setupGNUPlotFiles
  File "plugin.py", line 1193, in createGNUfile
<type 'exceptions.IOError'>: [Errno 2] No such file or directory: u'/Users/simon/Documents/INDIGOPlotD/Motion Sensors ON/OFF States-minute-S1.gnu'
  INDIGOplotD Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  File "plugin.py", line 2649, in runConcurrentThread
<type 'exceptions.IOError'>: (2, 'No such file or directory', u'/Users/simon/Documents/INDIGOPlotD/Motion Sensors ON/OFF States-minute-S1.gnu')
  Smartphone Radar                "Guest iPhone 4" state is now Away.
  Smartphone Radar                All smartphones are now Away.
  Trigger                         All iPhones away set SS to Active
I see the logs display the following error:
But I did click confirm. When I go back into the edit device settings there are no longer any lines in the third step.
Here's a thought - could python be messed up on my Mac? Every plugin I try gives me at least one error at some point. With some I never get past the configure stage and just give up.
could you send one of the gnu plot files to [email protected]
https://www.dropbox.com/s/36zjj9y8wg51l ... -2-7-1.zip version 2.7.1
fixes:
smaller clean-up, i.e. delete test files etc.
added:
electric energy monitoring functionality. See attached image on hoe to use it.
Screen Shot 2014-05-18 at 11.53.11 PM.png (185.63 KiB) Viewed 20894 times
T-Power
Post by T-Power »
Hello Karl,
Thanks for creating the wonderful plugin!
I am setting up an Aeon Labs Aeotec Home Energy Meter 2 Phase DSB09104-ZWUS and need a little help with the fine tuning.
I have your plugin installed and it seems to be working(its doing something :wink: )
Question: how would I set this up to display in a control page with periodic updates?
T.I.A.
Toran
MacMini 2.3 GHz Intel Core i7 16GB DDR3
Indigo Pro 2022.1 macOS Mojave 10.14.6
check if it produces a file "name-of-plot-inute/hour/day.png in the Documents/Indigioplotd directory
double click the file , check if graph ok
check the manual at the bottom, it shows how to include a plot in a control page and how to make it dynamic.
if you have anymore question, please let me know.
haavarda
Post by haavarda »
Hi Karl,
I am seeing some errors when I try to enable INDIGOplotD. Do you think you can help me out?
I have managed to get indigoplot working before. And I have tried to reinstall Xcode gnu plot etc...
I am using the latest version of indigo 6.
This is the error I get in the log:
7.1"
INDIGOplotD initializing ... 2-7-1
INDIGOplotD indigo version found: 6
INDIGOplotD Error Error in plugin execution startup:
File "plugin.py", line 323, in startup
File "plugin.py", line 3027, in syncPlotsWithIndigo
File "plugin.py", line 1198, in setupGNUPlotFiles
<type 'exceptions.ValueError'>: empty string for float()
File "plugin.py", line 2811, in runConcurrentThread
Håvard
https://www.dropbox.com/s/m6hs5ft22yoa9 ... -2-7-2.zip V 2-7-2
haavarda: this version should avoid the error, but it does not fix the underlying problem.
Could you tell me what you did before you got the error? The error comes from the fact that "text size variable is empty, i.e. not a number" .
- did you set the text size to blank? and if so how did you do it?
- any other action, upgrade ...??
haavarda
Post by haavarda »
Hmm I dont think so. I changed from Indigoplot to IndigoplotD.
But in the prosess something might have happened? I can go over my plots again and see
Håvard
haavarda
Post by haavarda »
I tried to remove everything and start over. I have installed Xcode, so I skipped that. But installed the other part. But no luck... this is the output from the log:
Starting plugin "INDIGOplotD 2.7.2" (pid 68082)
Started plugin "INDIGOplotD 2.7.2"
INDIGOplotD initializing ... 2-7-2
INDIGOplotD /Users/Server/Documents/INDIGOPlotD/testplot-minute-S1.gnu has no lines defined --click CONFIRM before you save the lines and plots
INDIGOplotD /Users/Server/Documents/INDIGOPlotD/testplot-hour-S1.gnu has no lines defined --click CONFIRM before you save the lines and plots
INDIGOplotD /Users/Server/Documents/INDIGOPlotD/testplot-day-S1.gnu has no lines defined --click CONFIRM before you save the lines and plots
INDIGOplotD /Users/Server/Documents/INDIGOPlotD/testplot-minute-S2.gnu has no lines defined --click CONFIRM before you save the lines and plots
INDIGOplotD /Users/Server/Documents/INDIGOPlotD/testplot-hour-S2.gnu has no lines defined --click CONFIRM before you save the lines and plots
INDIGOplotD /Users/Server/Documents/INDIGOPlotD/testplot-day-S2.gnu has no lines defined --click CONFIRM before you save the lines and plots
INDIGOplotD read file /Users/Server/Documents/INDIGOPlotD/minute.dat lines: 2304
INDIGOplotD read file /Users/Server/Documents/INDIGOPlotD/hour.dat lines: 912
INDIGOplotD read file /Users/Server/Documents/INDIGOPlotD/day.dat lines: 390
INDIGOplotD wait for SQL logger to finish start up -- before retrieving SQL data
12 Jun 2014 13:46:07
INDIGOplotD sql-logger not enabled
INDIGOplotD initializing ...2
Disabling plugin "INDIGOplotD 2.7.2"
Stopping plugin "INDIGOplotD 2.7.2" (pid 68082)
INDIGOplotD stopConcurrentThread ...
INDIGOplotD main loop stopped
Stopped plugin "INDIGOplotD 2.7.2"
Håvard
1. do you have sql logger enabled?
2. could you switch to "Do not use SQL-Logger" in Configuration at the bottom of the page, see attached screen shot.
3. and if you are on OSX 10.9 could you try using matplot?
indigoplot to indigoplotD does not transfer any data, should be no interference, 2 completely independent plugins.
Once its running, could you go into the test plot and see if there are any lines defined.
thanks
Screen Shot 2014-06-12 at 9.37.29 AM.png (63.24 KiB) Viewed 20568 times
Return to “INDIGOplotD”
