I'm seeing this regularly in the Indigo log:
Web Server Warning undefined page for request /AndroidClientHelper/updateAndroidDeviceStates from [my external IP]Code: Select all
Mar 31, 2023 at 9:30:37 PM
Web Server Warning undefined page for request /AndroidClientHelper/updateAndroidDeviceStates from 108.XXX.XXX.XXXX
I'd be willing to test thisRogueProeliator wrote:Hey guys... I have started testing a new plugin/DP version that uses the new web server architecture and fixes a few things. I was close except for the Plugins menu not working -- I need to get back with Matt/Jay on that as a command changed and I need to update to new params I believe.
However, I can probably send you a new version to side load if you want -- to get a new version to beta I have to go through creating a YouTube video to show why the app needs geo-location information. Apparently, app updates that have used it for years may be dangerous? Who knows. But short of getting that up I THINK others things are working okay. The side load would still let geofencing work in principle but I have not tested that yet.
Adam
Right now I am able to support a minimum of SDK 21 -- Android 5.0 (Lollipop). However, library support for releases this old is quickly fading so it might be the last main release for 5.0. It looks like about 11 devices are running 5.1, the remainder are at 7.0+.Outta interest what’s the minimum android version for the new app?
I'll try to post a beta (side load) APK and a new plugin shortly. I resolved the last two issues I know about tonight, so I will get the plugin/new app version tested and post a few links. If all goes well for that then I'll start working on an official beta and trying to get all their new documentation requirements done.I'd be willing to test this
TL;DR;RogueProeliator wrote:If you are interested in trying it out... this is very beta but I am testing it all out and no major gotchas so far. A few small things to deal with but they are minor compared to it not fully working - the only "big" one is SQL Logger History doesn't show at the moment.
APK Download
https://drive.google.com/file/d/1jBQ83Y ... share_link
Indigo Plugin Release
https://github.com/RogueProeliator/indi ... 1.0-beta-2
If you do try it out, please let me know your experience.
Adam
They cannot work together on the same device, but certainly can on different devices. The plugin is not compatible with the older version for the "extra" functionality but the old plugin doesn't work with the re-architected web server. I don't think you will lose anything by upgrading the plugin (unless you are running an older version of Indigo).Can the two versions run in parallel, so I can test the new version on my phone while still having the old running on other tablets in the house?
