HomekitLink "All Devices Started" but none available on Home App
macguyincali
Post by macguyincali »
I'm a longtime HKLS user and really appreciate the hard work you've put into this plugin. It is a lifesaver. I recently installed the new version and have been having some issues. I've reinstalled the plugin a few times, made sure that Python 3 is installed and CLT as well. Not sure if I did those steps correctly, but the log shows Python 3.11.6 and Confirmed Library Installs have been successfully completed. All the bridges seem to be started and Operational according to the Indigo UI.
But when I go to Home app, there is No Response listed for all my HKLS devices. I have about 80 devices.
Here's the troubleshooting code:
HomeKitLink Siri ==============================================================================================================================================================================================
HomeKitLink Siri ==================================================================================== Logging info follows ====================================================================================
HomeKitLink Siri ================================================ Initializing New Plugin Session =================================================
HomeKitLink Siri Plugin name: HomeKitLink Siri
HomeKitLink Siri Plugin version: 0.6.75
HomeKitLink Siri Plugin ID: com.GlennNZ.indigoplugin.HomeKitLink-Siri
HomeKitLink Siri Plugin Path: /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin
HomeKitLink Siri Indigo version: 2024.2.0
HomeKitLink Siri Silicon version: arm64
HomeKitLink Siri Python version: 3.11.6 (v3.11.6:8b6ee5ba3b, Oct 2 2023, 11:18:21) [Clang 13.0.0 (clang-1300.0.29.30)]
HomeKitLink Siri Python Directory: /Library/Frameworks/Python.framework/Versions/3.11
HomeKitLink Siri FFmpeg : /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Packages/homekitlink_ffmpeg/ffmpeg_binaries/arm/ffmpeg
HomeKitLink Siri
HomeKitLink Siri ================================================== Contents of Library Install: ==================================================
HomeKitLink Siri Contents of 'pip-install-log-success.txt':
Collecting cryptography==41.0.7 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 1))
Obtaining dependency information for cryptography==41.0.7 from https://files.pythonhosted.org/packages ... l.metadata
Using cached cryptography-41.0.7-cp37-abi3-macosx_10_12_universal2.whl.metadata (5.2 kB)
Collecting homekitlink_ffmpeg (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 2))
Obtaining dependency information for homekitlink_ffmpeg from https://files.pythonhosted.org/packages ... l.metadata
Using cached homekitlink_ffmpeg-0.0.25-py3-none-any.whl.metadata (2.8 kB)
Collecting orjson==3.8.10 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 3))
Obtaining dependency information for orjson==3.8.10 from https://files.pythonhosted.org/packages ... l.metadata
Using cached orjson-3.8.10-cp311-cp311-macosx_11_0_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl.metadata (47 kB)
Collecting async_timeout==4.0.3 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 4))
Obtaining dependency information for async_timeout==4.0.3 from https://files.pythonhosted.org/packages ... l.metadata
Using cached async_timeout-4.0.3-py3-none-any.whl.metadata (4.2 kB)
Collecting aiofiles==23.2.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 5))
Obtaining dependency information for aiofiles==23.2.1 from https://files.pythonhosted.org/packages ... l.metadata
Using cached aiofiles-23.2.1-py3-none-any.whl.metadata (9.7 kB)
Collecting tlv8==0.10.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 6))
Using cached tlv8-0.10.0-py3-none-any.whl
Collecting base36==0.1.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 7))
Obtaining dependency information for base36==0.1.1 from https://files.pythonhosted.org/packages ... l.metadata
