Smartphone Radar - Smartphone presence detection (Locked)
Re: Smartphone Radar - Smartphone presence detection (Update
I've updated the plugin with lots more functionality:
- Smartphones are now devices so there is no limit to how many you can monitor.
- Each device has Home, Away, and On Vacation states that can be used to trigger events.
- There are global events that trigger when ALL the phones are Home, Away, or On Vacation.
- Variables can be automatically created and used as conditions for other triggers or schedules.
See the original post for more details.
http://www.perceptiveautomation.com/use ... =19&t=6876
Enjoy
Enjoy
Looks like a great plugin will try it with my Time capsule when i have some time. Thanks for the effort
Works great with the TimeCapsule! I followed lharris9's instructions on the main post for using port 514 and then used the MAC address for each of our iPhones (IP address didn't work).
One question, Smartphone Radar created the AllPhonesAway, Home and Vacation variables, but not individual variables for each iPhone as in the picture. Is it supposed to do that by itself?
Very cool plugin!! Thanks Travis!
Hmmm. Yes the variables should be created automatically. The issue might be because it currently only makes variables when the config is changed or the plugin is started. Try opening the "Configure Smartphone Radar" page and then pressing Save, you don't have to make any changes. That should force the config to update and hopefully the variables will be created.
What debug level are you using on your Time Capsule for the syslog?
Thanks for the update. Glad you like it!
Thanks, hitting "Save" created the missing variables.
I'm using level "5 - Notice." Using MAC address is completely fine by me and means I don't have to remember to configure the router to reserve the DHCP spots when we get new phones, just update the MAC in SmartPhone Radar.
This issue has been fixed in the new version 0.9.1.Smartphone Radar created the AllPhonesAway, Home and Vacation variables, but not individual variables for each iPhone as in the picture. Is it supposed to do that by itself?
I'll add that info to the main post so others will know. Thanks.I'm using level "5 - Notice." Using MAC address is completely fine by me and means I don't have to remember to configure the router to reserve the DHCP spots when we get new phones, just update the MAC in SmartPhone Radar.
AEBS and SmartPhone Radar
I thought I set up logging correctly on my Airport Extreme BS. I uncommented the lines in syslogd and believe I executed the terminal stuff OK.
I have two variables shown in the device box, last seen and state. The other variables were correctly placed in the Variable List.
** Edit ** I repaired permissions and restarted the macmini. Now both phones are registered as "Away", even though mine is currently home and on the network.
After enabling logging on SPR, I get the following lines:
and
Thoughts? Do I need to install XSLT tools? Which version do you recommend?
Smartphone Radar Router Log: <3>Jun 12 11:31:57 Mac-mini osascript[241]: Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:\n /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: mach-o, but wrong architecture
Smartphone Radar Router Log: <5>Jun 12 11:31:57 Mac-mini com.perceptiveautomation.IndigoServer2[194]: 2011-06-12 11:31:57.910 osascript[241:903] Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:
Smartphone Radar Router Log: <5>Jun 12 11:31:57 Mac-mini com.perceptiveautomation.IndigoServer2[194]: /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: mach-o, but wrong architecture
Smartphone Radar Router Log: <5>Jun 12 11:31:57 Mac-mini com.perceptiveautomation.IndigoServer2[194]: osascript: OpenScripting.framework - scripting addition "/Library/ScriptingAdditions/XSLT Tools.osax" declares no loadable handlers.
Smartphone Radar Router Log: <3>Jun 12 11:31:57 Mac-mini osascript[240]: Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:\n /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: mach-o, but wrong architecture
Smartphone Radar Router Log: <5>Jun 12 11:31:57 Mac-mini com.perceptiveautomation.IndigoServer2[194]: 2011-06-12 11:31:57.919 osascript[240:903] Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:
Smartphone Radar Router Log: <5>Jun 12 11:31:57 Mac-mini com.perceptiveautomation.IndigoServer2[194]: Code: Select all
Smartphone Radar Router Log: <5>Jun 12 11:34:08 Mac-mini [0x0-0x29029].com.perceptiveautomation.serialbridge[262]: Ignoring Quickdraw drawing between QDBeginCGContext and QDEndCGContext
Smartphone Radar Router Log: <3>Jun 12 11:34:08 Mac-mini Serial Bridge[262]: Error loading /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: dlopen(/Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools, 262): no suitable image found. Did find:\n /Library/ScriptingAdditions/XSLT Tools.osax/Contents/MacOS/XSLT Tools: mach-o, but wrong architecture
Smartphone Radar Router Log: <5>Jun 12 11:34:08 Mac-mini [0x0-0x29029].com.perceptiveautomation.serialbridge[262]: Serial Bridge: OpenScripting.framework - scripting addition "/Library/ScriptingAdditions/XSLT Tools.osax" declares no loadable handlers.
