Unicode encoding bug
This is a legacy forum which is locked for new topics. New topics should be started in one of the other forums under Extending Indigo
Forum rules
Juju
Post by Juju »
Hello,
One of my plugins was working well since several weeks, and today (or perhaps since I have installed Mountain Lion, I don't know ...) I have an error when I try to create a device :
  File "plugin.py", line 415, in getContractParameters
  File "/Library/Application Support/Perceptive Automation/Indigo 5/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 1063, in openSerial
<type 'exceptions.UnicodeDecodeError'>: 'ascii' codec can't decode byte 0xc3 in position 7: ordinal not in range(128)
After searching in the forum, I read it is an error relating to unicode encoding. But I don't know where to search in my code ... It seems it's in openSerial, really ?
jay (support)
Re: Unicode encoding bug
Post by jay (support) »
It looks like the ownerName parameter you're sending to openSerial contains non-ASCII characters. We should probably handle that better in the plugin base class but to work around it you should make sure that what you're passing in ownerName is ASCII text.
Juju
Post by Juju »
Bingo !
I had some "é" in the name given to openSerial.
I don't understand why it was working before, but OK, problem is solved.
Thanks.
Locked
Return to “Extending Indigo with Plugins and Python”