Using cached base36-0.1.1-py2.py3-none-any.whl.metadata (2.0 kB)
Collecting pyqrcode==1.2.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 8))
Using cached PyQRCode-1.2.1-py3-none-any.whl
Collecting slugify==0.0.1 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 9))
Using cached slugify-0.0.1-py3-none-any.whl
Collecting pypng==0.20220715.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 10))
Obtaining dependency information for pypng==0.20220715.0 from https://files.pythonhosted.org/packages ... l.metadata
Using cached pypng-0.20220715.0-py3-none-any.whl.metadata (13 kB)
Collecting h11==0.14.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 11))
Obtaining dependency information for h11==0.14.0 from https://files.pythonhosted.org/packages ... l.metadata
Using cached h11-0.14.0-py3-none-any.whl.metadata (8.2 kB)
Collecting zeroconf==0.131.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 12))
Using cached zeroconf-0.131.0-cp311-cp311-macosx_14_0_arm64.whl
Collecting chacha20poly1305-reuseable==0.12.0 (from -r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 13))
Using cached chacha20poly1305_reuseable-0.12.0-cp311-cp311-macosx_14_0_arm64.whl
Collecting cffi>=1.12 (from cryptography==41.0.7->-r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 1))
Obtaining dependency information for cffi>=1.12 from https://files.pythonhosted.org/packages ... l.metadata
Using cached cffi-1.17.1-cp311-cp311-macosx_11_0_arm64.whl.metadata (1.5 kB)
Collecting ifaddr>=0.1.7 (from zeroconf==0.131.0->-r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 12))
Obtaining dependency information for ifaddr>=0.1.7 from https://files.pythonhosted.org/packages ... l.metadata
Using cached ifaddr-0.2.0-py3-none-any.whl.metadata (4.9 kB)
Collecting pycparser (from cffi>=1.12->cryptography==41.0.7->-r /Library/Application Support/Perceptive Automation/Indigo 2024.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/requirements.txt (line 1))
Obtaining dependency information for pycparser from https://files.pythonhosted.org/packages ... l.metadata
Using cached pycparser-2.22-py3-none-any.whl.metadata (943 bytes)
Using cached cryptography-41.0.7-cp37-abi3-macosx_10_12_universal2.whl (5.3 MB)
Using cached orjson-3.8.10-cp311-cp311-macosx_11_0_x86_64.macosx_11_0_arm64.macosx_11_0_universal2.whl (237 kB)
Using cached async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Using cached aiofiles-23.2.1-py3-none-any.whl (15 kB)
Using cached base36-0.1.1-py2.py3-none-any.whl (3.5 kB)
Using cached pypng-0.20220715.0-py3-none-any.whl (58 kB)
Using cached h11-0.14.0-py3-none-any.whl (58 kB)
Using cached homekitlink_ffmpeg-0.0.25-py3-none-any.whl (45.1 MB)
Using cached cffi-1.17.1-cp311-cp311-macosx_11_0_arm64.whl (178 kB)
Using cached ifaddr-0.2.0-py3-none-any.whl (12 kB)
Using cached pycparser-2.22-py3-none-any.whl (117 kB)
Installing collected packages: tlv8, slugify, pyqrcode, pypng, ifaddr, base36, zeroconf, pycparser, orjson, homekitlink_ffmpeg, h11, async_timeout, aiofiles, cffi, cryptography, chacha20poly1305-reuseable
Successfully installed aiofiles-23.2.1 async_timeout-4.0.3 base36-0.1.1 cffi-1.17.1 chacha20poly1305-reuseable-0.12.0 cryptography-41.0.7 h11-0.14.0 homekitlink_ffmpeg-0.0.25 ifaddr-0.2.0 orjson-3.8.10 pycparser-2.22 pypng-0.20220715.0 pyqrcode-1.2.1 slugify-0.0.1 tlv8-0.10.0 zeroconf-0.131.0
HomeKitLink Siri ================================================ Xcode Command Line Tools Check: =================================================
HomeKitLink Siri ✅ Xcode Command Line Tools are needed. Checking that they are Installed
HomeKitLink Siri ✅ Xcode Command Line Tools are installed at: /Library/Developer/CommandLineTools
HomeKitLink Siri 🔍🔍🔍 Checking Library dependencies, downloading and/or compiling in tempdirectory, without installing. 🔍🔍🔍
HomeKitLink Siri ✅ All dependencies listed in 'requirements.txt' are available for installation.