Smartphone Radar Router Log: <15>Jun 12 11:34:08 Mac-mini /usr/libexec/taskgated[265]: no system signature for unsigned /Applications/Serial Bridge/Serial Bridge.app/Contents/PlugIns/osasubr[264]
Smartphone Radar Router Log: <4>Jun 12 11:34:08 Mac-mini osasubr[264]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/XSLT Tools.osax"
Smartphone Radar Router Log: <15>Jun 12 11:34:09 Mac-mini /usr/libexec/taskgated[265]: no system signature for unsigned /Applications/Serial Bridge/Serial Bridge.app/Contents/PlugIns/osasubr[266]
Smartphone Radar Router Log: <4>Jun 12 11:34:09 Mac-mini osasubr[266]: Initializer-based scripting additions have been deprecated. Please update this addition: "/Library/ScriptingAdditions/XSLT Tools.osax"Re: AEBS and SmartPhone Radar
It doesn't look like you are getting anything from the AirPort Extreme yet.
I will share my configuration here. Maybe it will help.
I configured my AirPort Extreme to do "Syslog Level: 5 - Notice".
In /etc/syslog.conf I added two lines. The first makes a log file on my iMac and the second forwards to port 1514 for Smartphone Radar. I found it useful to have the log file in /var/log for troubleshooting. I can verify that the AirPort Extreme is indeed outputting information at that point. The configuration I am using only forwards the AirPort Extreme logs to Smartphone Radar so it is not cluttered with all the Mac OS X logs.
I created the /var/log/airport.log file like this:
I then restarted syslog with launchctl like this:
This configuration worked for me. I had to restart Indigo a couple times to make it all work. Maybe if you make a /var/log/airport.log file you can make sure the AirPort Extreme to Mac part is working.
PS: I got all this working but then did not use it because I use the AirPort Extreme for an access point only, not a router. All the AirPort was giving me was wireless association information that was not enough to know if the iPhones were home or not.
# to log airport extreme
local0.notice /var/log/airport.log
local0.notice @127.0.0.1:1514Code: Select all
sudo touch /var/log/airport.logCode: Select all
sudo launchctl stop com.apple.syslogdThis configuration worked for me. I had to restart Indigo a couple times to make it all work. Maybe if you make a /var/log/airport.log file you can make sure the AirPort Extreme to Mac part is working.
- jay (support)
- Site Admin
- Contact:
Ham - please keep conversations about specific plugins in their respective thread.
The error you're seeing about the XSLT tools is from the AppleScript component - you have that OSAX installed somewhere and it doesn't run on Intel systems - it's just a warning and doesn't mean anything.
Thanks, Jay. I was just trying to respect Travis' wishes in keeping router specific questions out of the thread. Is it simple to get rid of the XSLT warning by updating it?jay wrote:Ham - please keep conversations about specific plugins in their respective thread.
Re the AEBS configuration, here's where we are so far. I followed loafbread's recommendations. SBR doesn't seem to be getting the log info yet.
EDIT: Following shutting down and restarting I got this log, which seems to be catching the terminal commands. It shows a couple of trials with 127.0.0.1 and 10.0.1.18. Is this an appropriate log?
--AEBS is set to Syslog level 5, notification.
