Domio gets notifications, device history, live widgets and more
whmoorejr
Re: Domio gets notifications, device history, live widgets and more
Post by whmoorejr »
The williammoore account (me) is/was my oldest user account. When apple started using iCloud stuff for creating users.... my indigo setup got a little weird. By then, I already had a seperate indigo icloud account... whm.indigo. My last couple computers, I used that as the account to set up the computer then added william.moore as an admin user.
I've never even logged into that computer (except maybe once to set up the other account). I've done everything from the william.moore login. (including installing everything).
does that make a difference?
I could try to swap stuff over... but I can't even think of how many scripts or things will break because they look for items under the williammoore account
Bill
My Plugin: My People
whmoorejr
Post by whmoorejr »
jay (support) wrote: Wed Jun 17, 2026 11:17 am in the terminal will tell you.
Indigo-Server:~ williammoore$ id
uid=501(williammoore) gid=20(staff) groups=20(staff),12(everyone),61(localaccounts),79(_appserverusr),80(admin),81(_appserveradm),98(_lpadmin),33(_appstore),100(_lpoperator),204(_developer),250(_analyticsusers),395(com.apple.access_ftp),398(com.apple.access_screensharing),399(com.apple.access_ssh),400(com.apple.access_remote_ae),701(com.apple.sharepoint.group.1)
I'm staff?
get info on the /usr/local/indigo folder shows "You have no access"
System: Read & Write
wheel: Read & Write
everyone: No Access
so even if I am admin.... admin doesn't have access? Should I change that? Add the admin group?
Bill
durosity
Post by durosity »
jay (support) wrote: Wed Jun 17, 2026 9:29 am @durosity, hiding errors is never the right choice since failures become invisible and bugging issues becomes almost impossible. However, making errors more clear and useful to solve the issue is.
I didn't mean hiding errors as such, more the repetitive messages that appear when the app connects to Indigo to refresh its data.
jay (support)
Post by jay (support) »
What is the output from:
ls -la /usr/local/indigo
If that gives you a permission error, then:
sudo ls -la /usr/local/indigo
and:
ls -la /usr/local
You have something seriously wrong with permissions and accounts, I just can't really tell yet.
BTW, this has nothing to do with iCloud - it's all local macOS accounts and permissions. Well, I don't *think* so.
whmoorejr
Post by whmoorejr »
jay (support) wrote: Wed Jun 17, 2026 1:00 pm What is the output from:
Indigo-Server:~ williammoore$ ls -la /usr/local/indigo
total 0
ls: /usr/local/indigo: Permission denied
Indigo-Server:~ williammoore$ sudo ls -la /usr/local/indigo
total 72
drwxrwx---   7 root  wheel   224 Jun 17 11:35 .
drwxr-xr-x  24 root  wheel   768 Jun 17 11:32 ..
-rwxrwx---   1 root  admin  4573 Apr 29 13:48 indigo-clean-and-zip-plugin
-rwxrwx---   1 root  admin  7518 Apr 29 13:48 indigo-host
-rwxrwx---   1 root  admin  5445 Apr 29 13:48 indigo-restart-plugin
-rwxrwx---   1 root  admin  2484 Apr 29 13:48 indigo-start
-rwxrwx---   1 root  admin  5332 Apr 29 13:48 indigo-stop
total 27296
drwxr-xr-x@  11 root          wheel       352 May 21 03:57 ..
-rw-r--r--    1 root          wheel         0 Feb 12  2021 .com.apple.installer.keep
drwxr-xr-x  342 root          wheel     10944 Jun 17 11:36 bin
drwxrwxr-x   22 williammoore  admin       704 Feb  5  2021 Cellar
-rw-r--r--    1 root          wheel       440 Aug 11  2019 entropy-php.conf
drwxrwxr-x   13 williammoore  admin       416 Feb  5  2021 etc
drwxrwxr-x    4 williammoore  admin       128 Feb  5  2021 Frameworks
drwxrwxr-x   23 williammoore  admin       736 Jan 12  2024 Homebrew
drwxrwxr-x  124 williammoore  admin      3968 Feb  5  2021 include
drwxrwx---    7 root          wheel       224 Jun 17 11:35 indigo
drwxr-xr-x   13 root          wheel       416 Jun  9  2020 info
drwxrwxr-x@ 249 williammoore  admin      7968 Feb  5  2021 lib
-rwxr-xr-x    1 root          wheel  13973716 Aug 11  2019 libphp7.so
drwxr-xr-x    3 root          wheel        96 Feb  5  2021 n
drwxrwxr-x   29 williammoore  admin       928 Feb  5  2021 opt
drwxr-xr-x   14 williammoore  wheel       448 Feb  5  2021 packager
drwxr-xr-x   28 root          wheel       896 Jun  9  2020 php.d
drwxr-xr-x   14 root          wheel       448 Feb  5  2021 php5-7.1.31-20190811-210816
drwxr-xr-x    3 root          wheel        96 Feb  5  2021 remotedesktop
drwxr-xr-x   10 root          wheel       320 Jun  9  2020 sbin
drwxrwxr-x@  27 williammoore  admin       864 Feb  5  2021 share
drwxr-xr-x    7 root          wheel       224 Jun  9  2020 ssl
drwxr-xr-x    6 root          wheel       192 Jun  9  2020 var
Has anyone seen the "Demotivation" poster of the wrecked ship with the caption... "It could be that the purpose of your life is only to serve as a warning to others". Yeah, I think that's me.