HomeKitLink Siri 📝 Output:
HomeKitLink Siri ======================================================= Advanced Settings: =======================================================
HomeKitLink Siri Selected IP version: IPVersion.All
HomeKitLink Siri Select interfaces: InterfaceChoice.All
HomeKitLink Siri HKLS Advertised Ip address: None
HomeKitLink Siri HKLS Server Ipaddress: None
HomeKitLink Siri HKLS Advertised Ipaddress and HKLS Server Ipaddress are None, which is acceptable. The server will decide the best option.
HomeKitLink Siri ========================================================================= Device Bridges enabled and up and Running ==========================================================================
HomeKitLink Siri Bridge: 815815 : Indigo Id: 1355227261 Name: bedroom1 - ceiling fan - fan DeviceName: ceiling fan Type: Fan
HomeKitLink Siri Bridge: 655435 : Indigo Id: 179966269 Name: bedroom1 - ceiling fan - light DeviceName: ceiling fan light Type: LightBulb
HomeKitLink Siri Bridge: 749002 : Indigo Id: 1096485315 Name: bedroom2 - ceiling fan - fan DeviceName: ceiling fan Type: Fan
HomeKitLink Siri Bridge: 381861 : Indigo Id: 1213341169 Name: bedroom2 - ceiling fan - light DeviceName: ceiling fan light Type: LightBulb
HomeKitLink Siri Bridge: 788784 : Indigo Id: 853469048 Name: camera - backyard gate camera DeviceName: backyard gate Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 683040 : Indigo Id: 506508713 Name: camera - bbq area DeviceName: bbq area Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 103378 : Indigo Id: 703680478 Name: camera - foyer DeviceName: camera Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 764656 : Indigo Id: 803951342 Name: camera - front porch DeviceName: front porch Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 825351 : Indigo Id: 64805133 Name: camera - horse arena DeviceName: horse arena Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 548091 : Indigo Id: 585102598 Name: camera - living room DeviceName: camera - living room Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 497219 : Indigo Id: 1174393644 Name: camera - main driveway DeviceName: driveway camera Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 235106 : Indigo Id: 1377578854 Name: camera - mudroom DeviceName: mudroom Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 753419 : Indigo Id: 668800514 Name: camera - sage hill DeviceName: Sage Hill Camera Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 753419 : Indigo Id: 533493327 Name: camera - parking area DeviceName: camera - parking area - PTZ Type: SecuritySpyCamera
HomeKitLink Siri Bridge: 454088 : Indigo Id: 1024788150 Name: office - closet door - left sensor DeviceName: closet sensor left Type: ContactSensor
HomeKitLink Siri Bridge: 228093 : Indigo Id: 1315171396 Name: dining room - chandelier DeviceName: chandelier Type: LightBulb
HomeKitLink Siri Bridge: 546958 : Indigo Id: 47235315 Name: dining room - outlet - lower - lamp DeviceName: lower outlet Type: Outlet
HomeKitLink Siri Bridge: 424469 : Indigo Id: 106139576 Name: dining room - outlet - upper - lamp DeviceName: lower outlet Type: Outlet
HomeKitLink Siri Bridge: 123808 : Indigo Id: 135016854 Name: dining room - cans - keypad DeviceName: overhead Type: LightBulb
HomeKitLink Siri Bridge: 832781 : Indigo Id: 262004201 Name: powder room fan DeviceName: hallway - powder room fan Type: Switch