--Added port and lines per loafbread
*.notice;authpriv,remoteauth,ftp,install,internal.none /var/log/system.log
kern.* /var/log/kernel.log
# Send messages normally sent to the console also to the serial port.
# To stop messages from being sent out the serial port, comment out this line.
#*.err;kern.*;auth.notice;authpriv,remoteauth.none;mail.crit /dev/tty.serial
# The authpriv log file should be restricted access; these
# messages shouldn't go to terminals or publically-readable
# files.
auth.info;authpriv.*;remoteauth.crit /var/log/secure.log
lpr.info /var/log/lpr.log
mail.* /var/log/mail.log
ftp.* /var/log/ftp.log
install.* /var/log/install.log
install.* @127.0.0.1:32376
local0.* /var/log/appfirewall.log
local1.* /var/log/ipfw.log
"/etc/syslog.conf" 24L, 953C
--Grep Syslog results in:
Last login: Sun Jun 12 15:21:11 on ttys000
Mac-mini:~ WilliamsEC$ ps -e | grep syslogd
13 ?? 0:00.30 /usr/sbin/syslogd
1058 ttys000 0:00.01 grep syslogd
--Check TCP dump on 1514 (also tried 10.0.1.18, the assigned DHCP address):
Last login: Sun Jun 12 15:19:49 on ttys000
Mac-mini:~ WilliamsEC$ sudo tcpdump -i en1 host 127.0.0.1 and udp port 1514
tcpdump: WARNING: en1: no IPv4 address assigned
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on en1, link-type EN10MB (Ethernet), capture size 65535 bytes
Smartphone Radar Router Log: <149>Jun 12 15:45:47 Mac-mini sudo[1177]: WilliamsEC : TTY=ttys000 ; PWD=/Users/WilliamsEC ; USER=root ; COMMAND=/usr/bin/vi /etc/syslog.conf
Error script error: Can’t make characters 12 thru -1 of "" into type string. (-1700)
12Jun, 2011 3:46:24 PM
Smartphone Radar Router Log: <15>Jun 12 15:46:24 Mac-mini mDNSResponder[20]:
12Jun, 2011 3:47:00 PM
12Jun, 2011 3:47:20 PM
Smartphone Radar Router Log: <149>Jun 12 15:47:20 Mac-mini sudo[1185]: WilliamsEC : TTY=ttys000 ; PWD=/Users/WilliamsEC ; USER=root ; COMMAND=/usr/sbin/tcpdump -i en1 host 10.0.1.18 and udp port 1514
Smartphone Radar Router Log: <5>Jun 12 15:47:28 Mac-mini login[1078]: DEAD_PROCESS: 1078 ttys000
Smartphone Radar Router Log: <5>Jun 12 15:47:32 Mac-mini login[1186]: USER_PROCESS: 1186 ttys000
12Jun, 2011 3:47:50 PM
Smartphone Radar Router Log: <149>Jun 12 15:47:50 Mac-mini sudo[1190]: WilliamsEC : TTY=ttys000 ; PWD=/Users/WilliamsEC ; USER=root ; COMMAND=/usr/sbin/tcpdump -i en1 host 127.0.0.1 and udp port 1514
hamw,
Try putting the syslog lines at the bottom of the syslog.conf file. I don't know if it matters but mine are at the bottom. Restart syslog again after moving them. You shouldn't be seeing all those system messages in Indigo. I assume you are running Snow Leopard like I am?
Move to bottom of syslog.conf file.
Looks like it's also catching Indigo output. Wunderground script just ran and here's the results.
