Unable to subscribe to a topic with a comma in its name
I have some topics that have names that contain commas. When I attempt to subscribe to one of those topics, I get an error and it erases the entire subscribed topic list. I suspect internally the plugin is using commas to separate topic names, and this breaks when the topic name contains a comma.
- FlyingDiver
Re: Unable to subscribe to a topic with a comma in its name
Example?
- FlyingDiver
And which plugin are you actually using? Connector?
MQTTConnector
Try to add subscription to topic "sensor/emvue/261535-1,2,3" gives this error:
Then erases all the subscribed topics from the list.
Error (client) illegal string for list ID subscriptions (ignoring): 0:sensor/emvue/261535-1,2,3- FlyingDiver
I'm not using commas as a delimiter, but something else is choking on it. I'll have to look into it.
Thanks.
I am working around this by subscribing to "sensor/emvue/#" but that's a ton of messages the plugin is now processing for no reason. Background is I am publishing energy usage from Emporia devices every 15 seconds, and I have a lot of devices. Their smart plugs have that "-1,2,3" at the end of their device names.
- FlyingDiver
Looks to me like this is some sort of bug or limitation in the indigo.Dict class. It's erroring before it even gets to my code.
- FlyingDiver
Release 2023.2.1 in plugin store. See viewtopic.php?f=316&t=27797
That fixed it for me. Thank you so much for the quick turnaround!
