Hue new versions
Re: Hue new versions
2022.23.64 @ 2026-01-18
1. added assign modelid if not found in defs to similar device eg if RDM005 not defined, try to look in product name to find know device that matches
This should support new sensors / switches that have a new model id eg the new smart button has a different modelid than the old one.
if you encounter this please let me know and I can aded the model id to the list
For lamps it is done differently: only lamp type not model is used. All lamps fall into a few categories (on/off, dimer, color temp, color). That has not changed in the last years. Switches and sensors seem to be more complicated
2. added support for hue motion area events:
With the new pro bridge you can use the lamps in the room to detect movements
If you have setup a motion area zone then the plugin will create the corresponding device
and will set onOffState to True=on / False=off if motion is detected / expired. you can trigger on dev/state: onOffstate true / false
This works surprisingly well. The lamps must not be all in the same area, best if you have some on the ceiling and one at the entrance.
You should play around with the sensitivity settings.
Hue naturally also offers to use the events directly inside the hue system to switch on .. lamps devices.
In Indigo the motion are events only work if you use hue pro bridge and have api v2 and events in the plugin enabled
3. added eventNumber state to motion devices (also the old physical ones and old bridge), it added 1 if state goes from off to on
Remark. I have moved 3 old bridges to one pro. The plugin load is down a lot due to event listening, not polling. So instead of polling the bridges every 2 secs and reading xxxKB the plugin only refreshes the complete date every 500 secs (can be changed), but receives the events in < 1 sec from the bridge(1 kb/event). There are only a few events per minute: when you press a button, a motion is detected or light goes on / off.
I still have kept one old bridge for one room to be able to test new versions on the old bridge.
Hue new versions
2022.23.66 @ 2026-01-20
fixed bug introduced in last version
2022.24.68 @ 2026-01-25
1. removed some api v2 debug statement and config options.
2. no detailed options to choose from if api2v enabled
3. and some code cleanup
1. removed a debug statement
2. reversed a json.loads statement. apparently older python versions are fickle with single quotes: json.loads("{'a':1}") errors - not in the current indigo version though
3. fixed a bug: deleting a device and auto re-creating it caused an error. - it kept the old info in temporary dicts.
2022.25.70 @ 2026-02-03
1. added menu item to ignore/ disable hue device auto creation in indigo.
Normally the plugin will auto create a missing device in indigo.
This option will prevent this for selected hue devices (light, sensor, groups)
2022.27.74 @ 2026-02-15
1. added stats for # of packages send / received
added a print option to show the network traffic used (menu "print hue config .."" at bottom)
2. cleanup frequency for different http requests. It is now per type and per bridge
pro bridge as compared to old bridge type has about 1/5 the packages (incl events) and ~ 1/3 # of bytes.
with 2 bridges, one old and one pro and ~ 80 physical devices the average load on a MAC M1 is -0.5-6% averaging ~ 2.5%
and response time to devices changes on the pro bridge is < 0.5 seconds
3. added support for device"security contact". only works with pro bridge
looks like phillips is not adding api v1 support for newer models
api v1 does not send any info for that device on old bridge as well as new bridge
4. removed unnecessary items from device edit.
it is now very simple.
Disabled "create new device" for std Hue devices, beside "hue attribute controller"
all std devices are automatically created by the plugin.
5. fixed ignore devices and added support for V2 only devices
and thanks to Dirk for testing
PRE-RELEASE download from here :
https://github.com/kw123/Hue-Lights-Ind ... 2022.28.75
2022.28.75 @ 2026-02-24
1. added support for pro bridge for scene recall (activate a scene on the bridge, with option to set brightness and ramp rate.)
2. several smaller performance improvements
3. cleaned up code.
4. reconfigured RGB to XY color schema for pro bridges.
this is a prerelease. everything should be working.
BUT: could anyone test if pro and old bridges still work fine.
I have retired all of my old bridges, now everything runs on single pro bridge, down from 4 old bridges.
this is an update with some nice features. The hue pro bridge is now fully supported with api v2 calls.