Wunderground Script Launched
Script - Skipping Thermostat Fam Study
Wunderground DEBUG: Start PWS loop- Station # is: 1, Error count is: 0
Script - Skipping Thermostat GameRm
Smartphone Radar Router Log: <5>Jun 12 16:00:02 Mac-mini [0x0-0x88088].com.perceptiveautomation.indigo-server[1134]: We received a file for station: 1
Smartphone Radar Router Log: <5>Jun 12 16:00:02 Mac-mini [0x0-0x88088].com.perceptiveautomation.indigo-server[1134]: The file was valid for station: 1
Smartphone Radar Router Log: <5>Jun 12 16:00:02 Mac-mini [0x0-0x88088].com.perceptiveautomation.indigo-server[1134]: We parsed the file for station: 1
Smartphone Radar Router Log: <5>Jun 12 16:00:02 Mac-mini [0x0-0x88088].com.perceptiveautomation.indigo-server[1134]: The last rfc observation date: Sun, 12 Jun 2011 18:56:1 GMT
Smartphone Radar Router Log: <5>Jun 12 16:00:02 Mac-mini [0x0-0x88088].com.perceptiveautomation.indigo-server[1134]: The new rfc observation date: Sun, 12 Jun 2011 19:56:21 GMT
Smartphone Radar Router Log: <5>Jun 12 16:00:02 Mac-mini [0x0-0x88088].com.perceptiveautomation.indigo-server[1134]: Compared new ==>1307908581<== to old ==>1307904961<==
- jay (support)
- Site Admin
- Contact:
I don't believe it's been updated to work on Intel boxes - but given that you can't be using it in anything anyway I'd just dump it.hamw wrote:Is it simple to get rid of the XSLT warning by updating it?
Moved the Syslog files:
And rebooted. But still seem to be getting all the Mini's info in the router log file.
I did get this, though, which may be informative:
The device window shows both phones "away" while the Variables List Window shows the phones as home.
Last login: Sun Jun 12 18:33:54 on ttys000
Mac-mini:~ WilliamsEC$ sudo vi /etc/syslog.conf
Password:
# files.
*.* @127.0.0.1:1514
*.emerg *
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_active_timeout: 0, afp_idle_timeout: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_wan_threshold: 0, afp_wan_quantum: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_no_volChange_caching: 1, afp_no_kQueues: 0, afp_no_caseSensitiveVols: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_minFileCache: 5, afp_maxFileCache: 60
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_minDirCache: 5, afp_maxDirCache: 60
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_softmount_vols: No, afp_softautomount_vols: No
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_forceKerberosOnly: No, afp_immutable_dirs: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_allow_submounts: Yes, afp_prefer_IPv4: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_minQuantumNbr: 0, afp_maxQuantumNbr: 0, afp_minQuantumSize: 0, afp_maxQuantumSize: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_minIOToleranceMSecs: 0, afp_maxIOToleranceMSecs: 0, afp_minSingleIOToleranceMSecs: 0, afp_maxSingleIOToleranceMSecs: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: CheckPrefs: User Prefs
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_login_displayGreeting: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_keychain_search: Yes, afp_keychain_add: No
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_voldlog_skipIfOnly: No
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_cleartext_allow: No, afp_cleartext_warn: No
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_use_default_name: No, afp_use_short_name: No
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_default_name: (null)
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: afp_prefs_version: 9
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FindValidIPAddress - socket 0, IPv4 10.0.1.10:548
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FindValidIPAddress - socket 1, IPv6 [fe80:0:0:0:21f:f3ff:fece:14da]:548
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FindValidIPAddress - connect worked socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FindValidIPAddress - first valid address socket 0, family IPv4
Smartphone Radar Router Log: <15>Jun 12 18:39:44 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FindValidIPAddress - prefered IPv4 address socket 0
Smartphone Radar Router Log: <38>Jun 12 18:39:45 Mac-mini /System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[354]: Starting up.
Smartphone Radar Router Log: <13>Jun 12 18:39:45 Mac-mini LKDCHelper[355]: Starting (uid=501)
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: SharedVolumeEnumerator::Init fServerName src str len 41 > dest str len 33
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: GetPascalCFString: Using the default string
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: GetUAMsInDir: cannot find /Library/Filesystems/AppleShare
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: 13:Client Krb v2
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: 4:DHX2
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: 9:DHCAST128
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: 15:No User Authent
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: TUAMHandler::ChooseBestUAM fCurrentUAM is not NULL (13:Client Krb v2) clearing...
