Airfoil: "Application isn’t running"
This forum is where we've moved the discussions of the original Airfoil plugin that shipped with Indigo 5/6 (and is now open source). You may continue to ask questions in this subforum, just make sure that it's not about the new Airfoil Pro plugin that shipped with Indigo 7 (ask those questions below).
stoffergoffer
Post by stoffergoffer »
After updating airfoil to the newest version (4.8.2), the airfoil plugin no longer works. In the log i get "application isn't running".
I read this might be related to indigo 6.05, but i had airfoil working with that version before the update today.
Anyone else encountered this error, any solution yet?
Re: Airfoil: "Application isn’t running"
see the other discussions: install indigo twice that it works again.. its not indigo its mavericks
stoffergoffer
hmm i have now tried to install indigo multiple times, and downgrade to 6.04. but nothing seems to work.
Anybody else having this problem after updating airfoil?
nsheldon
Post by nsheldon »
Have you tried reinstalling Airfoil as well? I don't know if that'll fix the issue but it's worth a try. I have to re-install Indigo almost every time the computer reboots because the OS doesn't think IndigoServer is running when sent AppleEvents via AppleScript. Very frustrating.
jay (support)
Post by jay (support) »
I just upgraded both on my development Mac (Lion) and on my testing MacBook Pro (Mavericks) and both are running fine, no errors. I'd try deleting Airfoil and reinstalling that.
jay (support)
nsheldon wrote:I have to re-install Indigo almost every time the computer reboots because the OS doesn't think IndigoServer is running when sent AppleEvents via AppleScript.
Just quitting the server then restarting it manually (double-clicking on the server app: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoServer.app) doesn't work? That seems to work for some people...
nsheldon
Post by nsheldon »
I haven't tried double-clicking on the IndigoServer app directly. Next time it happens I'll give that a try. Thanks!
stoffergoffer
Well, after reinstalling airfoil my existing actions are working again. But when i try to create a new action it can't find my airfoil speakers.
In the log i now get this error:
Airfoil Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 538, in runConcurrentThread
File "plugin.py", line 488, in update
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xf8' in position 62: ordinal not in range(128)
Airfoil Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
jay (support)
You have a speaker with a name that contains a unicode (non-ascii) character in it. The fix is coming in the next release (6.0.6) but until it drops you can just remove any unicode characters from any speaker name (it appears you have an ø in one).
stoffergoffer
Yes thanks for the support, that solved my problem
Return to “Old Airfoil Discussions”
