does roon b1353 work with the plugin?
dtich
Post by dtich »
they've switched to server/client architecture with this build. don't want to update roon if it breaks the plugin. anyone try it yet, or have any info?
thx!
autolog
Re: does roon b1353 work with the plugin?
Post by autolog »
dtich wrote:they've switched to server/client architecture with this build. don't want to update roon if it breaks the plugin. anyone try it yet, or have any info?
Yes, it does. :)
You may have to update the Roon Core Port in the plugin configuration.
You can find the required port number in the Roon App by navigating to Settings > Display. The required port number is shown as part of the Web display URL.
You may need to reauthorise the extension in Roo n
dtich
Post by dtich »
oh--that doesn't sound so broken, if it just needs a tweak to the config. if that's true i'll do the update.
thanks jon~!
Return to “Roon Controller”