HomeKitLink Siri Bridge: 246522 : Indigo Id: 805918025 Name: driveway sensor for homekit DeviceName: driveway1 Type: MotionSensor
HomeKitLink Siri Bridge: 920151 : Indigo Id: 1652476521 Name: outdoor - dakota - motion sensor 3 DeviceName: dirt driveway - motion sensor Type: MotionSensor
HomeKitLink Siri Bridge: 793717 : Indigo Id: 959080348 Name: main driveway camera - zoom / home DeviceName: driveway zoom Type: Switch
HomeKitLink Siri Bridge: 289443 : Indigo Id: 123251084 Name: exterior - back porch cans - (master) DeviceName: back porch lights Type: LightBulb
HomeKitLink Siri Bridge: 556605 : Indigo Id: 1728880324 Name: exterior - rear - garage switch (master) DeviceName: behind house Type: LightBulb
HomeKitLink Siri Bridge: 630371 : Indigo Id: 1628097146 Name: exterior - christmas lights DeviceName: christmas lights Type: Switch
HomeKitLink Siri Bridge: 692793 : Indigo Id: 528838700 Name: exterior - front lights - garage (master) DeviceName: front lights Type: LightBulb
HomeKitLink Siri Bridge: 659610 : Indigo Id: 600087799 Name: exterior - parking entry - light DeviceName: parking area Type: Switch
HomeKitLink Siri Bridge: 308688 : Indigo Id: 361748552 Name: exterior - side yard - sliding door (master) DeviceName: backyard Type: Switch
HomeKitLink Siri Bridge: 747060 : Indigo Id: 1515928454 Name: kitchen - hallway - main DeviceName: hallway Type: LightBulb
HomeKitLink Siri Bridge: 315630 : Indigo Id: 1463105730 Name: family room - home theater cans - main DeviceName: home theater lights Type: LightBulb
HomeKitLink Siri Bridge: 216793 : Indigo Id: 1173630953 Name: family room - main cans DeviceName: main lights Type: LightBulb
HomeKitLink Siri Bridge: 770931 : Indigo Id: 97903025 Name: family room - office nook - dimmer DeviceName: office nook Type: LightBulb
HomeKitLink Siri Bridge: 108520 : Indigo Id: 1290222001 Name: family room - center cans - link hallway DeviceName: overhead lights Type: LightBulb
HomeKitLink Siri Bridge: 812115 : Indigo Id: 1156357916 Name: family room - window cans - keypad DeviceName: window lights Type: LightBulb
HomeKitLink Siri Bridge: 100629 : Indigo Id: 371908438 Name: foyer - christmas tree lamplinc DeviceName: christmas tree Type: LightBulb
HomeKitLink Siri Bridge: 245324 : Indigo Id: 1625969212 Name: foyer - lamplinc DeviceName: foyer lamp Type: LightBulb
HomeKitLink Siri Bridge: 605368 : Indigo Id: 893354435 Name: foyer - christmas tree plug DeviceName: lamp light Type: LightBulb_switch
HomeKitLink Siri Bridge: 237485 : Indigo Id: 949769418 Name: exterior - front gate lights DeviceName: front gate lights Type: LightBulb
HomeKitLink Siri Bridge: 626366 : Indigo Id: 876052134 Name: garage - overhead - keypad (mstr) DeviceName: garage lights Type: LightBulb
HomeKitLink Siri Bridge: 461416 : Indigo Id: 1990398500 Name: gate sensor - homekit DeviceName: gate sensor - switch Type: Switch
HomeKitLink Siri Bridge: 766590 : Indigo Id: 811367598 Name: guest bedroom - bathroom light DeviceName: bathroom light Type: LightBulb
HomeKitLink Siri Bridge: 449649 : Indigo Id: 1300389138 Name: pacos room - floor lamp DeviceName: christmas tree lights Type: LightBulb
HomeKitLink Siri Bridge: 896207 : Indigo Id: 796625587 Name: upstairs hallway landing - back stair (master) DeviceName: landing Type: LightBulb