2022.29.78 @ 2026-03-13
1. fixed bug for hue contact sensor update
2. fixed bug not creating api v2 devices for groups - there was a debug statement not commented
2022.29.77 @ 2026-03-12
1. added option to use default for brightness and ramp rate for recall action
2. fixed several rgb / dimmer functions
3. added enable disable for devices for pro bridge
4. added scenes support for pro bridge
5. added config option to set prefixes for devices names types switch/sensor/light/group eg Hue_light_br#_id#_nameOnBridge (replace light with lampa)
6. added different prefix for switches and sensors (was all sensor)
7. combined many sql updates for a device into a single call
8. reduced CPU usage, with > 80 lights, 15+ sensors 40+ switches on pro bridge: 0.1% .. 2% cpu on MAC-M1 (state updates depending on sensor, switch, light event frequency, no update: 0.1% CPU)
on my previous setup with 4 old bridges it was 5%-15% and response time to sensor events was 2-3 secs, now < 0.5 secs.
9. added option in config to enabled / disable a bridge. this will only disable communication with the bridge.
Useful if you have disconnected a bridge and would like to stop error messages
10. added a device for each bridge. it will contain bridge values in the device states (30+) This device is not editable, the states are just for info.
11. The pro bridge does not supply rgb (xy) color update events for groups (zones, rooms), only brightness level.
the issue is likely that a mix of different lamp types makes it difficult to actually calculate the proper color values (rgb + dimm only + color temp lamp types )
work around: Added a http api v1 "get" for all data for the hue group, WHEN a brightness level change event is received. That should cover most situations.
12. fixed indigo device icon. if a device is turned off, but brightness level is not 0 the icon stayed "ON". Now it reflecting state is off/on
2022.29.81 @ 2026-03-16
1. fixed bugs
lots of little format issues, misspelled variables, but used only in rare circumstances
used "pycharm" and "claude" to do syntax error checking
pycharm is much better though.
Hue new versions
2022.29.82 @ 2026-04-02
1. add check if connection to hue bridge is lost through eg reboot. The event listener in api v2 (pro bridge) does not realize if the connection is broken.
Now added a timeout you can set (in config) to re-establish the connection if no events where send from the bridge to the plugin.
It actually has 3 timeout tests.
One is a 11 minute hardwired timeout parameter in the http event receive stream connection.
The other - that value can be configured in config - remembers when the last hue event (sensor change, lights on/off) was received.
It is also triggered by a failed http get when the plugin once ever xx minutes tries to get the Hue bridge config and fails
I have many sensors etc and 1 minute seems to short for the timeout.
2+ minutes seem ok.
Anyway this is only for the exception that your Hue PRO bridge was rebooted or went offline for any reason. I had that when I was traveling. Tt now nicely recovers w/o flooding the indigo log.
No change for the older Hue bridge V2.
========================================. mostly for hue pro bridge
2022.32.112 @ 2026-07-09
The "shortBridgeInfo" print (bridge/lights/groups/... summary header + per-bridge lines) is now built into
one string (leading \n, each line \n-separated) and written with a single log call, instead of one log
entry per line. The rare not-setup/not-paired lines are included in the same block (now level 20).
The full bridge re-read now runs ONLY on a real outage (gap > kEventReplayWindowSecs). Previously it also
fired for short gaps where 0 events were replayed (nothing had happened) — unnecessary. Now: gap > window
-> level 20 + re-read; replay recovered events (short gap) -> level 10, no re-read; short gap with no events
-> level 10, no re-read. So no re-read for the routine hourly recycle.
Shortened the reconnect-table header line: "eventstream reconnects (last N of 100) — M replayed, avg gap Xs".
Dropped the long column-explanation parenthetical (the column names are self-explanatory).