Bill
jay (support)
Here's the problem:
Something stomped on the permissions of that directory in /usr/local/
sudo chgrp -R admin /usr/local/indigo
That should fix the issue starting the Indigo command line tool. I don't know where we stopped with the rest of the testing.
siclark
Post by siclark »
siclark wrote:
jay (support) wrote: Wed Jun 17, 2026 6:11 am Hey Simon, can you drop me an email with the details/example? We probably need to catch that exception with a better error.
This is something whmoorejr needs to run, it is a 500 error on his call.
I think this is returning him a 500
 curl -i -H "Authorization: Bearer YOUR_API_KEY"  https://YOUR_REFLECTOR_ID.indigodomo.net/v2/api/indigo.variables
Claude suggests below in the scripting shell might identify the problem variable. but the above returns 200 for me so all good.
import urllib.request, urllib.error
BASE = "http://127.0.0.1:8176/v2/api"
KEY = ""  # set to your API key if localhost rejects unauthenticated calls
def get(url):
    req = urllib.request.Request(url)
    if KEY:
        req.add_header("Authorization", "Bearer " + KEY)
    return urllib.request.urlopen(req, timeout=10).getcode()
bad = []
for v in indigo.variables:
    url = "{0}/indigo.variables/{1}".format(BASE, v.id)
        code = get(url)
        if code != 200:
            bad.append((v.id, v.name, code))
            indigo.server.log("BAD {0}: id={1} name={2!r}".format(code, v.id, v.name), isError=True)
    except urllib.error.HTTPError as e:
        bad.append((v.id, v.name, e.code))
        indigo.server.log("BAD {0}: id={1} name={2!r}".format(e.code, v.id, v.name), isError=True)
    except Exception as e:
        indigo.server.log("ERR id={0} name={1!r}: {2}".format(v.id, v.name, e), isError=True)
indigo.server.log("variable scan complete -- {0} problem variable(s)".format(len(bad)))
Now try this again now you can get a scripting prompt open.
whmoorejr
Post by whmoorejr »
siclark wrote: Wed Jun 17, 2026 1:57 pm
Well, for the 1st step... I now get this:
Connected to Indigo Server v2025.2.0, api v3.8 (localhost:1176)
>>> curl -i -H "Authorization: Bearer 5201...db3"  https://whmoorejr.indigodomo.net/v2/api/indigo.variables
  File "<console>", line 1
SyntaxError: invalid syntax
With the 2nd part, it identified 4 problem variables. Nothing I use anymore. Leftover from an old plugin. (SMDPd Plugin). Deleted those 4 variables. Ran the 2nd part again. No bad things.
Curious, what makes a variable go bad?
Bill
whmoorejr
Post by whmoorejr »
So sorry for dominating this thread. After I updated the permissions on that folder (Thanks for the trouble shoot Jay), and after I found the four bad variables and deleted them.... Notifications cleared up. (Sent myself a test notification successfully) No goofy 500 erros. And even the Shortcuts app can now be used to update a variable via dom.io
I think that fixed everything. Yall are awesome!
Ok. What can I break next?
Bill
durosity
Post by durosity »
whmoorejr wrote: Wed Jun 17, 2026 4:53 pm Ok. What can I break next?
My spirit! Oh wait, that’s already happened!
siclark
Post by siclark »
whmoorejr wrote:So sorry for dominating this thread. After I updated the permissions on that folder (Thanks for the trouble shoot Jay), and after I found the four bad variables and deleted them.... Notifications cleared up. (Sent myself a test notification successfully) No goofy 500 erros. And even the Shortcuts app can now be used to update a variable via dom.io
Can you share details to Jay please of the variables breaking the call
siclark
Post by siclark »
This has been pushed to Apple for release. Will be 2.3 and includes the Matter functionality, DSC alarm support, network improvements and improved ability to register a device for notifications if not done on startup.
I’ll pull this debugging an indigo issue out into another thread as was indigo not dom.io issue.
