Error Message Setting up Plugin
pdz
Post by pdz »
When I try to set up the plugin, I get an error message, "Error validating fields. Hover over the red field labels above to see the error reason," but there are no red fields in the plugin! What am I doing wrong? Thank you, Phil
Plugin Error Message.png (178.44 KiB) Viewed 1359 times
GlennNZ
Re: Error Message Setting up Plugin
Post by GlennNZ »
Thats really odd.
I just checked the code - & as per usual (despite the age) I don’t do much entry validation - preferring to error reporting later.
There isn’t any validation that occurs for the Plugin Config box - simple return (True, errorsDict) = which is empty.
So ?
Either really strange version ? Would check on latest, python3 version
Something up with plugin preferences? Could try deleting prefenences for this specific plugin, and reloading.
Perhaps something happened with installing (re-download - check latest version and reinstall)
Alternatively something else I haven’t considered - in which case could consider ignoring.. for the moment.
Edit:
I have updated plugin store version to latest 0.6.8
Was a prior pre-release 0.6.5
None of them particular address this issue - which I still suspect is probably install related - but hopefully reinstalling new version overcomes.
pdz
Post by pdz »
Thank you! Installing the new version instantly fixed the problem. I can now see that my array is generating power and was able to generate all 50 panels individually. Phil
Different Computers
Post by Different Computers »
might be worth reporting that I had this exact issue with the current 0.6.8 version. However, ignoring the warning let me create the device.
Return to “Enphase Envoy Solar”
