Added features / changes in v2022.168.79 @ 2023-07-12
1. added state: "lastBatteryReplaced" to devices that have a batteryLevel state.
it shows the date-time when the battery level went back from < 100 to 100 %
with this you can see when you replaced the battery.
this is also shown in the battery level report in menue / print various ...
dded features / changes in v2022.168.82 @ 2023-07-14
1. added state: "lastBatteryReplaced" ...
.. now also supports beacons that do not broadcast their battery level, but also beacons that
have to be queried to get their battery status eg iTrack, musegear ..
added features / changes in v2022.169.84 @ 2023-08-20
1. general maintenance release
2. added battery level to veg trug beacons
3. added menu action to reset or calibrate co2 sensors sensirion scd30
added device states to reflect calibration status
added features / changes in v2022.170.86 @ 2023-08-23
1. fixed bug introduced in v2022.169.84
changed values (5 min, 10 min, 1 hour ...) for temp humidity .. values did not update
2. added sensirion scd40 41.. sensortypes they measure CO2 temp and hunidity, using i2c
please get one with its own voltage regulator (eg adafruit.
they draw 200mA when measuring and require a very stable voltage.
And connect the V pin to +5V make sure you set V-i2c to 3V on the board)
not fully tested, pre version
3. optimized pi software updates
added features / changes in v2022.171.87 @ 2023-08-30
1. added option to use any GPIO on the rpi to read one wire sensor temperature (ie 18db20)
you can now use all gpios to read multiple onewire sensors each
so with > 10 gpios and 10 onewire sensors on each gpio it can go > 100.
but reading one sensor takes ~ 1 secs. So for 100 that would take 100 secs.
you need to add at the bottom of /boot/config.txt:
dtoverlay=w1-gpio
dtparam=gpiopin=26 <-- this will be busmaster 4
dtoverlay=w1-gpio
dtparam=gpiopin=5
dtoverlay=w1-gpio
dtparam=gpiopin=17
dtoverlay=w1-gpio
dtparam=gpiopin=4 <-- this will be busmaster 1
that will result in GPIO 4,17,5, 26 be reading onewire temp sensors
to edit config.txt do sudo nano /boot/config.txt and add the lines
with control-o and control-x you can save and exit nano editor
then reboot
with ls -o /sys/bus/w1/devices/ you can check if the busmaster channels 1.. 4 in this case are ready. you should see something like this:
lrwxrwxrwx 1 root 0 Aug 29 02:06 28-000d770e64ff -> ../../../devices/w1_bus_master4/28-000d770e64ff
lrwxrwxrwx 1 root 0 Aug 29 02:06 28-3ce10457da57 -> ../../../devices/w1_bus_master1/28-3ce10457da57
lrwxrwxrwx 1 root 0 Aug 29 02:06 28-0516b33a17ff -> ../../../devices/w1_bus_master3/28-0516b33a17ff
lrwxrwxrwx 1 root 0 Aug 29 02:06 28-3ce104570a38 -> ../../../devices/w1_bus_master2/28-3ce104570a38
lrwxrwxrwx 1 root 0 Aug 29 02:06 w1_bus_master1 -> ../../../devices/w1_bus_master1
where 28-3ce10457da57 are the IDs of the one wire sensors
2. added "lastBatteryReplaced" state to isensor devices
they will show when the state "lowVoltage" went from empty to false or from true to false, ie when a new battery was added or when
3. fixed bug for iSensor On devices (door button): the dev state onOffstate ui value was always "on". the onOffState itself was correct.Re: piBeacon: 3- presence monitoring download
added features / changes in v2022.171.88 @ 2023-11-07
highlight: With eg = 10 gpios and 10 onewire sensors on each gpio the rpi can read 100 one wire sensors
you can now use all gpios (20+) to read multiple onewire sensors each
you need to set the GPIOs in device edit for the RPI as it is set for all onewire sensors on that RPI
With eg = 10 gpios and 10 onewire sensors on each gpio it can read 100 sensors
with ls -o /sys/bus/w1/devices/ you can check if the busmaster channels are ok. You should see something like this:
added option to use a relay to reset the onewire setup (eg to disconnect power from the onewire sensors). Set this in RPI device edit
added option to reboot the RPI if reading onewire sensors is not successfull for xx read tries
It takes about 1 secs to read a sensor. With 10 sensors on one GPIO it would take about 11 secs to read 100 sensors with 10 GPIOs
2. fixed bug for iSensor On devices (door button): the dev state onOffstate ui value was always "on". the onOffState itself was correct.
