GeoFence - the Beacon replacement plugin
Sat Jul 30, 2022 8:21 pm
GlennNZ offline
Re: Beacon replacement plugin
Sorry - I meant for the above user error - would bypass Geofency/App issues and check that reflector API/settings are working. (Likewise could conceivably do a test button?)
You'll get an error because it's not a POST and doesn't have the right parameters.
Sat Jul 30, 2022 8:22 pm
Oh, it's fixed. He was using just the reflector host name and not the complete URL.
Mon Aug 01, 2022 1:34 am
mclass offline
Thanks,Joe for another great contribution!
Got it set up & working with Locative, but the next challenge is that I have two sites, each with its own Indigo server and each having it’s own reflector.
It seems to me after a bit of investigation that Locative will only serve a single reflector URL with one webhook message for entry and another for exit from a geolocation.
I realise that you’re not a Locative support resource, but wondered if you had any suggestions on how I can support the two separate locations and servers.
One option I considered was to have two different iPhone apps (eg Locative and Geofency) with each serving one of the two different locations. Interested if there’s any other bright suggestions!
TIA
mclass
Mon Aug 01, 2022 7:26 pm
GeoFence Plugin
I renamed the plugin to GeoFence. It uses the same plugin ID as the old Beacon plugin, so you should be able to just download the new plugin and double-click and it'll all work.
https://github.com/FlyingDiver/Indigo-G ... g/2022.1.0
This SHOULD do everything the old one did. The ONLY change that should be needed is make sure your reflector is working and to put an API key in the plugin config.
I'll be traveling for a couple days. Please test and comment. Open GitHub issues for actual bugs.
Mon Aug 01, 2022 7:29 pm
Only thing that comes to mind immediately is to designate one site as the "controller" and have all apps report to it. Then from there set up an action that forwards the notifications to the other site. Maybe use MQTT to send a message that fires an action group?
Mon Aug 01, 2022 7:32 pm
Re: GeoFence - the Beacon replacement plugin
How useful would it be to have all the parameters sent from the mobile app available as custom states in the GeoFence devices? For Locative, that's this data:
          device : FECE6A6E-8B0E-4108-884B-4B36CE34D68C (string)
          device_model : iPhone14,2 (string)
          device_type : iPhone (string)
          latitude : 123.0 (string)
          longitude : 123.0 (string)
          timestamp : 1659401290.0 (string)
          trigger : enter (string)
For Geofency we get:
    body_params : (dict)
          address : XXXXX  (string)
          category : Monitored (string)
          date : 2022-08-02T01:31:14Z (string)
          device : A7AA5CED-29B9-4747-8BEC-D5777D3DF47F (string)
          entry : 0 (string)
          latitude : XX (string)
          longitude : YY (string)
          radius : 100 (string)
          wifiBSSID : 7e:8a:20:5e:2:e3 (string)
          wifiSSID : WIFI (string)
Mon Aug 01, 2022 7:43 pm
ryanbuckner offline
          entry : 0 (string)
Extremely useful
Wed Aug 03, 2022 1:04 pm
Great, looking forward to updating to this.
Currently use Geofency.
Sat Aug 06, 2022 12:07 pm
Thu Sep 22, 2022 4:08 pm
jltnol offline
Hey folks
I'm running into a bunch of issues with iOS16 and the 2 location apps I have on my phone. Both apps are triggering without crossing boundaries. In today's example, I left the house and crossed both the Loc1 and Loc2 fence, which are concentric circles around my house with Loc1 being the closest. I came home about 16:30, and the "arrive" triggers didn't happen because both thought I was already there. I have 2 apps on my phone and this log is from the Locative app. While the other app has more "crossings" in the log, both show multiple crossings that simply didn't happen. I'm guessing this is an iOS 16 issue, and not an issue with the apps, and certainly not an issue with the plugin..
But I am curious if anyone else has seen this kind of behavior.
Thu Sep 22 12:54:02 2022
09-22 12:55:17.798000 Loc-1 False
09-22 12:56:49.118000 Loc-2 False
09-22 12:59:29.119000 Loc-2 True
09-22 12:59:29.200000 Loc-1 True
09-22 12:59:36.937000 Loc-2 False
09-22 12:59:37.109000 Loc-1 False
Thu Sep 22 12:59:37 2022
Thu Sep 22 13:00:58 2022
09-22 13:01:33.886000 Loc-2 True
09-22 13:01:33.887000 Loc-1 True
09-22 13:04:23.091000 Loc-1 False
09-22 13:04:23.099000 Loc-2 False
09-22 13:51:20.915000 Loc-2 True
09-22 13:51:21.080000 Loc-1 True
09-22 13:51:27.062000 Loc-2 False
09-22 13:51:27.230000 Loc-1 False
09-22 13:53:16.785000 Loc-2 True
09-22 13:53:16.976000 Loc-1 True
note in this list, the most worrisome entries are the ones around 13:51, as I had left a restaurant, but was no where NEAR the Loc1 or Loc2 fence
So the latest version of iOS seems to have fixed this issue for me.
Tue Oct 04, 2022 12:09 pm
jltnol offline
So I'm pretty sure I've finally gotten to the bottom of this, and it has to do with my phone. It occasionally gets "lost" and doesn't know where it is on the map. Not sure what the cause of THAT is, but regardless, as I move thru my geo fences, and the phone seeks its real location, it was causing triggers to fire when they shouldn't.
I've completely erased my phone, and re-installed the software, so I'm hoping that will solve this issue. It's been kind of a random problem, but I noticed via maps and CarPlay that I'm traveling over houses and fields, when I'm really on a street, and the map location jumps around a bit, and I'm guessing bouncing back and forth across my fences causing problems.
My cell provider has recently upgraded their equipment around me... now have much better cell internet speeds, so don't know if that plays an issue with this.
Wed Oct 05, 2022 6:20 am
norcoscia offline
Are their any instructions on how to set this up - any software required on indigo mac beyond plugin - do I need to get the pay version of phone software (locative) for it to work?
_______
Norm
Wed Oct 05, 2022 10:38 am
cuhouse offline
Joe’s (Flying Diver) location is “Southwest Florida”
This note: https://forums.indigodomo.com/viewtopic.php?f=216&t=26112&start=45#p213870 referred to the possibility of hurricane cleanup.
Indigo 2022.1.2, Big Sur v11.7.1, Dedicated late 2014 Mac Mini, PowerLinc 2413U.
Wed Oct 05, 2022 12:17 pm
norcoscia offline
Sure hope everything is OK with all concerned - was really hoping someone that is using the plug-in might help - Joe already does so much I don’t really want to make more work for him. I did not use the plug-in that this one replaced so kind of clueless on what is needed - trying to cut over any plug-in that will not function with the next indigo update and one thing I need to get working is a replacement for my current set up for geo location.
_______
Norm
