I've just updated to Indigo 2023.2 with plugin 0.6.60 and when the HomeKitLink plugin is loading I'm getting this error:
HomeKitLink Siri Starting accessory HomeKitLink Bridge 769980 with advertised addresses ['192.168.1.10'] with port 51831.
HomeKitLink Siri Error (HomeKitDevices.py: Function: get_motion line: 2306): Error : Message : MotionSensor: Indigo DeviceID 1870655184. Error: Value returned is not True/False.
HomeKitLink Siri Error (HomeKitDevices.py: Function: get_motion line: 2306): Error : Message : MotionSensor: Indigo DeviceID 1870655184. Error: Value returned is not True/False.I tried turning on debug options to submit with this, but ended up getting streams of what seemed like irrelevant data. If this is needed can you tell me which options should be enabled?
Here's the device properties in case it's of any use:
batteryLevel : None
buttonGroupCount : 0
configured : True
description : DSC Zone 05 - Wired
deviceTypeId : alarmZone
displayStateId : state
displayStateImageSel : MotionSensor
displayStateValRaw : closed
displayStateValUi : closed
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1039530962
com.GlennNZ.indigoplugin.HomeKitLink-Siri : (dict)
HomeKit_audioSelector : false (bool)
HomeKit_bridgeUniqueID : 503716 (integer)
HomeKit_deviceSubtype : MotionSensor (string)
HomeKit_inverseSelector : false (bool)
HomeKit_publishDevice : true (bool)
HomeKit_tempSelector : false (bool)
homekit-name : Motion (string)
com.frightideas.indigoplugin.dscAlarm : (dict)
Elem : (string)
occupancyGroup : 0 (integer)
var : None (empty)
zoneLogChanges : true (bool)
zoneNumber : 5 (string)
zonePartition : 1 (string)
zoneType : zoneTypeMotion (string)
lastChanged : 2024-01-25 01:33:22
lastSuccessfulComm : 2024-01-25 01:33:22
model : Alarm Zone
name : Lounge - Motion Sensor
ownerProps : com.frightideas.indigoplugin.dscAlarm : (dict)
Elem : (string)
var : None (empty)
pluginId : com.frightideas.indigoplugin.dscAlarm
protocol : Plugin
remoteDisplay : True
states : States : (dict)
LastChangedShort : 2m (string)
LastChangedTimer : 2 (integer)
bypass : nobypass (string)
bypass.bypassed : false (bool)
bypass.nobypass : true (bool)
state : closed (string)
state.closed : true (bool)
state.open : false (bool)
state.tripped : false (bool)
subModel :
subType :
supportsAllOff : False
supportsOnState : False
supportsStatusRequest : False
version : None
