Unauthorized warning
Wed Oct 11, 2023 2:19 pm
Ironshel offline
After using this plugin for many months, out of the blue I am consistently getting this error message:
MyQ Warning Error logging into MyQ server: Error requesting data from https://partner-identity.myq-cloud.com/connect/token: 401 - Unauthorized
Has something change with the API? My credentials still work. The MYQ app on my phone still works. The Indigo plugin doesn't seem to work any more and always returns this same warning.
Wed Oct 11, 2023 2:22 pm
Re: Unauthorized warning
Yes, MyQ has broken the API again. If/when the library developers figure out a fix, I'll post an update. Until then, it's broke.
My new house will have Alladin Genie openers. I'm tired of this crap.
Thu Oct 12, 2023 8:02 pm
sarahcat offline
MyQ API problem
Hi Joe,
I was about to update to Indigo 2023.1.0, but there is a caveat about Python 2 scripts no longer being supported. For whatever reason, my MyQ is still working, but despite the API problem, I didn't wish to upgrade Indigo until I asked if you had used Python and which version for the MyQ Plugin.
Thu Oct 12, 2023 8:04 pm
Re: MyQ API problem
sarahcat wrote:
Hi Joe,
All plugin versions since 2022.0.0 have been Python3.
Sat Oct 14, 2023 6:09 pm
If you're brave, you can use an unreleased patch to the MyQ library to address this issue. In Terminal on the Indigo server system, do:
pip3 uninstall pymyq
pip3 install git+https://github.com/arraylabs/pymyq.git@refs/pull/188/head
It seems to work on my system.
Sat Oct 14, 2023 6:17 pm
You will also need to update to plugin version 2022.0.4.
