The Problem: What started this quest was that whenever I walk by the Ecobee 4 thermostat in the living room, three lights in that room would come on. This drove me crazy for some time until I figured it had something to do with my Ecobee thermostat. If I put a cover over the thermostat, just a rag so the the thermostat didn't see someone in the area and try to update the display to show the weather and show a different set of data.
I tried putting the thermostats on a separate vlan and that cured the problem of having the lights come on whenever I walked by. Whenever I put the thermostats back on the main lan with the indigo server, the behavior returned.
I tried removing the plugin and reinstalling and no luck. I did not try to do a complete clean deleting all of the devices that the plugin and uninstalling and reinstalling the plugin but that bay be my next step. I'm not sure make sure that I have got all of the bits removed. Looking at the files opened by the indigopluginhost3 process, it looks like there may be LaunchServices process that is still hanging around
/private/var/folders/n8/_q84ffjd0xnd9r4yr83dysgc0000gn/0/com.apple.LaunchServices.dv/com.apple.LaunchServices-1082-v2.csstoreAny help in what the proper way to completely clean the plugin would be helpful. Do you think that I am barking up the wrong tree?
One other thing, I keep getting "Token refresh failed, will retry in 5 minutes" errors. I'm hoping that these will go away as soon as I clean things up. I will also go to my Ecobee account to deauthorize the old app authorization when I do a clean install
Jack