HomeKitLink Siri Bridge: 532931 : Indigo Id: 709904927 Name: backstair chandelier - bottom (master) DeviceName: backstairs chandlier Type: LightBulb
HomeKitLink Siri Bridge: 840470 : Indigo Id: 896912358 Name: upstairs hallway north - backstair (master) DeviceName: north hallway Type: LightBulb
HomeKitLink Siri Bridge: 869241 : Indigo Id: 140789901 Name: landing - dimmer DeviceName: main stairs landing Type: LightBulb
HomeKitLink Siri Bridge: 961647 : Indigo Id: 1002558798 Name: downstairs hallway - dimmer (master) DeviceName: north hallway Type: LightBulb
HomeKitLink Siri Bridge: 731852 : Indigo Id: 566391187 Name: kitchen - cabinet lights DeviceName: cabinet lights Type: Switch
HomeKitLink Siri Bridge: 312588 : Indigo Id: 981535447 Name: kitchen - cans DeviceName: overhead lights Type: LightBulb
HomeKitLink Siri Bridge: 707991 : Indigo Id: 76577905 Name: kitchen - chandelier DeviceName: chandelier Type: LightBulb
HomeKitLink Siri Bridge: 621096 : Indigo Id: 130333740 Name: kitchen - switch hallway DeviceName: hallway Type: LightBulb
HomeKitLink Siri Bridge: 580234 : Indigo Id: 1215501483 Name: kitchen - hallway - link DeviceName: kitchen - hallway - link Type: LightBulb_switch
HomeKitLink Siri Bridge: 367863 : Indigo Id: 754086004 Name: kitchen - hutch cans DeviceName: hutch Type: LightBulb
HomeKitLink Siri Bridge: 581658 : Indigo Id: 1671911306 Name: kitchen - island pendants (master switch) DeviceName: kitchen - island pendants -master switch- Type: LightBulb_switch
HomeKitLink Siri Bridge: 674504 : Indigo Id: 849588548 Name: kitchen - pantry DeviceName: kitchen - pantry Type: Switch
HomeKitLink Siri Bridge: 225156 : Indigo Id: 1083727137 Name: laundry room - fan DeviceName: fan Type: Switch
HomeKitLink Siri Bridge: 493005 : Indigo Id: 1919983289 Name: laundry room - light DeviceName: light Type: Switch
HomeKitLink Siri Bridge: 537498 : Indigo Id: 1829149004 Name: living room - chandelier DeviceName: chandelier Type: LightBulb
HomeKitLink Siri Bridge: 868598 : Indigo Id: 28798983 Name: living room - lamp DeviceName: living room - lamp Type: LightBulb
HomeKitLink Siri Bridge: 142118 : Indigo Id: 1664711325 Name: living room - wall lights DeviceName: wall lights Type: LightBulb
HomeKitLink Siri Bridge: 953637 : Indigo Id: 112932862 Name: master bedroom - fan - Light DeviceName: fan flight Type: LightBulb
HomeKitLink Siri Bridge: 532551 : Indigo Id: 1350051905 Name: outdoor - dakota - driveway motion sensor DeviceName: main driveway motion Type: MotionSensor
HomeKitLink Siri Bridge: 335502 : Indigo Id: 1619627613 Name: master bedroom - fan - Fan DeviceName: fan Type: Fan
HomeKitLink Siri Bridge: 966251 : Indigo Id: 890120401 Name: master bedroom - gigi's side table DeviceName: gigi's side table Type: LightBulb
HomeKitLink Siri Bridge: 729059 : Indigo Id: 1843085420 Name: master bedroom - side table - JP DeviceName: jp's side table Type: LightBulb
HomeKitLink Siri Bridge: 538060 : Indigo Id: 914316165 Name: master bedroom -sitting area DeviceName: sitting area Type: LightBulb
HomeKitLink Siri Bridge: 910744 : Indigo Id: 901221879 Name: mudroom - butler under cabinet light DeviceName: cabinet lights Type: Switch
HomeKitLink Siri Bridge: 887186 : Indigo Id: 124049880 Name: mudroom - motion sensor DeviceName: motion sensor Type: MotionSensor
HomeKitLink Siri Bridge: 840218 : Indigo Id: 4046876 Name: mudroom lights - garage (master) DeviceName: overhead Type: LightBulb
