New version python 3 compatible
siclark
Re: New version python 3 compatible
Post by siclark »
neilk wrote:Morning - It maybe the plugin is on strike like most of the UK train network (and suspect it may be related) but got this in my logs today
 UK Trains Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 1033, in runConcurrentThread
type: name 'errorFile' is not defined
   UK Trains Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Neil
Ah. I've seen that occasionally. I think the reference to the error file to write errors to file is missing. Somehow I didn't have any in testing so never saw that error. I'll try and have a look soon but so far seems to be limited in impact and will return data once the some is available.
neilk
Post by neilk »
Thanks - not really an issue as you say it doesn't seem to impact anything so no panic at all.
Neil
siclark
Post by siclark »
I have somewhat belatedly updated a version which should in theory publish errors out to a file, and not throw that error if it can't find it. Fingers crossed it works.
Return to “iTravel”
