I am still on 2021.x and would like to upgrade now finally to 2022.x
I'm using the old HomeKit Bridge plugin.
What's the correct path here in order to upgrade to the HomeKitLink Siri plugin?
First, upgade to Indigo 2022.x then install this new plugin?
Will it find the already published devices from the old one?
Or do I have to delete all device in HomeKit first and re-create then one by one afterwards?
Thanks for any advise!
Upgrading from HomeKit Bridge
Re: Upgrading from HomeKit Bridge
Try here: viewtopic.php?f=366&t=26142
Glenn went to a lot of effort to detail the process, you should be able to find all the answers there.
Thanks, Colly!Colly wrote:Try here: viewtopic.php?f=366&t=26142
I know about Glen's documentation.
However, it's not clear, if I have to delete the "old" bridge" and the devices before uprdading to the new plugin. But I will do so.
I was able to run both HomeKit Bridge and HomeKitLink Siri plugins at the same time. I then deleted devices from HKB and added them to HKLS. HomeKit allows multiple accessory servers, so it's OK to have a HKB accessory and a HKLS accessory.
papamac
papamac
- durosity
Hey Yassi,
Do you have any native HomeKit devices in the system? Or anything published from HomeBridge? Also what version of iOS are you running on your iPhone?
OK, thanks!papamac wrote:I was able to run both HomeKit Bridge and HomeKitLink Siri plugins at the same time. I then deleted devices from HKB and added them to HKLS. HomeKit allows multiple accessory servers, so it's OK to have a HKB accessory and a HKLS accessory.
papamac
Will try it.
Hi durosity,durosity wrote:Hey Yassi,
no native HomeKit devices, everything comes from Indigo.
I have two iPhones on iOS 16.2, one on 15.7.2
Yassi
- durosity
If it wasn't for the iPhone on iOS 15 I'd suggest just deleting the home and setting up from scratch as the new HomeKit architecture is much faster in response time for me.. but that only works if you're using iOS 16.2 or above. I had a horrible time upgrading from the old architecture to new but deleting and re-building was dead easy and resulted in a much more stable system. Seems quite a few people have had similar results (I guess that's why Apple disabled the option to upgrade to the new HomeKit system)
OK, I see.durosity wrote:If it wasn't for the iPhone on iOS 15 I'd suggest just deleting the home and setting up from scratch as the new HomeKit architecture is much faster in response time for me.. but that only works if you're using iOS 16.2 or above. I had a horrible time upgrading from the old architecture to new but deleting and re-building was dead easy and resulted in a much more stable system. Seems quite a few people have had similar results (I guess that's why Apple disabled the option to upgrade to the new HomeKit system)
Didn’t switched yet the plugins.
I will try at least to delete the device and re-create them.
And with the new architecture I know there were a lot of issues (the reason Apple pull it out after a while). But now with 16.3 the’ll bring it back.
Gesendet von iPhone mit Tapatalk
