iTunes 11.03
This is a legacy forum which is locked for new topics. New topics should be started in one of the other forums under Extending Indigo
Forum rules
rszmetro
iTunes 11.03
Post by rszmetro »
hi,
I upgraded to iTunes 11.03 and my iTunes plugin isn't woking. Says it is for Indigo 6 and I am using Indigo 5. What should I do to fix it?
Rob
Rob Z
jay (support)
Re: iTunes 11.03
Post by jay (support) »
Right - Apple changed how the communication works with iTunes 11. It's been fixed in the Indigo 6 beta.
rszmetro
Re: iTunes 11.03
Post by rszmetro »
Do I need to go to Indigo 6?
Rob Z
jay (support)
Re: iTunes 11.03
We don't have any plans to back port iTunes 11 compatibility to Indigo 5 so if you want to use it with the plugin then yes.
rszmetro
Re: iTunes 11.03
Post by rszmetro »
OK, thanks, I'll do the upgrade.
Rob
Rob Z
rszmetro
Re: iTunes 11.03
Post by rszmetro »
Sorry to be a bother - Smartphone Radar plugin now not working with Indigo 6:
File "plugin.py", line 86, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 428, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 107, in indigoVersionIsAtLeast
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: '0 b8'
Rob Z
rszmetro
Re: iTunes 11.03
Post by rszmetro »
I also seem to have lost the extended NOAA plugin that provided next seven days forecasts.
Rob Z
matt (support)
Re: iTunes 11.03
Post by matt (support) »
Hi Rob,
Re-install the latest versions of those plugins and I believe they will work correctly.
And thanks for the upgrade purchase!
Locked
Return to “Extending Indigo with Plugins and Python”
