Interest in Next-gen Shelly Devices
Plugin to control second generation Shelly devices over the MQTT protocol.
Colly
Re: Interest in Next-gen Shelly Devices
Post by Colly »
siclark wrote:I have a UK plug and have it working fine with this plug in. Shows power etc. not sure what’s missing.
Interesting - let me look into that so.
aaronlionsheep
Post by aaronlionsheep »
Did you pick the "standard" Shelly Plus US model? I believe all the underlying functionality would be the same, but the UK and EU models have special "UI" components that the US does not have.
siclark
Post by siclark »
I have this one
https://www.shelly.com/en-de/products/p ... us-plug-uk
aaronlionsheep
I have this one
Sorry, I meant when picking the model when setting the device up with the plugin. Did you set it up as a Shelly Plus Plug US/IT?
Screenshot 2023-10-04 at 4.53.42 PM.png (30.17 KiB) Viewed 4791 times
siclark
Post by siclark »
Took a little while to see how to tell, in Define and Sync but yes, it’s setup as US/IT device. I don’t recall doing that or seeing an option.
Happy with how it’s working so far.
tazswe
Post by tazswe »
Have anybody tested any of the Shelly blu sensors ?
If I understand it right you should be able to connect them with the ahellyNg.
Skickat från min SM-T720 via Tapatalk
aaronlionsheep
I released version 1.1.0 and it now supports the Pro 4PM (thanks berkinet), the 1/1PM mini devices, and the Plus S and Plug UK.
I didn't add support for the UI component of the S and UK plugs, but I can if that is desired.
https://www.indigodomo.com/pluginstore/290/
https://github.com/AaronLionsheep/Shell ... /tag/1.1.0
aaronlionsheep
tazswe wrote:Have anybody tested any of the Shelly blu sensors ?
I haven't seen any documentation on how the BLU sensors will work. I know they pair to a Shelly device, so it might be possible to create a Shelly script that relays the information over MQTT. The plugin would need some additional support for that though. The plugin is able to control the contents of a script, so if BLU sensors are desired, then its possible the plugin could maintain a Shelly script that relays the BLU device information over MQTT back to the plugin in a format it expects.
Colly
Post by Colly »
I have 2 configured in Indigo via the Home Assistant Agent plugin. I've just played about with them in my office. They are connecting directly with the rPi. I would hope to connect them to a Shelly Plus device and have them communicate directly with Indigo at some time in the future..... :)
Colly
Post by Colly »
Hi Aaron,
I've added a few more Shelly devices to my test setup. These are:
Shelly Plus 1PM Mini
Shelly Plus PM Mini
Shelly 1PM Mini Gen 3
It would be great to have these fully supported by your plugin. Please reach out if I can help with testing.
pgershon
Post by pgershon »
Hi Aaron - Any plans to officially support the shelly wall dimmer?
Comment on the Shelly blue beacons:
The battery life is very bad. About 2 weeks.
The issue is mechanical. The battery is loose in the device and hence the device restarts frequently and that drains the battery.
There is a trick to rectify this: put a piece of tape under the connector to make it have a stable contact to the battery.
Ps the Shelly blu devices are fully supported in pibeacon.
Return to “ShellyNGMQTT”