HomeKitLink Siri Bridge: 283983 : Indigo Id: 797081764 Name: mudroom - pantry DeviceName: storage closet Type: LightBulb
HomeKitLink Siri Bridge: 695855 : Indigo Id: 872641177 Name: Arm or Disarm Camera - office DeviceName: Camera - Office Type: Switch
HomeKitLink Siri Bridge: 683925 : Indigo Id: 1196841345 Name: office - ceiling fan - fan DeviceName: Ceiling Fan Type: Fan
HomeKitLink Siri Bridge: 986856 : Indigo Id: 1338615225 Name: office - closet door - right sensor DeviceName: closet door - right Type: ContactSensor
HomeKitLink Siri Bridge: 935367 : Indigo Id: 340903198 Name: office - closet exhaust fan DeviceName: exhaust fan - office Type: Fan
HomeKitLink Siri Bridge: 749233 : Indigo Id: 837645101 Name: office - heater DeviceName: heater Type: Outlet
HomeKitLink Siri Bridge: 607467 : Indigo Id: 1087727945 Name: office - ceiling fan - light DeviceName: ceiling light Type: LightBulb
HomeKitLink Siri Bridge: 702226 : Indigo Id: 1347905167 Name: Arm or Disarm Camera - driveway DeviceName: Arm Cameras Type: Switch
HomeKitLink Siri Bridge: 601395 : Indigo Id: 695680621 Name: SecuritySpy DeviceName: Video Server Type: Switch
HomeKitLink Siri Bridge: 570436 : Indigo Id: 437639878 Name: parking area camera - backyard / home DeviceName: zoom to backyard Type: Switch
macguyincali
Re: HomekitLink "All Devices Started" but none available on Home App
I'm getting the following error message:
Error plugin "HomeKitLink Siri 0.6.75" (pid 70945) unexpectedly stopped -- restarting in 5 seconds
Error plugin "Web Server 2024.2.0" (pid 70698) unexpectedly stopped -- restarting in 5 seconds
Reloading plugin "HomeKitLink Siri 0.6.75" using API v3.4
Starting plugin "HomeKitLink Siri 0.6.75" (pid 71957)
HomeKitLink Siri Error (plugin.py: Function: Plugin_getter_callback line: 2987): Exception : Message : Plugin Setter Exception
HomeKitLink Siri Error Traceback:
File "plugin.py", line 2712, in Plugin_getter_callback
indigodevice = indigo.devices[accessoryself.indigodeviceid]
HomeKitLink Siri Error Error in plugin execution:
RuntimeError: ServerCommunicationError -- timeout waiting for response
Exc_info: (<class 'RuntimeError'>, RuntimeError('ServerCommunicationError -- timeout waiting for response'), <traceback object at 0x118ab3900>)
Exc_Text: Traceback (most recent call last):
Stack_info: None
GlennNZ
Post by GlennNZ »
Hi
Quick reply from an airport …. Well done on including all this logging!
So was working and then stopped with new version?
Please confirm:
First standouts
You should never install python3 for any indigo plugin - a 2nd install may cause issues
There is nothing standout in the logs - except that last error messaging suggests that the Mac computer is not accessible?
Firewall, antivirus etc.?
The above would be the most likely:
Finally you could try changing the Ipversion to IPv4 as that has been a recent change:
GlennNZ
Post by GlennNZ »
GlennNZ wrote:Hi
Please confirm:
First standouts
How are you going with this?
Having a longer look at your logs - you do have a lot of HomekitLink Bridges.
It’s seems some bridges only have one or 2 devices attached to it?
One Bridge - can have up to 100 Indigo devices attached to it.
Multiple bridges will work - but can create overhead and each bridge uses a new port, and also needs to be QR code paired.
Glenn
Return to “HomeKitLink Siri”