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: 13 volumes total
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Macintosh HD volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: User has access
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Daily Time Machine volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Daily Backup volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Occ Time Machine volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Occ Backup volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Emily Internet's Public Folder volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Family's Public Folder volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on My Music volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on iTunes volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Lit Searches volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Paige Internet's Public Folder volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on RT IN GI Malig volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on hamwilliams volflags = 00
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: 13 Volumes Available
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: DoUsersMatch: Got a uid of 504
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: DoUsersMatch: Got a uuid
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: CheckPrefs: Host Prefs
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_reconnect_allow: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_mount_defaultFlags: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_reconnect_interval: 10, afp_reconnect_max_time: 600 secs
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_debug_level: 5, afp_debug_syslog: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_host_prefs_version: 9
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_active_timeout: 0, afp_idle_timeout: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_wan_threshold: 0, afp_wan_quantum: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_no_volChange_caching: 1, afp_no_kQueues: 0, afp_no_caseSensitiveVols: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_minFileCache: 5, afp_maxFileCache: 60
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_minDirCache: 5, afp_maxDirCache: 60
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_softmount_vols: No, afp_softautomount_vols: No
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_forceKerberosOnly: No, afp_immutable_dirs: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_allow_submounts: Yes, afp_prefer_IPv4: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_minQuantumNbr: 0, afp_maxQuantumNbr: 0, afp_minQuantumSize: 0, afp_maxQuantumSize: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_minIOToleranceMSecs: 0, afp_maxIOToleranceMSecs: 0, afp_minSingleIOToleranceMSecs: 0, afp_maxSingleIOToleranceMSecs: 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: CheckPrefs: User Prefs
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_login_displayGreeting: Yes
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_keychain_search: Yes, afp_keychain_add: No
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_voldlog_skipIfOnly: No
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_cleartext_allow: No, afp_cleartext_warn: No
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_use_default_name: No, afp_use_short_name: No
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_default_name: (null)
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: afp_prefs_version: 9
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - socket 0, IPv4 10.0.1.10:548
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - socket 1, IPv6 [fe80:0:0:0:21f:f3ff:fece:14da]:548
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - socket 0, IPv4 10.0.1.10:548
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - socket 1, IPv6 [fe80:0:0:0:21f:f3ff:fece:14da]:548
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - connect worked socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - first valid address socket 0, family IPv4
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - prefered IPv4 address socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - connect worked socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - first valid address socket 0, family IPv4
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - prefered IPv4 address socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: Mount succeeded
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Volume Macintosh HD is already mounted
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: FetchVolumeList: Checking Access on Macintosh HD volflags = 02
Smartphone Radar Router Log: <15>Jun 12 18:39:51 Mac-mini /System/Library/CoreServices/NetAuthAgent.app/Contents/MacOS/NetAuthAgent[350]: TSocketAFPSession: Disposing of a TSocketAFPSession 1883d80
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - socket 0, IPv4 10.0.1.10:548
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - socket 1, IPv6 [fe80:0:0:0:21f:f3ff:fece:14da]:548
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - connect worked socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - first valid address socket 0, family IPv4
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /Applications/Utilities/Grab.app/Contents/MacOS/Grab[332]: FindValidIPAddress - prefered IPv4 address socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - socket 0, IPv4 10.0.1.10:548
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - socket 1, IPv6 [fe80:0:0:0:21f:f3ff:fece:14da]:548
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - connect worked socket 0
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - first valid address socket 0, family IPv4
Smartphone Radar Router Log: <15>Jun 12 18:39:52 Mac-mini /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder[158]: FindValidIPAddress - prefered IPv4 address socket 0
Smartphone Radar Router Log: <7>Jun 12 18:39:52 Mac-mini kernel[0]: AFP_VFS afpfs_mount: /Volumes/Macintosh HD, pid 350
Smartphone Radar Router Log: <5>Jun 12 18:40:00 Mac-mini com.perceptiveautomation.IndigoServer2[191]: /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/External Scripts/Recent Activity List.scpt:
Smartphone Radar Router Log: <5>Jun 12 18:56:51 Mac-mini login[381]: DEAD_PROCESS: 381 ttys000- Attachments
- SmartPhoneRadar Screen Shot.tiff (57.46 KiB) Viewed 6777 times
Remove this line from your syslog.conf and restart syslogd
*.* @127.0.0.1:1514
That is the line that is sending everything to Smartphone Radar.
*.* @127.0.0.1:1514
