NOAA Weather Plus discussions
jalves
Re: NOAA Weather Plus discussions
Post by jalves »
Never mind. Apparently some combination of those things tried again in the last 10 minutes did the trick. I have no idea what went wrong or how I "fixed" it. :oops:
Jeff
nsheldon
Post by nsheldon »
Hello. Sorry to hear about the trouble.
The NOAA Weather Plus plugin doesn't actually create or update any Indigo variables as a built-in function. If you have variables that are supposed to be updated when NOAA Weather Plus devices change states, there'd need to be triggers in place to do that (almost certainly ones that use the Device State Changed trigger event). You can search the Indigo client for those types of triggers by sorting the trigger list by the Trigger Type column.
jalves
Post by jalves »
After a bit more research, it appears that the server startup item "weather NOAA script" wasn't running properly when I was having difficulty. It now seems to be working correctly.
Jeff
rhanson
Post by rhanson »
So is the plugin working for everyone?
I'm getting this since yesterday (v1.1.15):
NOAA Weather Plus Error         Error in plugin execution runConcurrentThread:
  File "plugin.py", line 246, in runConcurrentThread
  File "plugin.py", line 528, in update
<type 'exceptions.ValueError'>: need more than 1 value to unpack
nsheldon
Post by nsheldon »
That's a new one. Are you getting that more than once? If so, could you turn on debug logging in the plugin configuration and reload the plugin then paste in the log into your reply?
rhanson
Post by rhanson »
Here's what the plugin reports. The raw data from that web call is attached.
Stopped plugin "NOAA Weather Plus 1.1.15"
  Starting plugin "NOAA Weather Plus 1.1.15" (pid 6147)
  NOAA Weather Plus Debug         Initializing Plugin.
  Started plugin "NOAA Weather Plus 1.1.15"
  NOAA Weather Plus Debug         Starting device: Weather (Irvine)
  NOAA Weather Plus Debug         Updating weather for device: Weather (Irvine)
  NOAA Weather Plus Debug         Device Weather (Irvine) using URL http://forecast.weather.gov/MapClick.php?FcstType=dwml&lg=english&lat=00.000&lon=-000.00
  NOAA Weather Plus Debug         Attempt # 1 at downloading and parsing weather data.
  NOAA Weather Plus Debug         Device Weather (Irvine) reading returned weather data.
  NOAA Weather Plus Debug         Device Weather (Irvine) parsing weather XML data.
  NOAA Weather Plus Debug         Device Weather (Irvine) locating "data" elements in XML.
  NOAA Weather Plus Debug         Device Weather (Irvine) found forecast data.
  NOAA Weather Plus Debug         Device Weather (Irvine) found current observation data.
  NOAA Weather Plus Debug         Device Weather (Irvine) looking for observation location coordinate data.
  NOAA Weather Plus Debug         Device Weather (Irvine) found latitude xx.xxxxx, longitude -xxx.xxxxx
  NOAA Weather Plus Debug         Device Weather (Irvine) looking for observation time.
  NOAA Weather Plus Debug         Device Weather (Irvine) observation time listed is "NA."
  NOAA Weather Plus Error         exception in deviceStartComm(Weather (Irvine)): need more than 1 value to unpack
  NOAA Weather Plus Debug         Starting runConcurrentThread.
wx.xml
XML response (by curling the url)
(11.31 KiB) Downloaded 295 times
nsheldon
Post by nsheldon »
Thanks for the additional information. I'll check it out and see what I can find.
nsheldon
Post by nsheldon »
Patch update 1.1.16 released:
(See main NOAA Weather Plus announcement thread for download link).
Changes Since Version 1.1.15
  • Fixed (hopefully) a bug that would cause the plugin to crash if "NA" was specified for the current condition observation time.
rhanson
Post by rhanson »
Not sure if this is due to changes in 1.1.16 or not:
Dec 5, 2013 21:46:17
  NOAA Weather Plus Error         Error in plugin execution ServerReplacedElem:
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 852, in deviceUpdated
  File "plugin.py", line 217, in deviceStartComm
  File "plugin.py", line 1224, in update
<type 'exceptions.UnboundLocalError'>: local variable 'e' referenced before assignment
nsheldon
Post by nsheldon »
Thanks for the report. I'll check it out.
HFTobeason
Post by HFTobeason »
Again, I love this plugin, thank you!
I get a fairly regular error, very often in groups of three, but sometimes two, sometimes alone. This happens every few hours, at least:
  • 2013-12-09 07:16:39 NOAA Weather Plus Error Unknown error getting weather for coordinates 34.0625, -118.502: <urlopen error timed out>
    2013-12-09 07:16:42 NOAA Weather Plus Error Unknown error getting weather for coordinates 34.0625, -118.502: <urlopen error timed out>
    2013-12-09 07:16:45 NOAA Weather Plus Error Unknown error getting weather for coordinates 34.0625, -118.502: <urlopen error timed out>
I recognize that this is probably an issue on the NOAA side, but is there any way to suppress these errors? Or handle them? Because I have Indigo set to email me on errors, I get a LOT of extraneous emails.
Any advice much appreciated.
Thank you.
nsheldon
Post by nsheldon »
I hear ya. I get them too. I'll see what I can do.
Bollar
Post by Bollar »
The NOAA Point Forecast hourly weather graph shows predicted precipitation amounts. Is that something potentially available to NOAA Weather Plus, or via another service?
I'm interested in incorporating this type of data into my evapotranspiration project. Yes, I can figure out some kind of hedge from precipitation probability, but it would be more straightforward to be able to incorporate NOAA's forecast of xx mm of rain in the next 24 hours into the sprinkler cycle calculation.
nsheldon
Post by nsheldon »
If it's the one I'm thinking of, I've seen the point forecast from NOAA. It has a lot of interesting and useful stats and predictions for mostly niche circumstances. I can see the value in adding it to the plugin, but I don't think I'm going to have the time to do that as it would require fairly significant modifications to the code (and list of device states). If you know some Python, you could probably modify the NOAA Weather Plus plugin code for your own purposes though.
Bollar
Post by Bollar »
nsheldon wrote:If it's the one I'm thinking of, I've seen the point forecast from NOAA. It has a lot of interesting and useful stats and predictions for mostly niche circumstances. I can see the value in adding it to the plugin, but I don't think I'm going to have the time to do that as it would require fairly significant modifications to the code (and list of device states). If you know some Python, you could probably modify the NOAA Weather Plus plugin code for your own purposes though.
Yes, I was able to pull the equivalent information from Weather Underground using their API.