Level 20 now fires only when events may actually have been MISSED (not merely recovered). Reasoning:
recovered events are counted reliably and are NOT missed; a true miss only happens if the reconnect gap
outlasts the bridge's Last-Event-ID replay buffer (then the oldest events age out). So: gap <= the assumed
replay window (kEventReplayWindowSecs, default 300s) -> fully recoverable -> level 10; gap > the window ->
possible data loss -> level 20 ("gap of Ns EXCEEDED the ~Ws replay window ... MAY HAVE BEEN MISSED").
Honest limitation: from the stream alone a quiet gap and a buffer-overflow gap are indistinguishable, so
this is a gap-duration proxy, not a perfect miss detector. For the ~40s hourly recycles it stays at level 10.
Also: the re-read is now forced whenever there was no full replay OR the gap exceeded the window.
The "real gap ... recovered N events" line is now level 10 too. The hourly bridge-recycle reconnect is
routine and self-healing, so it produces no level-20 output at all now (details remain in the print-stats
reconnect table). Still level 20: the first-connect "Successful Connected" (startup) and the generic
"Error: ... Reconnecting" for unexpected exceptions.
Reconnect table "last event" column now shows the full YYYY-MM-DD HH:MM:SS timestamp (column widened).
Reconnect table: replaced the raw epoch ev-ids (useless to read) with human-readable columns —
"last event" = the bridge time of the last ev-id before the gap (epoch converted to local, dd HH:MM:SS),
and "next event" = "+Ns" seconds to the first ev-id after. Dropped the separate ev-gap column (now the
"next event" delta).
Reconnect table: dropped the misleading "spurious?" label. recovered==0 only means "no events occurred
during the gap", NOT that the restart was unneeded — the connection gap was still real (confirmed by
the ev-id epochs jumping tens of seconds). Added an "ev-gap" column = the time hole between the last
ev-id before and the first ev-id after (seconds), which shows the real gap even when 0 events were
recovered. Summary line now reports total events replayed + average gap, no spurious count.
Quieter reconnect logging. Routine reconnect notices are now level 10 (debug): "Bridge connection
closed/unreachable / read timeout ... Reconnecting", "Successful Connected" (on reconnects only — still
level 20 on the first connect), "reconnect after Ns gap ... checking replay", and the "no events missed
/ likely unneeded restart" resolution. Only a REAL gap (events actually recovered) logs at level 20,
now as one self-contained line including the gap duration: "bridge X: real gap of Ns — last ev-id ...
-> first ev-id ...; N events replayed by bridge". So a spurious reconnect is silent at normal level;
a genuine data-gap shows exactly one line.
Single source of truth for config defaults: all plugin-config parameter reads now use
kDefaultPluginPrefs["key"] as their fallback instead of hardcoded literals — timeScaleFactor,
sendDeviceUpdatesTo, timeScaleFactorAPIV2, showLoginTest (startup + getDebugLevels), the debug* flags,
autoCreatedNewDevices, folderNameForNewDevices, and logAnyChanges (now a safe .get). The event
thresholds already used kDefaultPluginPrefs + minMaxEventRecovery ranges. (Consistent with removing the
default= attributes from PluginConfig.xml — defaults now live only in kDefaultPluginPrefs.) Action /
device dialog fields are unchanged; those aren't plugin-config parameters.
Faster reconnect. The eventstream reconnect used a fixed 5-10s sleep, adding ~10s to every gap. Now a
drop of a *working* connection (the common case: the bridge gracefully recycles/close-notifies the SSE
connection) reconnects IMMEDIATELY (0s); the delay only escalates (2 -> 5 -> 10s) if the reconnect
itself keeps failing (bridge genuinely down). reconnectFailures resets as soon as data flows again.
This covers the TLS close-notify case without parsing the alert (requests abstracts it away).
Also fixed two bugs introduced in the parameter-driven readEventTimerPrefs edit: a missing ')' on the
NumberOfSecondsEventRestart read, and the fallback clamp using 'restart' instead of 'woMsg'.