3. added "lastBatteryReplaced" state to isensor devices
4. changed state lastBatteryUpdate:
was: if new batterylevel ==100 and old < 100: set lastBatteryUpdate to current date
now: added if lastBatteryUpdate is empty set to current date.
if the battery level is less than 100 when you start the plugin you might need to wait for a loooong time before this state gets set ie if the battery live is 2 years
this now gives you at east some date (when you load this plugin)
5. added device types:
MMK beacons, must be configured with iphone app KBeaconpro. These devices transmit TML (google def) packages
they can be configured to send different packges of data.
you need to setup these diffent packages (called slots in KBeaconpro)
add one slot for each package, single, double, long press and if available for Temp/hum/acceleration
set Namespace ID to 1 for single press, 2 for double press, 3 for long press
then set trigger advertisement to "trigger only" and "trigger by" to single, double long press respectively
A) SOS button can be used for eg a door buton, indigo can then trigger on button press, double press, long press
B) rechargeable beacon with ALSO temp,hum,acceleration info.
It is a little tricky to setup but works well
added features / changes in v2022.173.89 @ 2024-01-13
1. added Thermopro beacon & sensors
2. added Shelly BLU button and Motion and Window sensor
this is a newer line of SHELLY products that use BLE to communicate. They Broadcast various infos:
battery level, button:press/short/double/tripple/long, illuminance (in Lux), door open/closed/ rotation, motion.
some of them can beep, but only thru the shelly phone app shelly BLU
YOU MUST SETUP EACH DEVICE IN THAT APP AND ENABLE broadcast (BC) and disable encryption
you can add them with menu/accept new beacons.. selcet the proper shelly dev type.
then a beacon device is created as well as a sensor device that shows the open/close montion/. button press. values.
you need to edit the created sensor device to select the proper RPi to be used to trac the button info. you can select several RPi to do this.
with a single shelly button device you can trigger up to 4 actions in indigo. (press/double/tripple/long press)
trigger on dev/state[on/offstate] == True, then with condition dev/state[currentEvntType] == press/ double_press/ tripple_press / long_press
then you can have ONE button that can eg: open house/ garage/ light on/ away
the beacon behaves like a regular beacon (although it broadcast alive only every 8 secs, otehr beacosn every second or faster)
it hence can be used as "present" indicator like all otehr beacons
3. fixed state indicator red/green/grey for delayed action (eg button press goes green but never grey.. afetr x seconds as intended). It was always set to sensor ON
!!! IMPORTANT !!!
4. fixed issue for python2 installs on rpi w older ssd image: removed new format statement that only work under py3: f" {xx}" replaced by " {}.format(xx)"
if you are using an older RPI image w/o python3 as default (older than 2022) PLEASE install this version. beacon detection will not work otherwise
added features / changes in v2022.174.89 @ 2024-01-22
1. now supports RPI opsys bookworm - 32 bit version, released in Dec 2023
it was a little bit of work to make everything work again.
behaviour of links between programs programs changed, ie sudo python xxx.py now requires sudo python xx.py & to invoke
previously xxx.py canceled the sudo process w/o impaction xxx.py. That is not true anymore. It is used quit extenisveley in pibeacon
Several other chnages required modigications
NO python2 programs are available, everything is now py3 o the new RPI OP sys
2. you now can use the regular RPI SD IMAGE INSTALLER tool to create your SD.
see >>> https://forums.indigodomo.com/viewtopic.php?f=187&t=15482&p=109421#p109421 <<<
The plugin will auto install all needed software and set all required configs on the RPI
==> I will not supply a precanned image anymore to be copied onto the SD
you can now create that yourself. It is actually more user friendly.