Next release will be expanding the number of devices it can control.
jay (support)
siclark wrote: Thu Jun 18, 2026 12:01 am
whmoorejr wrote:the four bad variables
Glad you got it working - yes, can you please share the details of those "bad" variables so I can reproduce the error?
whmoorejr
Post by whmoorejr »
jay (support) wrote: Thu Jun 18, 2026 6:44 am Glad you got it working - yes, can you please share the details of those "bad" variables so I can reproduce the error?
Part of the log from when I ran that script:
2026-06-17 17:41:23.470	Web Server Warning	HTTP API v2 GET call received for indigo.variables/1924392604 from 127.0.0.1
2026-06-17 17:41:23.470	Web Server Warning	undefined page for request /v2/api/indigo.variables/1924392604 from 127.0.0.1
2026-06-17 17:41:23.470	Interactive Shell Error	BAD 404: id=1924392604 name='smtpd_messageFrom'
2026-06-17 17:41:23.471	Web Server Warning	HTTP API v2 GET call received for indigo.variables/357203846 from 127.0.0.1
2026-06-17 17:41:23.471	Web Server Warning	undefined page for request /v2/api/indigo.variables/357203846 from 127.0.0.1
2026-06-17 17:41:23.471	Interactive Shell Error	BAD 404: id=357203846 name='smtpd_messageSubject'
2026-06-17 17:41:23.472	Web Server Warning	HTTP API v2 GET call received for indigo.variables/1114385026 from 127.0.0.1
2026-06-17 17:41:23.472	Web Server Warning	undefined page for request /v2/api/indigo.variables/1114385026 from 127.0.0.1
2026-06-17 17:41:23.472	Interactive Shell Error	BAD 404: id=1114385026 name='smtpd_messageText'
2026-06-17 17:41:23.473	Web Server Warning	HTTP API v2 GET call received for indigo.variables/1442611324 from 127.0.0.1
2026-06-17 17:41:23.473	Web Server Warning	undefined page for request /v2/api/indigo.variables/1442611324 from 127.0.0.1
2026-06-17 17:41:23.473	Interactive Shell Error	BAD 404: id=1442611324 name='smtpd_messageTo'
2026-06-17 17:41:23.474	Web Server Warning	HTTP API v2 GET call received for indigo.variables/539012128 from 127.0.0.1
2026-06-17 17:41:23.474	Web Server Warning	HTTP API v2 GET call received for indigo.variables/774293101 from 127.0.0.1
These four variables all had dependencies.... sorta. They were populated / controlled by the old SMTPd plugin. I stopped using that plugin a few years ago (Used it as a workaround to get instant motion notifications from cameras). Deleted out the plugin, forgot about the variables. That's the only difference between those 4 and the rest of the unused forgotten variables I still have.
Bill
whmoorejr
Post by whmoorejr »
siclark wrote: Wed Mar 25, 2026 4:20 pm Push Notifications
Now that it's working on mine, I really love how well it works and the ability to deep link into pages, devices etc without a bunch of extra clicking on stuff.
I have a couple requests to make it a true replacement for how I use pushover (general feature requests):
URL deep linking:
  • blueiris://?camera=SHORTNAME Direct to a camera in the blueiris app
    https://tempestwx.com/station/STATION_ID/ External link to a local weather station
    ? Is there a url to go to the notifications history? Or maybe that should be the default deep link if one isn't set?
NOTE: Tried typing a paragraph long message to see how it looks. Only a few lines visible when the banner popped up, clicked (no deep link selected) went to the last domio screen I was on.
Scriptable:
Some of the pushover messages I send are beyond the scope of the plugin, so I use python scripts to handle those.
Banner Icon / Title options:
With pushover, I use multiple icons (different API Tokens) to quicky differentiate the notification category: Indigo (Catch All), Motion, Front Door, Climate, CDRA (My office), Emergency, GeoLocation (Any location based event), Security (Catch all for a security event that's not an emergency, Cyber (networking events). Yes, I could just make that the title, but it would be cool if the icon could change so even when your screen is locked, you could know right away.
Sound Options:
I don't really use this because my phone is on silent mostly... Some might find it usefull for differentiating between a update notification and an urgent notification.
Image / GIF Support?
I guess technically you could do this now with a control page that has a refreshing image.
Example: When my front door camera detects motion, Indigo pulls a static image of whatever created that motion event (human, dog, bicycle, etc). That image is saved twice: Once as CAMERA_NAME_Date:Time.jpg in a camera log folder, and once as "R.jpg". So the rotating image "R.jpg" is always my most current "threat". So if I want a notification associated with that camera, I include "Rotate.jpg" as part of the payload for the notification.
Alternatively, could you possibly deep link to an image on the indigo server (in the way a control page uses a refreshing image URL.... but without the control page)? Example from one of my control pages:
file:///Users/williammoore/Desktop/IPCamRotate/R.jpg
Bill
Return to “Domio”