Note: the remaining gap (~25s in the captured case) is the bridge holding the connection open/idle
before it closes it — that part is bridge-side and not reducible from here.
Track the last ev-id before a reconnect and the first ev-id received after, to tell a real gap from a
spurious restart. Each reconnect log line and the print-stats reconnect table now show both ids, and
the table adds a summary ("N real gap, M with NO events missed"). A reconnect that recovers 0 events
(recovered==0) means nothing was actually missed — flagged "0 no-gap"; a run of these at a low
NumberOfSecondsEventRestart indicates the threshold is too aggressive (spurious restarts, no data lost).
Fix: the v.99 "apply NumberOfSecondsEventRestart immediately" didn't work — validatePrefsConfigUi
applies the new value before closedPrefsConfigUi captured the old one, so the change was never detected
(it only took effect on a full plugin reload). Now each listener session is stamped with the threshold
it was built with ('restartSecs'), and checkIfListenerIsRunning (main loop, every ~10s) restarts the
listener when that differs from the current config value. Works regardless of the dialog callback order.
Changing the (main) NumberOfSecondsEventRestart threshold now takes effect immediately. The keepalive
is baked into the socket at session creation, so a changed value previously needed a plugin reload
(in-thread reconnects reuse the same session). closedPrefsConfigUi now detects a change to that value
and restarts the V2 event listeners, so checkIfListenerIsRunning respawns them with a fresh session
(new keepalive) within ~10s. The (fallback) NumberOfSecondsEventWoMessage watchdog already applied live.
Cosmetic: getDebugLevels() collapsed its two duplicate branches (loop + showLoginTest read) into one
path — "if useMe is None or empty: useMe = self.pluginPrefs", then a single loop. No behaviour change.
Refactor (continued): the general prefs that were applied in startup + validatePrefsConfigUi +
closedPrefsConfigUi (timeScaleFactor, sendDeviceUpdatesTo, searchForStringinFindHueBridge, and the
fixed timeScaleFactorAPIV2) are now read/applied by one method applyGeneralPrefs(prefs), called from
all three. Removes the duplicated apply blocks and the dead `if False:` timeScaleFactorAPIV2 reads
(the value was already forced to 119). All three sites now apply the same set consistently. No
behaviour change for real values.
Refactor: the read+range-clamp of the two eventstream restart thresholds was duplicated in three
places (startup, validatePrefsConfigUi, closedPrefsConfigUi). Consolidated into one method
readEventTimerPrefs(prefs) that all three call. No behaviour change.
Split the eventstream restart control into two separate expert-section config dropdowns:
- (main) NumberOfSecondsEventRestart: 10..130s, default 90 — drives the TCP keepalive (fast restart,
fires "Bridge unreachable. Reconnecting"). This is the primary threshold.
- (fallback) NumberOfSecondsEventWoMessage: 60..200s, default 180 — drives the no-message watchdog,
the backstop for the rare case where TCP stays alive but the bridge stops sending events.
Both defaults are in kDefaultPluginPrefs; both are range-clamped on load (legacy values → default).
The stream read timeout now sits above whichever of the two is larger (+60s).
1. Full bridge re-read after a gap is now conditional: if the bridge replays the missed events
(Last-Event-ID), processing them already makes device states current, so the re-read is skipped.
The re-read is only forced when the bridge sends no backlog. Removes the redundant per-hour re-read
on bridges that support replay.
2. Restart threshold is now a config dropdown (expert section, bottom of plugin config):
"Restart api-V2 event listener after no events for:" with fixed values 10..130s, default 90.
Reuses the existing NumberOfSecondsEventWoMessage pref and now drives BOTH the TCP keepalive
(idle = threshold-20, +2x10s probes) and the no-message watchdog, so the whole range is effective.
Legacy/out-of-range saved values (e.g. 180/240) are clamped to the new default 90 on load.