In the future I will need to stop supporting py2 compatibility.
That means new plugin versions MIGHT not run on older SD versions anymore.
This one still does, but might be the last one. I hope you understand.Re: piBeacon: 3- presence monitoring download
added features / changes in v2022.174.90 @ 2024-01-31
1. fixed menu/ send .. to rpi/ "restart master on rpi through ssh" did not work
2. added a check around debugRPI, it now makes sure that the variable is properly set, even if not initialized
added features / changes in v2022.175.90 @ 2024-02-13
1. added precision temperature sensor tmp117
2. some py3 fixes on rpi, to import adafruit libraries
added features / changes in v2022.175.91 @ 2024-02-13
1. fixed for older rpi images install of tmp177 library
the pip3 environment changed with os v rpi of 12
with v 11 it is
sudo pip3 install adafruit-circuitpython-tmp117
with v 12:
sudo pip3 install --break-system-packages adafruit-circuitpython-tmp117
in how to .. ssd there is cn important change:
previously it stated which RPI you select to download the proper OS doe not matter, instead:
1. RPI device >> IT MATTERS WHICH RPI YOU SELECT<< not all OS run on all RPI, older RPi do not run on OS 12, bookworm does not run on rpi0w first version, RPI1, and RPI2
added features / changes in v2022.175.93 @ 2024-03-26
1. NaN == "Not a Number"
Replaced any "NaN" received from an RPI sensor to -9999
This is not a problem for any std pibeacon or sensor data. Only if you use a user extension (your own program) that can create a NaN.
A sensor might return an error when reading , that in turn could lead to a NaN.
In all data from std sensors I have converted a read error to a "bad Sensor" message or a -999 or a -9999 data element
Indigo has serious issues with NaN data in some funtions, hence the new filter.
This has happened to one user and if you dont know about it you are not impacted.
2. Added Switchbot curtain version 3 support
The version 3 has a changed ble handler (0x08->0x10) and a new device id (c -> { )
added features / changes in v2022.178.101 @ 2024-07-03
1. reduced number of dev states updates if value not changed
==> dev state "last updated" now chnages only when a real dev state value was changed
2. reduced # of beacon_is_back messages,
3. restructured beaconloop.py on rpi, reduced cpu comsumption by ~25%. That can have an impact if you are using an rpi0, for a rpi3++ likely not a big impact.
4. optimized restart of beaconloop.py on RPi, in case hcidump does not start
5. added accept beacons: >>jaalee w name tag<<. some Jaalee beacons send out a message that contains jaalee as a string (mfg info)
6. added support for iTrack (musegear) glasses beacon. This beacon can be mounted on your glasses. Indigo can beep it. It is very lite, has to be recharged ~ every 3-4 weeks
7. added support for >>meeblue M52<< beacons, The battery should last several years, and it has a button that can be used in indigo to trigger an action:
-1. start beacon (remove battery strip)
-2. start app "checkBlue" on iPhone
-3. press button for 3 secs, led should blink blue
-4. put beacon next to phone
-5. you should see “meeblue” and connectable true
-6. click on beacon
-7. after 10 secs you should see “configure Multiple Parameter”, click on it.. it will take 30 secs
-8. click advertising mode: pick "Advertise Real-Time Data", everything else is off
-9. back, you should see Advertising mode = 4
-10. set "Button Detect" enabled
-11. click back at top, back at top, settings are saved and the beacon is not connected anymore. it should start broadcasting data now
---- 2 types: regular broadcast with mac number, battery info, and when button is pressed (blue led blinking) another package with "meeblue" mfg id for about 15 secs. These other packages are used to detect the button press
-12. In indigo menu/ accept new beacons: select meebue m52.
---- You should see 2 new devices after < 1 minute in indigo. One is the beacon(up/down/expired), the second the button(on/off). Both show battery level.
-6. click on beacon
