Airfoil and Indigo 6.0.5
This forum is where we've moved the discussions of the original Airfoil plugin that shipped with Indigo 5/6 (and is now open source). You may continue to ask questions in this subforum, just make sure that it's not about the new Airfoil Pro plugin that shipped with Indigo 7 (ask those questions below).
jay (support)
Re: Airfoil and Indigo 6.0.5
Post by jay (support) »
Doesn't matter.
Dewster35
Post by Dewster35 »
jay (support) wrote:Doesn't matter.
Still getting this over and over again:
Airfoil Debug runConcurrentThread: Airfoil isn't running
Not seeing anything else in the event log if that is the only place where you thought I would see changes happening.
jay (support)
You never told me the results of running the AppleScript I posted...
Dewster35
Post by Dewster35 »
That was the result...
jay (support)
So the result of running the script in the Script Editor application was...
Dewster35
Post by Dewster35 »
As I said earlier...
All running the script shows in the event log is the following... which I assume the script is doing nothing.
I'm not sure what other "processes" launching and quitting you were referring to.
jay (support)
That message is from the plugin, not from the AppleScript. When you execute the script in the Script Editor application it will show the results in the Script Editor window (or show an error) - Indigo isn't even in the loop.
jay (support)
Let me explain what I'm trying to determine and maybe what I'm looking for will make more sense. I want to make sure that Airfoil is responding to apple events sent from something else other than the various Indigo components. So if you run that AppleScript from the AppleScript Editor application, the expected result is that it would return a list of available speakers. That's the first test that I'd like you to run - an AppleScript that talks to Airfoil from outside of any Indigo components.
Now, having said that, at least one other user seems to have gotten Airfoil back in a working state by deleting the application completely then reinstalling. So you might give that a try. There appears to be some sandboxing issue with the OS that's sometimes causing apple events (i.e. AppleScripts) to fail between some applications.
Dewster35
Post by Dewster35 »
I see. My problem was that I was firing the script from an action within indigo and watching the event log.
Below is the message I receive from the results window of the editor.
{speaker id "com.rogueamoeba.airfoil.LocalSpeaker" of application "Airfoil", speaker id "7073CBDAEE85" of application "Airfoil", speaker id "A820661225FC" of application "Airfoil", speaker id "001FF303BB86" of application "Airfoil"}
jay (support)
OK - that's the expected reply. Next, create an action group in Indigo with an Execute Script action. Paste in the following script and hit the "Run" button.
tell application "Airfoil"
	set speakerName to name of first speaker
end tell
tell application "IndigoServer" to log speakerName
Anything in the Event Log (ignore any lines that are from the Airfoil Plugin)? Any lines should have the type "Script".
Dewster35
Post by Dewster35 »
Results:
Dec 12, 2013 12:11:53 PM
Error script error: around characters 115 to 130
Error script error: File IndigoServer_d wasn’t found. (-43)
jay (support)
LOL - sorry, I tested it against a debug build. I edited it above (removed the _d) so copy/paste it again.
Dewster35
Post by Dewster35 »
No worries.
 Script                          Computer
jay (support)
Ok. Unfortunately, it basically just means that the appscript library, which is what we use to bridge python to AppleScript, is what's having the issue. Have you tried the suggestion to delete Airfoil completely and reinstall it?
Dewster35
Post by Dewster35 »
I've deleted the airfoil app to the trash. Emptied the trash. Reinstalled airfoil and reset the speaker list from the indigo plugin. The same result is happening. Is there a way to trash the script library as well somehow?
Return to “Old Airfoil Discussions”