1. Restart threshold raised to ~90s: eventstream TCP keepalive is now 60s idle + 3x10s probes (was
30s + 3x10s = ~60s). A >=90s silence has <0.01% chance of being normal (observed max gap ~40s), so
this never false-triggers and avoids reconnecting into a still-stalled bridge.
2. Reconnect table in print-stats clarified: the count column is now labelled "recovered" (= gap events
the bridge replayed), right-aligned; values are a number or "pending" (events not yet resumed).
Columns realigned.
Note: the separate watchdog backstop (config: NumberOfSecondsEventWoMessage, ~180s) is unchanged;
lower it to ~90s in plugin config if you also want the "no message in N secs" path to fire at 90s.
Harden the skipped-event count against a bridge event-id going backwards (e.g. a bridge reboot whose
clock resets before NTP re-sync). The backfill test now requires resumeEpoch <= evTs < reconnect-time
(previously only the upper bound), so a backward id jump reads as "0 / no replay" instead of counting
every live event as skipped. Gap duration, forced re-read, and Last-Event-ID resume were already safe.
Print-stats now includes a rolling eventstream-reconnect history. Each reconnect records timestamp,
bridge, gap duration (s), and events skipped/recovered; the list is capped to the last 100 (oldest
dropped). Shown at the bottom of the "bytes send /received to/from bridge" (and ...WithReset) menu output.
Report skipped-event count on reconnect. The SSE event id is <unix-epoch-seconds>:<index>, so after a
gap-reconnect the plugin counts how many replayed events carry an id-epoch earlier than the reconnect
moment (= events that were skipped by the live connection and are now being backfilled). Logs either
"recovered N events that were skipped during the gap (bridge replayed them)" or, if the bridge sends no
backlog, "bridge did not replay any skipped events; states were made current by the forced re-read".
The reconnect line now also prints the gap duration in seconds.
Event-stream gap recovery — after an SSE stall/reconnect, missed events no longer leave device states stale:
1. Last-Event-ID resume: the plugin now remembers the last SSE event id per bridge (persists across
listener restarts) and sends it as the Last-Event-ID header on reconnect, so a compliant bridge
replays events buffered during the gap. (Buffer depth is bridge-dependent/short; confirm from the
log by watching for a burst of events right after "reconnect after gap".)
2. Forced full re-read on reconnect: whenever the listener reconnects with a stored event id (i.e. a
gap occurred, not the first-ever connect), it zeroes the getHueConfig / 'all' / 'v2' / checkMissing
timers so the next main-loop pass re-reads the whole bridge and brings all device states current —
the same reconcile the bridge already does on add/delete events. This guarantees persistent state
(on/off, brightness, colour, sensor values) is correct after a gap even if the Last-Event-ID replay
buffer has rolled over. Transient events (a button press / motion pulse that already cleared during
the gap) are only recoverable via #1, not the re-read.
Note: the underlying hourly stalls are a bridge-side issue (bridge stalls its own eventstream ~hourly,
stays ping-reachable throughout) — see VERSION_HISTORY .87/.88; this change limits the data impact of each stall.
1. TCP keepalive enabled on the event-stream socket (probe after 30s idle, then every 10s, 3 probes).
The SSE connection is inbound-only after the request; NAT tables / power-save / bridge firmware
silently drop such connections (~hourly stalls on bridge 1). Keepalive probes maintain the path
(usually preventing the stall) and let the OS detect a dead peer in ~1 minute, so recovery happens
as a normal reconnect instead of waiting for the watchdog.
2. "listener thread did not stop cleanly" warning downgraded to an informational message — with the
v.87 stop mechanism an old reader draining in the background is expected and harmless.
1. Event-listener restart after a stalled stream now takes seconds instead of ~8 minutes:
- stop_listener closed the streaming response inline from the watchdog thread; closing an SSL
socket that the listener thread is blocked reading waits on the SSL lock until the read times
out (NumberOfSecondsEventTimeOut = 660s), stalling the whole plugin loop. The close now runs
in a small daemon thread.
