Pushover v2022.0.0 Invalid Token problems
Mon Oct 17, 2022 8:20 pm
haychess offline
Hi
I have followed all the instructions, but no matter what I do the plugin gives me an error:
Post Error - Result: {"token":"invalid","errors":["application token is invalid"],"status":0,"request":"xxxxxxxxxxxxxxxx"}
How can I get this working?
Tue Oct 18, 2022 2:19 am
Re: Pushover v2022.0.0 Invalid Token problems
Enable debug logging, restart the plugin, try to send a notification, post the log output.
Tue Oct 18, 2022 12:38 pm
haychess offline
Starting plugin "Pushover 2022.0.0" (pid 15283)
Pushover Debug logLevel = 5
Started plugin "Pushover 2022.0.0"
Pushover Debug startup called
Pushover Debug Sounds = OrderedDict([('pushover', 'Pushover (default)'), ('bike', 'Bike'), ('bugle', 'Bugle'), ('cashregister', 'Cash Register'), ('classical', 'Classical'), ('cosmic', 'Cosmic'), ('falling', 'Falling'), ('gamelan', 'Gamelan'), ('incoming', 'Incoming'), ('intermission', 'Intermission'), ('magic', 'Magic'), ('mechanical', 'Mechanical'), ('pianobar', 'Piano Bar'), ('siren', 'Siren'), ('spacealarm', 'Space Alarm'), ('tugboat', 'Tug Boat'), ('alien', 'Alien Alarm (long)'), ('climb', 'Climb (long)'), ('persistent', 'Persistent (long)'), ('echo', 'Pushover Echo (long)'), ('updown', 'Up Down (long)'), ('vibrate', 'Vibrate Only'), ('none', 'None (silent)')])
Trigger TEST
Pushover Debug send pluginAction.props = io.thechad.indigoplugin.pushover : (dict)
msgAttachment : (string)
msgBody : TEST (string)
msgDevice : (string)
msgPriority : 0 (string)
msgSound : (string)
msgSupLinkTitle : (string)
msgSupLinkUrl : (string)
msgTags : TEST (string)
msgTitle : TEST (string)
msgUser : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (string)
Pushover Error Post Error - Result: {"user":"invalid","errors":["user identifier is not a valid user, group, or subscribed user key"],"status":0,"request":"b2cca014-4a48-4749-a2e9-702e12014a17"}
I blocked out my msgUser number (hence the "xxxxxxx")
Tue Oct 18, 2022 12:41 pm
Well, that's a different error.
Try it without the user key in the action dialog, so it just uses the API token and user key from the plugin config dialog.
Thu Oct 20, 2022 9:48 pm
haychess offline
That fixed it. Thanks so much.