- The stream read timeout now tracks the watchdog window (NumberOfSecondsEventWoMessage + 60s,
capped at NumberOfSecondsEventTimeOut) so an abandoned reader thread exits soon after being replaced.
- A replaced (zombie) reader can no longer clear the new listener's response reference or
lastMessage, and no longer queues a stop_listener that would tear down the replacement listener.
Code audit: ~40 bug fixes across plugin.py (no new features). Highlights:
1. Save Preset no longer rejects every light device (validation compared the Python builtin "type" against the compatibility list)
2. Recall scene without a group works again (int 0 vs string "0" groupId mismatch); doScene now tolerates int groupIds
3. activateScene picks the API version of the action's own bridge, not the last bridge selected in a config dialog; removed an older dead duplicate of activateScene
4. V2 set-color-temperature now sends the requested brightness and turns the light off at brightness 0 (previously always on:true, brightness discarded)
5. RGB scaling is no longer corrupted after saving plugin prefs (stale "rgbmax" block set rgbIndigoMax to 1.0)
6. White-level slider: hue is converted from degrees to the bridge 0-65535 scale (lights snapped to red before); hueGroup white slider no longer forces saturation to 0
7. Attribute Controller colorGreen toggle-on no longer swaps green into the red channel
8. V1 "off" commands use the noOffRampRate prop instead of noOnRampRate; V2 "off" reads the correctly spelled brightnessLevel state (ramp rate was always forced to 0)
9. Dimmer-switch/button onOffState is no longer inverted (triggers fired backwards)
10. hueOnOffDevice V1 "on": Indigo state updates again (undefined vars aborted the handler after the bridge command)
11. Hue state for bulbs/light strips/LivingColors stored in degrees again (normalizeHue return value was discarded)
12. V2 color/ct-only events no longer reset brightness to 100% (missing "dimming" now keeps the last known level)
13. zgp (Tap / Friends-of-Hue) connectivity events no longer mark connected devices as disconnected (quoting typo)
14. Motion-area device creation fixed (moti905onInfo typo, indigo.devices["name"] literal, getConvenienceAreaMotionInfo returning a bare None); grouped-motion states no longer set to literal key names; contact-sensor tamper state no longer clobbered to None
15. Event stream: health updates no longer leak to the wrong device; per-bridge listener threads no longer share one deviceUpdate dict; listener shutdown race guarded
16. One offline V2 bridge no longer aborts the data refresh for all bridges; child-service exclusion in fillAllDataV2 fixed (stale loop variable)
17. Move-device-to-new-bridge: states are actually transferred now, and the moved device is no longer auto-recreated on the old bridge (ignore list used wrong key and wrong id)
18. Hold-to-brighten/dim worker thread logs errors and keeps running instead of dying silently
19. Expired auto-pairing window stops retrying instead of re-pairing on every poll cycle
20. Many smaller fixes: scene/preset dialog crashes (KeyErrors, Py2 leftover .items()[0], "{}}" format string), color-picker hex builder, sensor status requests skipped when debug logging was on, temperature offset now scaled correctly for Fahrenheit, sensitivityMax gating, duplicate-sensor validation no longer crashes on stale devices, various wrong/misleading log messages
SearchCz
Post by SearchCz »
kw123 wrote: Tue Feb 24, 2026 2:44 pm PRE-RELEASE download from here :
3. cleaned up code.
What do I do if I don't want any "default brightness" sent to my Hue lights? I'm looking for a (None) option on the device config. Can you point me in the right direction please?
No Default Brightness Please.jpg (172.18 KiB) Viewed 106 times
What do you want to do? Just on / off?
SearchCz
Post by SearchCz »
Yes. I am doing an on/off and the device/plugin is reporting this *default* number back as the device brightness initially, then reporting back the actual brightness shortly afterwards. I think I found a workaround for this.
v 2022.33.120
added option to use
- default brightness
- last brightness
to switch on lamps
you can set general pref in config or for each individual lamp in device edit of the lamp
Return to “Hue Lights”
